查看: 3333|回复: 0
[RTE运行引擎] NI RFmx 2.5 Runtime Win64Eng NI Wireless Test Standard Software运行版RFMXRTEX64062018
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2021-2-26 22:32:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx
    WinEng
    2.5RTEX64
    文件大小: 520126189 字节 (496.03 MB)
    修改日期: 2018-07-03 17:49
    MD5: 464fc1856553c28d5cb408fd3ca27c8e(官方正确)
    SHA1: fb2da973fd68bbe9a0a1914c41d906214413e446
    SHA256: a532c917bc73f97dcdee36450bee4665f1a799a759b11dd206cd0c54455c87c2
    CRC32: ef705d8f
    RFmx2.5RTE64.txt (598 Bytes, 下载次数: 0, 售价: 5 圆)
    National Instruments Wireless Test Standard Software Readme
    June 2018
    Wireless Test Standard Software Readme Files
    For important information about your National Instruments Wireless Test Standard Software, refer to the following product-specific readme files:
    • NI-RFmx Measurement APIs
      • NI-RFmx SpecAn 2.5
      • NI-RFmx Noise Figure Runtime 2.5
      • NI-RFmx Demod 2.5
      • NI-RFmx WCDMA 2.5
      • NI-RFmx LTE 2.5
      • NI-RFmx GSM 2.5
      • NI-RFmx TD-SCDMA 2.5
      • NI-RFmx CDMA2k 2.5
      • NI-RFmx EV-DO 2.5
    • NI-RFSG Playback Library:
      • NI-RFSG Playback Library 2.5
    • NI-RFmx Waveform Creator:
      • NI-RFmx Waveform Creator 2.5
    • RF Toolkits:
      • NI LabVIEW Modulation Toolkit 18.0
      • NI WLAN Toolkit 17.5
      • NI Bluetooth Toolkit 17.0.1
      • NI FM-RDS Toolkit 1.0.1
      • NI GNSS Simulation Toolkit 3.0
    Choosing Software to Install
    The following product-specific summaries will help you decide which software you need to install:
    NI-RFmx SpecAn—This software installation provides support for Spectral Analyzers Measurement functions in LabVIEW, LabWindows/CVI, C, and .NET environments.
    NI-RFmx Noise Figure Runtime—This software installation provides development license support for applications that use the NI-RFmx Noise Figure API. The Noise Figure measurement requires license activation. To evaluate or activate the Noise Figure license, you must install the Noise Figure license, which is a separate installer from the NI-RFmx SpecAn installer. If you install the Noise Figure license but do not activate it, you will have 30 days from the first time you use the measurement to evaluate it.
    NI-RFmx Demod—This software installation provides support for Demodulation functions in LabVIEW, LabWindows/CVI, C, and .NET environments.
    NI-RFmx WCDMA—This software installation provides support for making WCDMA measurements in LabVIEW, C, and .NET environments.
    NI-RFmx LTE—This software installation provides support for making LTE measurements in LabVIEW, C, and .NET environments.
    NI-RFmx GSM—This software installation provides support for making GSM measurements in LabVIEW, C, and .NET environments.
    NI-RFmx TD-SCDMA—This software installation provides support for making TD-SCDMA measurements in LabVIEW, C, and .NET environments.
    NI-RFmx CDMA2k—This software installation provides support for making CDMA2k measurements in LabVIEW, C, and .NET environments.
    NI-RFmx EV-DO—This software installation provides support for making EV-DO measurements in LabVIEW, C, and .NET environments.
    NI-RFSG Playback Library—This software installation provides support for generating waveform files on RF Signal Generators in LabVIEW, C, and .NET environments.
    NI-RFmx Waveform Creator—This software installation provides support for creating waveform files for different RF standards.
    Modulation Toolkit for LabVIEW—This software installation provides additional modulation scheme software functionality for customers using NI RF vector signal generators, NI arbitrary waveform generators, NI RF vector signal analyzers, and NI high-speed digitizers.
    NI WLAN Toolkit—This software installation provides support for generating and measuring wireless local area network (WLAN) transceiver signals in LabVIEW, LabWindows/CVI and C environments.
    NI Bluetooth Toolkit—This software installation provides support for generating and measuring Bluetooth signals in LabVIEW, LabWindows/CVI and C environments.
    NI FM-RDS Toolkit—This software installation provides support for generating and measuring FM-RDS signals that conform to the UNITED STATES RBDS STANDARD,1998 specifications in LabVIEW, LabWindows/CVI and C environments.
    NI GNSS Simulation Toolkit—This software installation provides support for generating global navigation satellite system (GNSS) signals in LabVIEW, LabWindows/CVI and C environments.
    Caution  Before you install NI-RFmx products, ensure that you have uninstalled all related NI-RFmx 1.0 products. Refer to your product-specific readme file for more information about product-specific uninstallation instructions.
    This installation requires one of the following operating systems:
    Refer to your product-specific readme file for additional requirements.
    Uninstallation Instructions
    You can uninstall each NI product by selecting National Instruments Software in the Windows Add/Remove Programs application. Refer to your product-specific readme file for more information about product-specific uninstallation instructions.
    © 2015-2018 National Instruments. All rights reserved.
    376406E-01
    GMT+8, 2026-4-8 10:47
