查看: 3104|回复: 0
[NI驱动程序] NI-USRP 1.3 Driver Win32Eng NI通用软件无线电外设仪器驱动程序1.3下载
    发表于 2020-11-16 22:48:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    1.3
    文件大小: 598984705 字节 (571.24 MB)
    修改日期: 2019-06-25 02:58
    MD5: 40a4825724e5fcde2a51190cb34db717(官方正确)
    SHA1: d064d4c3a3c2b6ee2d7b2982f026c7deaf29b27f
    SHA256: 59ed23621beb26fa08cb0e0dedfb71cb8c48ab1d3e30616e4292b7ea1cfb43ba
    CRC32: 6054ca44
    USRP1.3.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP Readme
    Version 1.3
    Thank you for using NI-USRP instrument driver software. This file contains important information about NI-USRP and is organized into the following sections:
    Accessing VIs and Sample Project
    Accessing Examples
    Uninstalling/Modifying NI-USRP
    NI-USRP 1.3 adds the following features:
    • Support for LabVIEW 2013.
    • Support for NI USRP-2940R, NI USRP-2942R, NI USRP-2943R, NI USRP-2950R, NI USRP-2952R, and NI USRP-2953R devices (NI 294x/295x devices also may be used as LabVIEW FPGA targets)
    • Compatible with Ettus Research USRP X300 and USRP X310 devices using the following daughterboards:
      • SBX
      • CBX
      • WBX
    • Support for Windows 8.1
    NI-USRP 1.2 includes the following features:
    • Support for the NI USRP-2930 device
    • Support for the NI USRP-2932 device
    • API Changes:
      • VIs
        • niUSRP Get Time VI
        • niUSRP Wait for Lock VI
        • niUSRP LV Timestamp to USRP Timestamp VI
        • niUSRP USRP Timestamp to LV Timestamp VI
      • Properties
        • GPS Lock Status property
        • GPS Sentence GGA property
        • GPS Sentence RMC property
        • GPS Time (seconds) property
        • Has GPS Disciplined Clock? property
    • Compatible with Ettus Research USRP2, USRP N200, and USRP N210 devices using the following daughterboards:
      • SBX
      • LFTX
      • LFRX
      • BasicTX
      • BasicRX
    NI-USRP 1.1 includes the following features:
    • Support for the NI USRP-2922 device
    • Support for configuring 8-bit sample width for transferring data over the bus, which can increase streaming rates and allow higher I/Q rates
    • Support for fetching and writing binary data waveforms
    • Support for programmatically discovering devices in the system and their model information using the niUSRP Find Devices VI
    • Support for controlling multiple devices in a single session (for use in MIMO applications)
    • Support for locking the local oscillator (LO) to a user-specified frequency and controlling the carrier frequency independently using the digital signal processor (DSP)
    • Support for reconfiguring gain, carrier frequency, and active antenna while an acquisition or generation is in progress
    • API Changes:
      • VIs
        • niUSRP Fetch Rx Data (I16) VI
        • niUSRP Fetch Rx Data (2D CDB) VI
        • niUSRP Fetch Rx Data (2D I16) VI
        • niUSRP Write Tx Data (I16) VI
        • niUSRP Write Tx Data (2D CDB) VI
        • niUSRP Write Tx Data (2D I16) VI
        • niUSRP Find Devices VI
      • Properties
        • Number of Channels in Session property
        • Host Data Type property
        • Sample Width property
        • Expected Peak property
        • LO Frequency property
        • Warning Policy property
      • SBX
      • LFTX
      • LFRX
      • BasicTX
      • BasicRX
    NI-USRP 1.0 includes the following features:
    • Support for NI USRP-292x devices
    • Support for LabVIEW 2011 (32-bit)/2010 (32-bit)/2009 (32-bit)
    • Support for Windows 7/Vista/XP
    • Interactive configuration utility to change device IP addresses and update firmware and FPGA images
    • Support for continuous and finite generation (Tx) and acquisition (Rx) operations
    • Full set of examples, including examples that use the NI LabVIEW Modulation Toolkit
    • Integration with NI LabVIEW Modulation Toolkit
    • Compatible with Ettus Research USRP2 and USRP N210 devices using the following daughterboards:
      • WBX
      • XCVR2450
    The following hardware products are supported under Windows 8.1 (32-bit and 64-bit1 versions)/7 (32-bit and 64-bit1 versions)/Vista (32-bit and 64-bit1 versions)/XP operating systems.
    • NI USRP-2920
    • NI USRP-2921
    • NI USRP-2922
    • NI USRP-2930
    • NI USRP-2932
    • NI USRP-2940R
    • NI USRP-2942R
    • NI USRP-2943R
    • NI USRP-2950R
    • NI USRP-2952R
    • NI USRP-2953R
    • Ettus Research USRP22
    • Ettus Research N2002
    • Ettus Research N2102
    • Ettus Research X3002
    • Ettus Research X3102
    1 These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
    2 The NI-USRP instrument driver supports WBX, SBX, XCVR2450, LFTX, LFRX, BasicTX, and BasicRX daughterboards on this device. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    Note  For NI 292x/293x devices, use LabVIEW 2010 or later. For NI 294x/295x devices, use LabVIEW 2013 or later.
    Note  You must update the firmware and FPGA images on your USRP module prior to using NI-USRP 1.3. Refer to the NI USRP-29xx Getting Started Guide for more information about updating the firmware and FPGA images.
