查看: 3616|回复: 0
[LabWindows] LabWindows/CVI 8.1 Full Win32Eng LabWindows/CVI8.1完整版下载
发表于 2020-12-8 22:59:44 | 显示全部楼层 |阅读模式
8.1完整:有EXE和ZIP版本,ZIP版本为现在的下载版本,但是视觉论坛未找到资源。仅提供EXE版本下载:
(MD5)
736213544d4956cba5999f343e64e940
ZIP版无资源
exe版
文件大小: 466199488 字节 (444.60 MB)
修改日期: 2006-11-22 01:37
MD5: b19cf5bd40c0ed2401427ca3d35c8d9d
SHA1: 300e26223761da4a70a89711bc582dc1b62798cc
SHA256: 9c20e6f7bbdfcf1730de2e58188be859c6a5591993ae95ce7de534f5357e86d8
CRC32: 4b6b3b74
百度和NI官方下载地址:
CVI8.1Full.txt (623 Bytes, 下载次数: 3, 售价: 15 圆)
LabWindows/CVI for Windows 2000/XP, Version 8.1Readme File
This file contains installation information, programming considerations, and changes that are too recent to be included in the LabWindows/CVI Help. Refer to the LabWindows/CVI Release Notes for more information about new features.
Minimum System Requirements
To run LabWindows/CVI 8.1, you must have the following items:
  • Personal computer using a Pentium iGHz or higher microprocessor
  • Windows 2000 Service Pack 3 or Windows XP
  • Minimum of 128 MB of RAM, 256 MB recommended
  • 200 MB free hard disk space
  • Microsoft-compatible mouse
Installing LabWindows/CVI
National Instruments recommends that you install the complete LabWindows/CVI 8.1 program to take full advantage of all LabWindows/CVI 8.1 functionality. If you choose to install with options, select the options you want and follow the on-screen directions. If necessary, you can run the setup program again to install or remove additional files.
Before Installation
  • If you install the LabWindows/CVI Real-Time Module and device drivers with LabWindows/CVI 8.1, you must install these products in the following order:
    • LabWindows/CVI 8.1
    • Device driver software from the NI Device Drivers CD set
    Do not install the device driver software when you are prompted to do so during the LabWindows/CVI 8.1 installation. You will be prompted to install the device driver software again during the LabWindows/CVI Real-Time Module installation.
  • When you install or activate LabWindows/CVI 8.1, your user account must have administrator privileges. When you run LabWindows/CVI for the first time after installation, your user account must have administrator privileges.
  • You must explicitly select the Win32 SDK feature of the LabWindows/CVI installer to install the complete Windows SDK from the LabWindows/CVI Full Development System (FDS). Some Windows SDK header and import library files are included when you install the LabWindows/CVI Base Package. The Windows SDK help file is available only with the LabWindows/CVI FDS.
  • The LabWindows/CVI installation includes the LabWindows/CVI 8.1 Run-Time Engine. This version overwrites previous versions of the run-time engine. After you install LabWindows/CVI 8.1, executables and DLLs created with previous versions of LabWindows/CVI automatically use the new LabWindows/CVI 8.1 Run-Time Engine.
  • If you uncheck the top-level LabWindows/CVI feature in the installer feature tree, the installer installs some components that you cannot then uninstall. Therefore, National Instruments recommends that you leave the top-level LabWindows/CVI feature checked.
  • The IVI Installer Creator and IVI Specific Driver Test Suite items are selected by default in the installer feature tree only if the IVI Compliance Package is installed. If the IVI Compliance Package is not installed, you can select these items, but you must then install the IVI Compliance Package from the NI Device Drivers CD set to use these features.
Running the Installation
If you already have a different version of LabWindows/CVI installed on your computer, be sure to install version 8.1 in a different directory or uninstall the other version before installing LabWindows/CVI 8.1.
Complete the following steps to install LabWindows/CVI 8.1:
  • Insert the LabWindows/CVI CD into the CD drive. If the CD does not run automatically, open Windows Explorer, right-click the CD drive icon, and select AutoPlay.
  • Select Install LabWindows/CVI on the National Instruments LabWindows/CVI screen.
  • LabWindows/CVI prompts you to enter your user information. Select one of the following options:
    If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. LabWindows/CVI automatically uses this serial number when you run the NI Activation Wizard.
Activating LabWindows/CVI
Complete the following steps to activate LabWindows/CVI 8.1.
  • Select the Automatically activate through a secure Internet connection option and click Next. Your computer must be connected to the Internet for this option to work. If you do not have Internet access on your computer, refer to the LabWindows/CVI Release Notes.
  • The serial number should be automatically entered for you. If not, enter the serial number found on your Certificate of Ownership card and click Next.
