查看: 5347|回复: 0
[LV工具模块] LabVIEW 2020 FPGA IP Export Utility Win64ENG LabVIEW2020 FPGA IP导出工具包IPEU2020-64bit
发表于 2020-8-3 18:20:39 | 显示全部楼层 |阅读模式
LabVIEW FPGA IP Export Utility可用于导出LabVIEW FPGA算法,以便在第三方硬件上进行部署。
LabVIEW FPGA IP Export Utility是一个软件附件,可帮助您使用LabVIEW FPGA在NI FPGA硬件上对实时算法进行快速原型设计。然后,您可以将经过验证的设计导出为VHDL源代码或网表,以在第三方硬件上使用。使用LabVIEW FPGA IP Export Utility需要先安装LabVIEW FPGA模块。
该工具包为2020版首发的,之前没有该工具包,以前应该是使用FPGA IP Builder生成器来完成类似的任务(因为我方不使用该工具包,只是猜测,未验证)。2020版可选Windows32位、64位版本,仅英文版。
文件大小: 321845248 字节 (306.94 MB)
修改日期: 2020-05-12 01:22
MD5: 8bc136619e1f79674ce8799c3cb92224(官方正确)
SHA1: ad779b39bd22c34171e5b807607631b3279e21ff
SHA256: f4488eb0d9a15fcef6be5421b41ef7d9086b90626b4367e4cbff55f79d0ae0be
CRC32: 29a34729
IPEU2020-64.txt (337 Bytes, 下载次数: 1, 售价: 10 圆)
LabVIEW 2020 FPGA IP Export Utility Readme
March 2020
This file contains important information about the LabVIEW FPGA IP Export Utility, including system requirements and installation instructions.
Activation Notice
The LabVIEW FPGA IP Export Utility Drops Support for Windows 7 in 2021
The LabVIEW FPGA IP Export Utility allows you to export your FPGA algorithm developed in LabVIEW FPGA as FPGA IP (Intellectual Property). You can then integrate the IP in your Vivado project and use the IP on any Xilinx Vivado FPGA device of the same family. The LabVIEW FPGA IP Export Utility provides the following editions:
  • LabVIEW FPGA Netlist Export Utility—Exports an FPGA algorithm as an encrypted netlist.
  • LabVIEW FPGA VHDL Export Utility—Exports an FPGA algorithm as an encrypted netlist or plaintext VHDL.
The LabVIEW 2020 FPGA IP Export Utility has the following requirements:
  • LabVIEW 2020 Full or Professional Development Systems (32-bit or 64-bit)
  • LabVIEW 2020 FPGA Module (32-bit or 64-bit)
  • LabVIEW 2020 FPGA Compilation Tool for Vivado 2019.1
Refer to the LabVIEW Readme, LabVIEW FPGA Module Readme, and Xilinx Compilation Tools Readme for additional system requirements and supported operating systems.
The LabVIEW 2020 FPGA IP Export Utility supports the following operating systems:
  • Windows 10 (version 1909) (64-bit)
  • Windows 7 SP1 (64-bit)1
1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
Note  Refer to The LabVIEW FPGA IP Export Utility Drops Support for Windows 7 in 2021 for information about future OS support.
NI installs the LabVIEW FPGA IP Export Utility using NI Package Manager. If you do not already have NI software installed, the LabVIEW FPGA IP Export Utility installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
Activation Notice
The LabVIEW FPGA IP Export Utility provides two purchase options: LabVIEW FPGA Netlist Export Utility and LabVIEW FPGA VHDL Export Utility. Depending on your purchase option, activate the LabVIEW FPGA IP Export Utility in the following ways:
  • LabVIEW FPGA Netlist Export Utility—Allows you to export your FPGA algorithm developed in LabVIEW FPGA to FPGA IP as an encrypted netlist. Activate or evaluate the LabVIEW FPGA IP Export Utility using NI License Manager.
  • LabVIEW FPGA VHDL Export Utility—Allows you to export your FPGA algorithm developed in LabVIEW FPGA to FPGA IP as an encrypted netlist or plaintext VHDL. Activate the LabVIEW FPGA IP Export Utility in the following ways:
    • Activate the LabVIEW FPGA IP Export Utility using NI License Manager.
      Upon activation, you can export your FPGA algorithm developed in LabVIEW FPGA to FPGA IP as an encrypted netlist.
    • To export your FPGA algorithm as plaintext VHDL, continue with the following steps:
      • Email labview.fpga.VHDL.access@ni.com with the following information:
        • LabVIEW version
        • Serial number for the LabVIEW FPGA VHDL Export Utility license
        • Volume serial number—Accessible by running the vol C: command from the command line window.
        If your request is approved, you will receive a node-locked catalog (.cat) file that you can use on the designated computer with the specified LabVIEW version.
      • Install the catalog file on the designated computer by completing the following steps:
        • Close LabVIEW.
        • Create a folder named IPExport in the labview\FPGA directory, where labview is the installation directory of the specified LabVIEW version.
        • Copy the catalog file to the new folder.
      You can then export your FPGA algorithm as plaintext VHDL.
      Note  You can change the filename of the catalog file. Do not include spaces, special or non-ASCII characters in the catalog filename.
Refer to the Getting Started with the LabVIEW FPGA IP Export Utility for information about using the LabVIEW FPGA IP Export Utility. Access this manual by navigating to the labview\manuals\LabVIEW FPGA IP Export Utility directory and opening FPGA_IP_Export_Getting_Started.pdf
The LabVIEW FPGA IP Export Utility will drop support for Windows 7 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
© 2020 National Instruments. All rights reserved.
378241A-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:24
