查看: 3458|回复: 0
[RTE运行引擎] NI RFmx 19.1 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_19.1.0
发表于 2021-2-26 22:50:29 | 显示全部楼层 |阅读模式
RFmx
WinEng
19.1RTEX64
文件大小: 754800640 字节 (719.83 MB)
修改日期: 2019-10-18 18:09
MD5: 1cfc65dba4dad82df320ea27902ef609(官方正确)
SHA1: d6e79c02593a3a17f56d709bc02eb921799ad7f9
SHA256: 21ac26b5bc71470d5a2f68649a70920e85c3847d28613bd35333fef019f2fef5
CRC32: 93776fb1
RFmx19.1RTE64.txt (659 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx Runtime (64-Bit) Readme
October 2019
This file contains important information about the RFmx Runtime (64-Bit), including system requirements, installation instructions, and a list of included products.
Products Included in RFmx Runtime (64-Bit)
RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
Application Software
  • RFmx SpecAn Runtime (64-Bit)
  • RFmx Demod Runtime (64-Bit)
  • RFmx Noise Figure Runtime
  • RFmx Phase Noise Runtime
  • RFmx WLAN Runtime (64-Bit)
  • RFmx Bluetooth Runtime (64-Bit)
  • RFmx NR Runtime (64-Bit)
  • RFmx LTE Runtime (64-Bit)
  • RFmx WCDMA Runtime (64-Bit)
  • RFmx TD-SCDMA Runtime (64-Bit)
  • RFmx EV-DO Runtime (64-Bit)
  • RFmx CDMA2k Runtime (64-Bit)
  • RFmx GSM Runtime (64-Bit)
Drivers
  • NI-RFSG Playback Library Runtime
System RequirementsRFmx Runtime (64-Bit) has the following requirements:
  • 4 GB RAM*
RFmx Runtime (64-Bit) 19.1 supports the following 64-bit operating systems:
  • Windows 10/8.1/7 SP12
  • Windows Server 2012 R21
  • Windows Server 2008 R2 SP12
Note  In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx Runtime (32-Bit) will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 and Windows Server 2008 R2 in 2021 for information about future OS support.
RFmx Runtime (64-Bit) is available for download from NI Software Product Downloads.
RFmx Drops Support for Windows 7 (64-Bit)and Windows Server 2008 R2 in 2021
RFmx will drop support for Windows 7 (64-Bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
LabWindows/CVIcvi_lifecycle
© 2019 National Instruments. All rights reserved.
377999B-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:51
