查看: 3171|回复: 0
[NI驱动程序] NI-USRP 18.1 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序18.1下载
  • 签到天数: 3859 天
    连续签到: 52 天
    发表于 2020-11-16 23:20:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    18.1
    文件大小: 3499694008 字节 (3.26 GB)
    修改日期: 2018-08-17 22:46
    版本: 18.1.0.0
    MD5: 57c1cd8cadc3355a099d0605e5751dab(官方正确)
    SHA1: 04b2f5ba475a383be672b092eab777db37f29ddc
    SHA256: ec85aee5076631876562b333cd09e467e8ef86b124f6876f262bb3aadd720fb2
    CRC32: ca201b8a
    USRP18.1.txt (587 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP 18.1 Readme
    July 2018
    This file contains important information about NI-USRP, including installation instructions, new features, a partial list of bugs fixed for NI-USRP 18.1, and known issues.
    Finding Examples, Lessons, and Sample Projects
    This software installation provides support for customers using software defined radio (USRP) devices, software defined radio reconfigurable (USRP RIO) devices, and software defined radio stand-alone (USRP Stand-Alone) devices, as specified in the Supported Hardware section. To program your USRP, USRP RIO, or USRP Stand-Alone device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP, USRP RIO, or USRP Stand-Alone device.
    NI-USRP 18.1 adds support for LabVIEW NXG 2.1 and LabVIEW Communications System Design Suite 2.1.
    NI-USRP 18.0 adds support for LabVIEW 2018 (32- and 64-bit).
    NI-USRP 17.2 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.0.
    NI-USRP 17.1 adds support for several bug fixes.
    NI-USRP 17.0 adds support for LabVIEW 2017 (32- and 64-bit).
    NI-USRP 16.1 includes the following new features:
    • Support for USRP-2945 and USRP-2955 devices with LabVIEW 2016
    • Support for USRP-2900 and USRP-2901 devices with LabVIEW 2016
    NI-USRP 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955
    • USRP-2974
    • Ettus Research USRP2*
    • Ettus Research N200*
    • Ettus Research N210*
    • Ettus Research X300*
    • Ettus Research X310*
    *The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450
    daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    NI-USRP 18.1 has the following requirements:
    • Processor——1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
      Note  LabVIEW NXG and LabVIEW Communications System Design Suite support only 64-bit (x64) processors.
    • Connector requirements shown in the following table
    Device
    USB 2.0 or Higher
    Gigabit Ethernet
    PCI/MXI Express x4
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/3932
    USRP-2940/2942/2943/2944/2945
    USRP-2950/2952/2953/2954/2955
    USRP-2974
    Ethernet Support on USRP RIO Devices
    USRP RIO devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
    The USRP-2974 is only supported through Ethernet using 1 GbE through RJ45 and 10 GbE through SFP+ connections.
    Note  The FPGA cannot be modified when the USRP RIO device is connected through Ethernet.
    NI-USRP 18.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  LabVIEW NXG and LabVIEW Communications System Design Suite support only 64-bit operating systems.
    Note  NI-USRP 18.1 does not support Windows Server non-R2 editions.
    Note  In 2016, NI-USRP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-USRP 18.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 18.1 to an unsupported OS. Additionally, after installing NI-USRP 18.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    NI-USRP 18.1 supports the following application software versions, including service packs. If you are using LabVIEW, you should install it before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    Device
    LabVIEW 2015 SP1, 2016, 2017, or 2018
    LabVIEW Communications System Design Suite 2.0 or 2.1
    LabVIEW NXG 2.1
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944√‡
    USRP-2950/2952/2953/2954√‡
    USRP-2945/2955à
    USRP-2974 √**
    † The USRP-2945/2955 is not supported in LabVIEW 2015 SP1.
    ‡ Support for the USRP RIO API and modifying the LV FPGA bitfile is only supported in LabVIEW Communications System Design Suite.
    ** NI-USRP 18.1 does not include support for the USRP-2974 in LabVIEW Communications System Design Suite 2.1.
    Note  NI-USRP is not supported in LabVIEW NXG 2.0 or earlier.
    NI-USRP and USRP RIO palette VIs and nodes are available in the following palette locations.
    API
    LabVIEW NXG or LabVIEW Communications System Design Suite 2.1
    NI-USRPFunctions»Instrument I/O»Instrument Drivers»NI-USRPHardware Interfaces»NI-USRPHardware Interfaces>>Wireless Design and Test>>NI-USRP
    USRP RIOFunctions»Instrument I/O»Instrument Drivers»USRP RIOHardware Interfaces»USRP RIOHardware Interfaces>>Wireless Design and Test>>USRP RIO
    NI-USRP examples, lessons, and sample projects are available in the following locations.