    NI-USRP 1.3 supports the following operating systems:
    • Windows XP Service Pack 3 (SP3)(32-bit)
    Minimum System Requirements
    • RAM—1 GB
    • Gigabit Ethernet interface
    • Windows 8.1/7/Vista/XP SP3 with all available critical updates and service packs
    Recommended System
    • Processor—Intel i7 or equivalent
    • RAM—2 GB
    • Dedicated gigabit Ethernet interface for each device
    Application Development Environment (ADE)
    Note  You should install ADEs, such as NI LabVIEW, before installing NI-USRP. To add support for ADEs installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    NI-USRP 1.3 supports the following software versions, including service packs:
    • LabVIEW 2010 (32-bit only), 2011 (32-bit only), 2012 (32-bit only), 2013 (32-bit only)
      • Windows 8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Program Files\National Instruments\
      • Windows 8.1(64-bit)3/7 (64-bit)3/Vista (64-bit)3: Program Files (x86)\National Instruments\
      • Windows 8.1 (32-bit)/7 (32-bit)/Vista (32-bit)/Windows XP: Windows\System32
      • Windows 8.1(64-bit)3/7 (64-bit)3/Vista (64-bit)3: Windows\syswow64
    3 These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
    ItemInstalled Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\NI-USRP\includes\
    NI-USRP Import Library files\NI-USRP\lib\msc\
    NI-USRP DLL\niusrp.dll
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Note  The NI Example Finder does not include NI-USRP examples.
    Documentation for NI-USRP 1.3 and NI-USRP devices is located at Start» Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI-USRP HelpHTML/Windows HelpThe primary document for NI-USRP products. The help is an HTML version of a traditional user manual that includes:
    • an introduction to NI-USRP
    • hardware device overviews
    • how to get started with application development
    • a complete reference for all NI-USRP programming functions
    NI USRP-29xx Getting Started GuidePrinted and PDFPrinted and PDF format. Contains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    SpecificationsPrintedPDF format. Lists technical specifications for all NI-USRP devices.
    NI-USRP 1.3 ReadmeHTML (this document)This document.
    To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the Simple NI-USRP Streaming project.
    NI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
    Accessing Examples
    NI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other SDR functionality. You can access the NI-USRP examples from the following locations:
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    You can access additional examples from the Code Sharing Community at ni.com/usrp.
    Perform the following procedure to uninstall NI-USRP.
    • Click Change/Remove.
    • Select NI-USRP 1.3 from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Go to the desktop.
    • Select the Charms Bar.
    • Select Settings.
    • Click Control Panel.
    As part of the NI-USRP 1.3 installation, the following software is installed. To completely remove the NI-USRP 1.3 installation from your system, you must also remove all of the following packages:
    • NI LabVIEW Modulation Toolkit 4.3.4
    • NI LabVIEW MathScript RT Module (depending on distribution)
    • NI LabVIEW Digital Filter Design Toolkit (depending on distribution)
    • NI-RIO 13.1.1
    • NI Measurement & Automation Explorer 5.6.0
    Ethernet Support on NI 294x/295x Devices
    NI 294x/295x devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G and port 1 is designated for 10G.
    You can access the software and documentation known issues list online. Refer to the NI-USRP 1.3 Known Issues at ni.com for an up-to-date list of known issues.
    The following items are changes in NI-USRP 1.3 from NI-USRP 1.2.
    460052Fixed an issue that caused the local oscillator to fail to lock when two devices connected by the MIMO connector transmit synchronously while one device also receives.
    The following items are changes in NI-USRP 1.2 from NI-USRP 1.1.
    376069Fixed an issue that caused the property node "Number of Samples is Finite" to always return a "false" value regardless of whether the task was set as finite or continuous.
    370383Fixed an issue that caused a multi-device session to fail. Remove any trailing semicolons in lists of devices. For example, use "192.168.10.2; 192.168.10.3" instead of "192.168.10.2; 192.168.10.3;".
    362726Fixed an issue that caused LabVIEW to crash after configuring the number of samples in niUSRP EX Rx Continuous Async.vi.
    The following items are changes in NI-USRP 1.1 from NI-USRP 1.0.
    325276Corrected the documented maximum input power (Pin) for the NI USRP-2920 to 0 dBm.
    325144Fixed an issue that caused the NI-USRP Configuration Utility to hang if the final field of the IP address was three or more digits.
    313727Fixed an issue where the niUSRP EX QAM Rx example VI would not display a signal constellation when run using the default values.
    311842Fixed an issue where NI-USRP returned an error if you opened an Rx session when a Tx session was already open for a separate device.
    313754Fixed an issue where NI-USRP returned an incorrect value for the coerced gain parameter on a Tx session using the NI USRP-2920.
    329137Fixed an issue where NI-USRP raised the class of the process to "Real-Time" and the priority of the thread to "Highest" when an Rx operation started.
    Using NI Launcher
    Finding All Programs
    NI-USRP Drops Support for Microsoft Windows Vista, and Windows XP in 2016
    National Instruments NI-USRP will drop support for Microsoft Windows Vista, and Windows XP as of July 1, 2016. Versions of NI-USRP that ship after July 1, 2016 will not install or run on Windows Vista, or Windows XP. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2011–2014 National Instruments. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    GMT+8, 2025-12-8 07:25
