查看: 3284|回复: 1
[驱动] 菲力尔FLIR-灰点Point Grey工业相机WinX86/X64系统驱动SpinnakerSDK WEB版2.0.0.147
    半小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2020-7-22 15:27:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    版本:
    SpinnakerSDK_WEB_2.0.0.147_x64
    链接: https://pan.baidu.com/s/1NjMn-vInvXq5weJOQeZo-Q 提取码:
    SpinnakerSDK_WEB_2.0.0.147_x86
    链接: https://pan.baidu.com/s/113p8f41m4hvQopd6jykklg 提取码:
    Spinnaker SDK – 2.0.0.147
    - CHANGE LIST (list of updates with this version):
    Enhancements:
    Resolved Issues:
    - Spinnaker 2.0.0.146 device event has empty event name
    - Application version not populated in Spinnaker 2.0.0.147
    Spinnaker SDK – 2.0.0.146
    Enhancements:
    - Add GenTL producer support
    - Add analytics into SpinView for experience improvement. No personal data is connected.
    - Add support for device specific JPEG-LS payload type
    - Add a method to set zoom level of Display Window in WPF example
    - Add C++ Chunk Enabled Sequencer Core Test
    - Add SpinView FFY-DL Pop-up link to resources page
    - Add pip install enum34 instruction for Python2 in PySpin README
    - Add Camera FPS counter to Spinview_Qt
    - Bring up EULA prompt during Linux installation
    - Spinview StreamBuffercount mode changed to default from Auto to Manual with 10 default buffers
    - Configure Spinnaker Linux and MacOS to store logs, Transport Layer persistence data and GenICam device XMLs at specific location
    - Update C# tests with new GetCameraBySerial function
    - Refactor Spinnaker API functions to use DeviceID instead of serial number
    - Cleanup System XML
    - Cleanup stream XML
    - Cleanup Interface/Device XML
    - Update MultipleCamera C++ example to handle disconnect with image events
    - Update Spinnaker with new PGRLWF driver 2.7.3.342
    - Remove email register page from Win installer
    - Remove VS2010/VS2013 libs/binaries/examples from Full Windows Installer
    - Rename GevDeviceForceIP and GevDeviceForceIPEx nodes
    - Rename Events to EventHandlers
    - DEPRECATE - Remove legacy polarization methods
    - DEPRECATE - Remove old GevMaximumResendBuffers node
    - DEPRECATE - Remove deprecated video recording functions from Spinnaker API
    Resolved Issues:
    - SpinView_WPF performs poorly with unavailable network
    - Fix "Do not show" option to survey request dialog in SpinView
    - Device arrival/removal events registered on the system gets wiped when interface list changes
    - Spinnaker PDF documentation do not include html pages properly
    - Windows - Disabling a network adapter removes all cameras
    - Sequencer_C Fails to Get Image 3 and Image 5 Error -1011
    - Fix firmware update getting stuck when camera is on wrong subnet after reboot
    - Spinview_Qt exits with segmentation fault when app is closed while inference is enabled
    - USB camera can still be recognized as a FLIR camera after running uninstaller
    - Linux - log4cpp property files not present in /usr/bin after installation
    - VisionPro 9.6 BFS-U3 has a timeout error every second when put into trigger mode
    - Error in calculation of Angle of polarization (AoLP) from "ImageUtilityPolarizationImpl" spinnaker source code
    - BufferHandling.cpp example not installed for Ubuntu
    - Auto/ForceIP should use/take device ID instead of serial number
    - Error when number of buffer is set to 2
    - SpinView_WPF System context menu shows option to update firmware
    - Missing Uninstall button when running the installer of its own version
    - boost::exception_detail::error_info_injector
    - Bad lexical cast during GEV discovery for GEV cameras without serial number
    - Different BFS/GS3 cameras running at different application/threads influence one another
    - Exposure and Exposure_QuickSpin fails in all languages: Failed waiting for EventData on NEW_BUFFER_DATA event
    - Missing "Help" entry in the dropdown of "Help"
    - SpinVideoC_v140.dll depends on debug dlls
    - Spinnaker installer completed quickly, with nothing installed on the PC.
    - Spinnaker uninstallation fails, hanging at 95% of random packages
    - Implement stream related nodes for querying buffer pool sizes/counts
    - SpinView switching from Features tab to Settings tab after starting
    - Implement BUFFER_INFO_NEW_DATA for DSGetBufferInfo
    - Set 1MiB limit for StreamBlockTransferSize
    - Spinnaker and GenTL Logs missing from Spinview logging
    - SpinView_Qt Acquisition Mode dropdown menu is editable when device is streaming
    - SpinView_Qt Linux Acquisition Mode Dropdown Menu Is Cut Off
    - EXC_CRASH when trying to start SpinView and other precompiled examples in MAC OS with Spinnaker v1.24.0.60
    - SpinView_WPF 1.26.0.31 launches AdapterConfigGUI when selecting Configure Adapter Properties on network interface
    - Issue setting and forcing persistent IP in Spinview_QT
    - SpinView_WPF - Inference Label default color is white
    - SpinView_WPF IP config shows Failed setting current IP (camera) even though it does not fail
    - SpinView_Qt crashes with segfault when disconnecting an initialized/streaming camera
    - Firefly camera removal does not trigger removal event on Linux
    - Issue with multiple device reset on Ubuntu
    - SpinView 1.28.0.14 showing camera twice after force IP
    - SpinView_WPF crashes when changing acquisition modes with FireflyDL
    - Some BFS-PGE cameras hang when others are plugged into the same switch
    - Cannot update firmware with SpinView 1.27.0.48 and 1.28.0.14
    - Spinview_Qt 1.27.0.48 segfaults when Ax5 is selected
    - Cannot restart acquisition after DeviceReset on RaspberryPi3
    - Spinnaker Version format is inconsistent in Control Panel
    - Upgrade prompt page showing wrong format of installed Spinnaker version
    - SpinView_Qt category node names are editable
    - EndAcquisition() takes long when large amount of buffers are allocated
    - SpinView_Qt crashes when streaming from software disconnect/reconnect
    - FFY-U3 sometimes hangs when stopping/starting while streaming
    - SpinView_WPF sometimes fails to enumerate GigE cameras
    - Typo in Inference.py Example
    - Saving snapshot crashes SpinView_WPF
    - install_spinnaker.sh does not install spinnaker-doc
    - Dependency problem running remove_spinnaker.sh to install older Spinnaker
    - Camera doesn't show up when in updator mode.
    - Spinview_Qt 1.25.0.52 not able to cascade displays (streaming window) horizontally
    - Searching camera feature in SpinView_Qt does not work with spaces
    - BFLY-PGE doesn't do exposureauto "once" in api, but does in SpinView
    - Dead links in install_spinnaker.sh 1.27.0.48 and trying to register old version
    发表于 2020-10-31 14:28:44 | 显示全部楼层 来自:广东省广州市 移动
    GMT+8, 2026-4-8 08:45
