查看: 7521|回复: 2
[LabVIEW] NI LabVIEW 2017 Pro Linux64Eng LV2017Linux系统专业版下载
    11 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2020-10-23 22:44:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW 2017 SP1 Pro Linux专业版,可在Linux系统中安装使用(使用范围参考下面的Readme)。专业版和完整版比较,多了应用生成功能、VI分析器等功能,具体请查看自述文件。
    LabVIEW 2017 Linux专业版
    发布日期:2017/5/23
    CentOS
    openSUSE
    Scientific Linux
    RedHat
    语言:英文
    文件大小: 1138688000 字节 (1.06 GB)
    修改日期: 2017-08-03 02:05
    MD5: 013b129b36c37139b231b3d824f3aa12(重复下载一致)
    SHA1: 1c8e6b5af3918d94b43edd7a33b8356be2a23cbd
    SHA256: 0539182ecfd1de1e2014ebbe098dea3520c85f38df23307d0522c360934d328e
    CRC32: b134a498
    请注册视觉论坛会员登录后购买附件下载查看
    LabVIEW2017ProLinux.txt (567 Bytes, 下载次数: 9, 售价: 100 圆)
    LabVIEW 2017 Readme for GNU/Linux
    March 2017
    This file contains important information about LabVIEW 2017 for Linux, including system requirements, installation instructions, known issues, and a partial list of bugs fixed.
    Supported Drivers
    Additions to the LabVIEW Help
    LabVIEW Does Not Support 32-bit Linux Distributions
    LabVIEW 2017 for Linux has the following requirements:
    LinuxRun-Time EngineDevelopment Environment
    Operating SystemLinux kernel 2.6x or 3.x
    GNU C Library (glibc) Version 2.11 or later for the Intel x86_64 architecture
    openSUSE LEAP 42.1
    openSUSE LEAP 42.2
    Red Hat Enterprise Linux Desktop + Workstation 6.x
    Red Hat Enterprise Linux Desktop + Workstation 7.x
    Scientific Linux 6.x
    CentOS 7
    Note  LabVIEW and LabVIEW Run-Time Engine require 64-bit processors which support SSE2 instructions.
    Complete the following steps to install and activate LabVIEW for Linux.
    Are you installing LabVIEW for the first time? Insert and mount the LabVIEW installation media. As the root user in the mounted directory, enter sh ./INSTALL to install LabVIEW in the /usr/local directory. When prompted, enter the serial number for the product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    You can install NI device drivers from ni.com/linuxdrivers.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2017.
    LabVIEW 2017 for Linux supports the following modules and toolkits.
    • MathScript RT Module2
    • VI Analyzer Toolkit
    2 The MathScript RT Module does not support the libraries class of MathScript RT Module functions.
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2017, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2017.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2017. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    404983Dynamic load of LabVIEW Class fails when built into a DLL.
    522606Error Ring does not adhere to dataflow in an executable or in a VI with debugging disabled.
    524160Updated Timed Loop Mode example VI to better display custom phase and show correct value for period in context help.
    567353When an XNode output is wired to the Loop count of a Parallel For Loop the VI breaks.
    571901Using the BD Get Image Scaled method crashes LV 2014 and 2015 if the depth of the image is 1.
    572024Built applications hang in some instances when calling Quit LabVIEW.
    584378LabVIEW has the potential to crash when simultaneously setting multiple variant attributes to empty variant constants.
    588140Insert of Compound Arithmetic node on wire can result in undesirable configuration.
    590370Levenberg-Marquardt algorithm has poor convergence in some cases.
    591709Calling Format Value on improper value can result in crash.
    592088Improper updates of library members when using Actor Framework Message Maker.
    594760Example "Extract number with match pattern" gives incorrect output.
    595814The unflatten from String primitive can take several minutes to return when given malformed input strings.
    595815DataSocket Read VI crashes LabVIEW when calling certain IP addresses.
    596804Re-registering a dynamic event can cause subscribing event frames to behave improperly.
    598986Scrollbar does not properly respond to clicks on string constant.
    601256Error message when replacing existing channel endpoint with an invalid configuration is not clear.
    601764Local variables can be created from channel wires.
    601807Resizing a "Register for Events" Node Crashes LabVIEW.
    602230Connecting conflicting channel types does not always break the wire.
    602973In some cases, using the Min/Max function on array of single precision floating point numbers can cause a VI to fail to compile.
    603092Rearranging tabs in tab control can cause a crash.
    603391Incorrect Out of Memory dialog when using "Active Plot" property node in 64-bit LabVIEW.
    603562Using dynamically dispatched VIs with unwired input terminals can, in some cases, cause crashes.
    603576Channels carrying typedefs/classes create crosslinks when users duplicate projects.
    603854QMH project template contains a potential race condition.
    605231Attempting to abort a VI may not always cause the VI to abort.
    606365Dragging a control or indicator to the edge of the block diagram can cause duplication of the front panel object.
    606847Dynamic Dispatch VIs break when the class wire is passed through a shift register in specific cases.
    607685Cast Unit Bases does not correctly remove units from output.
    611532Selecting "Use Default if Unwired" on an output tunnel with a LabVIEW class data type will cause a broken VI with no errors.
    611810Saving a VI containing a "Lookup Channel Probe" node for LabVIEW version 2015 and earlier can result in failure to open the saved VI.
    611838The abort behavior of the Accumulator Tag channel wire does not match that of other implementations.
    612501Interpolate 2D Scattered VI will return an incorrect value for specific size input values.
    615195Collapsing "Variant Attribute Get / Replace" border node on In Place Element Structure causes LabVIEW to crash.
    615288Previous versions of LabVIEW are unable to open dynamic classes saved using "Save for Previous Version" in 2016.
    616848Using Quick Drop to add a Custom Control Template to a VI's Front Panel crashes LabVIEW.
    617119Pressing Abort during project creation then creating another project causes LabVIEW to crash in some cases.
    617504Dragging the front panel icon of a VI onto the block diagram of another VI will undo the last edit of the dragged VI in some cases.
    617917Possible crash when loading particular classes.
    624304Actors that return an error from Pre Launch Init also send a Last Ack containing the same error.
    624957Possible memory corruption when opening invalid file.
    627716Opening a project with "Messenger Channels" causes a search for Wrapper.lvclass.
    627910Large projects may have extended save times.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2017.
    • In LabVIEW 2017, you can insert the contents of a subVI into the calling block diagram at edit time by right-clicking the subVI node and selecting Replace with SubVI Contents. In the Replace with SubVI Contents dialog box that appears, you can configure the following options:
      • Make space in calling diagram to fit subVI contents—Specifies whether to adjust the calling block diagram to accommodate the contents of the subVI.
      • Wrap subVI contents in a Sequence structure—Specifies whether to place the contents of the subVI in a Stacked Sequence structure.
    LabVIEW dropped support for Intel 32-bit versions of Linux distributions on July 1, 2016. Versions of LabVIEW that ship after July 1, 2016 may install and execute on Intel 32-bit distributions, but official support is not provided.
    © 2004–2017 National Instruments. All rights reserved.
    374718G-01
    发表于 2022-4-4 23:14:18 | 显示全部楼层 来自:江苏省徐州市 移动
    GMT+8, 2026-4-9 20:03
