查看: 3543|回复: 6
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Full Version x64-linux/aarch64-linux/armv7a-linux(32bit) HALCON20.11.1.2稳定完整版
    3 小时前
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2021-3-24 23:06:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-linux.tar.gz
    文件大小: 2325539858 字节 (2.17 GB)
    修改日期: 2021-03-03 22:53
    MD5: 7ca135f857272c70eaf3bbc608413fa4
    SHA1: 388cc225403b65b8b5f366c8b7954c964c9761a8
    SHA256: ebf7dd81db2e3c3e035d03cd662490191ef97dd1a10369973a9dc3a724ba9f49
    CRC32: 9bb7ddbf
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    百度网盘下载地址:
    链接:
    提取码:0xlv
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
    连续签到: 2 天
    发表于 2021-6-25 16:19:21 | 显示全部楼层 来自:江苏省南京市 电信
  • 签到天数: 2 天
    发表于 2021-7-27 14:33:00 | 显示全部楼层 来自:江苏省苏州市 电信
    发表于 2021-10-6 13:47:19 | 显示全部楼层 来自:河南省郑州市 联通
  • 签到天数: 2 天
    连续签到: 2 天
    发表于 2021-10-8 11:52:54 | 显示全部楼层 来自:江苏省南京市 电信
    看看
  • 签到天数: 2 天
    连续签到: 2 天
    发表于 2026-1-28 10:54:32 | 显示全部楼层 来自:北京市 联通
  • 签到天数: 1 天
    发表于 2026-3-15 15:45:06 | 显示全部楼层 来自:辽宁省沈阳市 东北大学大学生城
    GMT+8, 2026-4-18 13:30
