查看: 2248|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Full Version x64-linux/aarch64-linux/armv7a-linux (32 bit) HALCON20.11.0.2改进版完整版 x64-Linux/aarch64-Linux/arm7a-linux 32位等系统
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2021-3-23 23:46:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-linux.tar.gz
    文件大小: 2324997585 字节 (2.17 GB)
    修改日期: 2021-03-03 22:42
    MD5: adbf9b928cbf8fd4afba9b7b25028b48
    SHA1: d5c75398f6f47d674f7699a0ab651a1c721eb2d1
    SHA256: c7c7be92f48a9cc2370bd01630bd429454327264015a9febc1e66dd78c523586
    CRC32: 488d7de5
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:4xok
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2026-4-18 15:11
