查看: 2611|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite Spring 2019 Win32Eng 嵌入式控制和监控软件套件2019春季英文版ECMSS19.0
    1 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2021-10-27 14:44:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
    Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
    套件包含:
    LabVIEW专业版
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW MathScript模块
    LabVIEW高级信号处理工具包
    LabVIEW数字滤波器设计工具包
    视觉采集软件
    视觉开发模块
    LabWindows/CVI执行评测工具包
    LabWindows/CVI Real-Time模块
    LabWindows/CVI SQL工具包
    LabWindows/CVI完整版
    Measurement Studio企业版
    发布日期
    2019/5/15
    包含的版本
    2019
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言
    English
    校验和
    2019Spring
    32ENG
    文件大小: 24158674944 字节 (22.50 GB)
    修改日期: 2019-05-16 01:12
    MD5: 3ec8b34a07988b5c7f35ef2e88fcea4e(官方正确)
    SHA1: 7005e7647b8a420e0d75abfd3e947dfe11121341
    SHA256: 0df7ac0eed4d052e76d8265e60ea2f521e851a32973eba6b6ca1fe5482338dac
    CRC32: 9fc145e7
    2019SpringEng.txt (685 Bytes, 下载次数: 0, 售价: 40 圆)
    NI Embedded Control and Monitoring Software Suite Spring 2019 Readme
    June 2019
    This file contains important information about the NI Embedded Control and Monitoring Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
    Products Included on the NI Embedded Control and Monitoring Software Suite Media
    NI Embedded Control and Monitoring Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Installation InstructionsInstalling and Activating the NI Embedded Control and Monitoring Software Suite
    NI automates the NI Embedded Control and Monitoring Software Suite installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Complete the following steps to install products using the NI Embedded Control and Monitoring Software Suite media.
    • Insert the NI Embedded Control and Monitoring Software Suite installation USB.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the NI Embedded Control and Monitoring Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI Embedded Control and Monitoring Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Back to Top
    The following products are included on the NI Embedded Control and Monitoring Software Suite media.
    Application Software
    • LabVIEW Advanced Signal Processing Toolkit
    • LabVIEW Desktop Execution Trace Toolkit
    • LabVIEW FPGA Compile Farm Toolkit
    • LabVIEW FPGA Module
    • LabVIEW MathScript Module
    • LabVIEW OPC UA Toolkit
    • LabVIEW Professional Development System
    • LabVIEW Real-Time Module
    • LabVIEW Unit Test Framework Toolkit
    • LabVIEW VI Analyzer Toolkit
    • JKI VI Package Manager
    • LabVIEW FPGA ISE Compilation Tool 14.7
    • LabVIEW FPGA Vivado Compilation Tool 2017.2
    • NI Vision Development Module
    Driver Software
    • FlexRIO with Integrated I/O
    • FlexRIO with Modular I/O
    • FPGA Interface C API
    • NI CompactRIO
    • NI R Series Multifunction RIO
    • NI-DAQmx
    • NI-IMAQ
    • NI-IMAQdx
    • NI-IMAQ I/O
    • NI-Industrial Communications for EtherNet/IP
    • NI-Serial
    • NI-Sync
    • NI-VISA
    • NI-XNET
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit.
    Back to Top
    Back to Top
    Back to Top
    NI Embedded Control and Monitoring Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2014–2019 National Instruments. All rights reserved.
    377939A-01
    GMT+8, 2026-4-8 10:01