  • Fill in the necessary information and click Next.
  • Check the option if you would like to receive a confirmation email of your activation and click Next.
  • After a brief moment, you should receive a message indicating whether LabWindows/CVI has been activated or not. Enter or verify your serial number. Click Next.
  • When you successfully activate LabWindows/CVI, click Finish. LabWindows/CVI will then display a window indicating when this license will expire.
For more information about activation, refer to the LabWindows/CVI Release Notes.
After Installation
  • Installing LabWindows/CVI in a New Directory—If you installed driver or toolkit software for a previous version of LabWindows/CVI and you install LabWindows/CVI 8.1 in a new directory, you must uninstall and reinstall the LabWindows/CVI portion of the driver or toolkit software.
  • Setting the Compatibility Mode for Real-Time DLLs—When you create a DLL to run on a real-time target, you must use the Visual C/C++ compatibility mode. The Borland C/C++ compatibility mode is not supported for real-time DLLs.
  • Projects Built Using LabWindows/CVI Beta—If you created any projects using the LabWindows/CVI Beta, you must rebuild the project in LabWindows/CVI 8.1.
  • Using the LabWindows/CVI Conversion Wizard in Visual Studio 2005—Microsoft Visual Studio 2005 removed support for the single-threaded version of its C library. Therefore, you must configure your project's linker settings to ignore directives to use the single-threaded C library. In Visual Studio, select Project» Properties and expand the properties tree to the Configuration Properties»Linker»Input item. Add libc to the Ignore Specific Library option. Refer to the I Receive Linker Errors When Using LabWindows/CVI-Generated Static Libraries and Object Files in Microsoft Visual Studio 2005 KnowlegeBase article for more information.
  • Updating an Existing Distribution—The LabWindows/CVI distribution creation feature no longer provides the option to include .obj files for both compatible compilers. If you convert an existing distribution that has this option enabled, LabWindows/CVI includes the .obj files only for the current compatible compiler in the updated distribution.
  • Using the NI Instrument I/O Assistant—The Instrument I/O Assistant 2.0, which is included in the NI Device Drivers CD set packaged with LabWindows/CVI, generates LabWindows/CVI code that is not backward compatible with code that previous versions of the Instrument I/O Assistant generated. If you run code generated with the Instrument I/O Assistant 2.0 with an existing application, the code in that application might not compile.
  • Making Backup .uir Files—If you have been using LabWindows/CVI 7.1 or earlier, make backup copies of your .uir files. Once you save .uir files in LabWindows/CVI 8.1, the .uir files are no longer compatible with versions 7.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 8.1 in LabWindows/CVI 7.1 or earlier.
    You can save .uir files you create or load in LabWindows/CVI 8.1 in LabWindows/CVI 7.1 format. Select File»Save .uir As and specify LabWindows/CVI 7.1 User Interface (*.uir) for the Save as type option. If you save a user interface with features that were added in LabWindows/CVI 8.0 and later, those features are removed when you save the file in 7.1 format.
  • Using Microsoft Excel as an ActiveX Control—If you develop an application that uses Excel as an ActiveX control on a LabWindows/CVI user interface panel, make sure that a separate instance of Excel is not running simultaneously. Otherwise, programmatic calls to the Excel control might not work as expected after the separate Excel application terminates.
  • Navigating the Tools Library Topics in the LabWindows/CVI Help—If you click a link from a topic in the Tools Library section of the LabWindows/CVI Help or from the toolslib function panel help, you cannot use the Back button in the help viewer toolbar to return to the original topic.
  • Analysis Function Behavior Changes—The updated Advanced Analysis Library functions are backward compatible with the previous versions. However, the following function behavior has changed from LabWindows/CVI 7.1 to LabWindows/CVI 8.x:
      In LabWindows/CVI 7.1 and earlier, CxSVD has the following requirement: If numberOfRows (n) < numberOfColumns (m), you must allocate m*m*sizeof(ComplexNum) bytes of memory to the input matrix and the U orthogonal matrix. LabWindows/CVI 8.x no longer has this requirement.
    • CxTrace—CxTrace accepts only a square matrix. In LabWindows/CVI 7.1 and earlier, the function requires both the number of rows and the number of columns as input parameters. In LabWindows/CVI 8.x and later, matrixSize specifies both the number of rows and the number of columns. The numberOfColumns parameter in LabWindows/CVI 7.1 and earlier is a reserved parameter in LabWindows/CVI 8.x. This parameter is not referenced in the function.
© 1993–2006 National Instruments Corporation. All rights reserved.
National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. For a listing of the copyrights, conditions, and disclaimers regarding components used in USI (Xerces C++, ICU, and HDF5), refer to the USICopyrights.chm.
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:25
