查看: 3297|回复: 0
[RTE运行引擎] NI RFmx 19.0 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_19.0.0
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2021-2-26 22:45:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx
    WinEng
    19.0RTEX64
    文件大小: 743612416 字节 (709.16 MB)
    修改日期: 2019-07-17 14:32
    MD5: 0c2be0d2b776e3bf7a103ed7dee3dbfc(官方正确)
    SHA1: b8c198eddfb924f2f8aac36f9d8467699f5d4de8
    SHA256: 4e14bfe26f1214b857044d372fe00758dd54d3028d5caae1082da2bd5ac62dca
    CRC32: 2282813d
    RFmx19.0RTE64.txt (661 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (64-Bit) Readme
    June 2019
    This file contains important information about the RFmx Runtime (64-Bit), including system requirements, installation instructions, and a list of included products.
    Products Included in RFmx Runtime (64-Bit)
    RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (64-Bit)
    • RFmx Demod Runtime (64-Bit)
    • RFmx Noise Figure Runtime
    • RFmx Phase Noise Runtime
    • RFmx WLAN Runtime (64-Bit)
    • RFmx Bluetooth Runtime (64-Bit)
    • RFmx NR Runtime (64-Bit)
    • RFmx LTE Runtime (64-Bit)
    • RFmx WCDMA Runtime (64-Bit)
    • RFmx TD-SCDMA Runtime (64-Bit)
    • RFmx EV-DO Runtime (64-Bit)
    • RFmx CDMA2k Runtime (64-Bit)
    • RFmx GSM Runtime (64-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    System RequirementsRFmx Runtime (64-Bit) has the following requirements:
    • 4 GB RAM*
    RFmx Runtime (64-Bit) 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx Runtime (32-Bit) will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx Runtime (64-Bit) is available for download from NI Software Product Downloads.
    RFmx Drops Support for Windows 7 (64-Bit)and Windows Server 2008 R2 in 2021
    RFmx will drop support for Windows 7 (64-Bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377999A-01
    GMT+8, 2026-4-8 10:49