    Content Type
    Description
    Examples
    NI-USRP includes several example applications that serve as interactive tools, programming models, and building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality.
    Note  You can access additional examples from the Code Sharing Community at ni.com/usrp.
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP Host.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP RIO.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP.
    • From the Learning tab, select Examples»Hardware Input and Output»USRP RIO.
    LessonsNI-USRP includes lessons that guide you through the process of identifying and demodulating an FM signal with your device.N/AFrom the Learning tab, select Getting Started»Demodulating FM Signals with the NI... and choose a task to accomplish.From the Learning tab, select Getting Started»Demodulating FM Signals with the NI... and choose a task to accomplish.
    Sample ProjectsUSRP RIO includes several sample projects that serve as starting points to build a USRP RIO streaming application.From the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.From the Projects tab, choose the applicable sample project for your device and setup.From the Projects tab, select USRP RIO and choose the applicable sample project for your device and setup.
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation and online at ni.com/manuals. The documentation set is composed of the following documents.
    Document
    Format
    Description
    Location
    NI-USRP 18.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manuals
    NI-USRP ManualOnline HelpContains a complete programming reference for all NI-USRP nodes.Online at ni.com/manuals
    NI-USRP HelpHTML/Windows HelpThe primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI USRP
    • A complete reference for all NI-USRP programming functions and VIs
    Basic Elements (NI-USRP and NI-579x) ManualOnline HelpContains a complete programming reference for all Basic Elements nodes on the USRP RIO palette.Online at ni.com/manuals
    Getting started guide for your devicePrinted and PDFContains software and hardware installation, configuration, signal connection, and troubleshooting information for your device.Online at ni.com/manuals
    Specifications for your devicePDFLists technical specifications for your device.Online at ni.com/manuals
    Manual for your deviceOnline HelpContains information about supported hardware, including pinouts, block diagrams, and specifications.Online at ni.com/manuals
    To access the LabVIEW Communications System Design Suite 2.0 Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes the following information:
    • An introduction to LabVIEW Comms
    • Hardware device overviews
    • Information about how to get started with application development
    • A complete programming reference for all NI-USRP nodes
    LabVIEW NXG and LabVIEW Communications System Design Suite Help
    View context help by pressing and hovering over an object.
    Search for items using the search bar in the upper right corner of the window. You can also view context help for the search results.
    • is an alias for the following file folder location: (64-bit) Windows\system32
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\Shared\ExternalCompilerSupport\C\include
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib32\msvc
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Additional File Locations for Windows (64-bit)
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib64\msvc
    Installation InstructionsInstalling NI-USRP for LabVIEW or LabVIEW Communications System Design Suite 2.0
    You must be an Administrator to install NI software on your computer. Install application software support before installing NI-USRP.
    • Visit ni.com/info and enter the Info Code usrpdriver to access the download page for the latest NI-USRP software.
    • Download the NI-USRP driver software.
    • Follow the instructions in the installation prompts.
      Note: Windows users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Installing NI-USRP for LabVIEW NXG or LabVIEW Communications System Design Suite 2.1
    NI automates LabVIEW NXG and LabVIEW Communications System Design Suite installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-USRP 18.1.
    There are no changes in NI-USRP 18.1 from NI-USRP 18.0.
    There are no changes in NI-USRP 18.0 from NI-USRP 17.2.
    There are no changes in NI-USRP 17.2 from NI-USRP 17.1.
    The following items are changes in NI-USRP 17.1 from NI-USRP 17.0.
    ID
    Fixed Issue
    679121Fixed an issue that caused digital data values in the NI-USRP Simple Streaming with USRP-2945/2955 Sample Project to be scaled to half of the correct value.
    681935Fixed an issue that caused aliases to appear in the data path after the frequency shift occurred on the FPGA.
    The following items are changes in NI-USRP 17.0 from NI-USRP 16.1.
    ID
    Fixed Issue
    641880Fixed an issue that caused the RF frequency to be inaccurate due to LO sharing when using the USRP-2945/2955 and the USRP RIO sample project.
    624459Fixed an issue that caused the building of a bitfile to fail using DRAM in LabVIEW Communications 2.0 after installing NI-USRP.
    617872Fixed an issue that caused the streaming performance of USRP RIO devices to degrade when connected over PCIe and using NI-USRP API.
    The following items are changes in NI-USRP 16.1 from NI-USRP 16.0.
    ID
    Fixed Issue
    597196Fixed an issue that caused errors to appear when launching the NI-USRP Configuration Utility from LabVIEW Communications 2.0.
    494050Fixed an issue that caused the USRP-2950/2952/2953/2954 devices not to set the GPS time by default.
    © 2011–2018 National Instruments. All rights reserved.
    374760P-01
    GMT+8, 2026-4-17 10:54
