查看: 2755|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite Fall 2020 Win32Eng 嵌入式控制和监控软件套件2020秋季英文版ECMSS20.6
发表于 2021-10-27 15:56:01 | 显示全部楼层 |阅读模式
Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
套件包含:
LabVIEW专业版
LabVIEW Real-Time模块
LabVIEW FPGA模块
LabVIEW MathScript模块
LabVIEW高级信号处理工具包
LabVIEW数字滤波器设计工具包
视觉采集软件
视觉开发模块
LabWindows/CVI执行评测工具包
LabWindows/CVI Real-Time模块
LabWindows/CVI SQL工具包
LabWindows/CVI完整版
Measurement Studio企业版
发布日期
2021/8
包含的版本
Fall 2020
受支持的操作系统
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
语言
English
校验和
2020Fall
32ENG
文件大小: 34195081216 字节 (31.85 GB)
修改日期: 2021-01-07 08:08
MD5: d3d6e18ded104dedd810cf55d9bbe671(官方正确)
SHA1: de97d6c42125a3700c86adfc833aa06cd09db090
SHA256: d4b09697eccdecf4e32c44495c95880e4a70660e8c970c8a8f4fe3ceee6792e6
CRC32: ae904207
2020FallEng.txt (683 Bytes, 下载次数: 0, 售价: 40 圆)
NI Embedded Control and Monitoring Software Suite Fall 2020 Readme
January 2021
This file contains important information about the NI Embedded Control and Monitoring Software Suite, including installation instructions, compatibility issues, and a list of products included on the media.
Products Included on the NI Embedded Control and Monitoring Software Suite Media
NI Embedded Control and Monitoring Software Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
Installation InstructionsInstalling and Activating the NI Embedded Control and Monitoring Software Suite
NI installs the NI Embedded Control and Monitoring Software Suite using NI Package Manager. If you do not already have NI software installed, the NI Embedded Control and Monitoring Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
  • Use the serial number that is included with your software to activate the NI Embedded Control and Monitoring Software Suite. For more information on the NI Embedded Control and Monitoring Software Suite activation, refer to NI Software Activation.
Complete the following steps to install products using the NI Embedded Control and Monitoring Software Suite media.
  • Insert the NI Embedded Control and Monitoring Software Suite installation media.
Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
Installing LabVIEW Add-Ons
Installing LabVIEW add-ons, such as modules and toolkits, from the NI Embedded Control and Monitoring Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the NI Embedded Control and Monitoring Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
Back to Top
The following products are included on the NI Embedded Control and Monitoring Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
Application Software
Version
Bitness
LabVIEW (32-bit) Chinese2020 SP132-bit
LabVIEW (32-bit) English2020 SP132-bit
LabVIEW (32-bit) French2020 SP132-bit
LabVIEW (32-bit) German2020 SP132-bit
LabVIEW (32-bit) Japanese2020 SP132-bit
LabVIEW (32-bit) Korean2020 SP132-bit
LabVIEW (64-bit) English2020 SP164-bit
LabVIEW NXG5.1.064-bit
Add-Ons
Version
Bitness
JKI VI Package Manager202032-bit and 64-bit
LabVIEW Advanced Signal Processing Toolkit (32-bit)202032-bit
LabVIEW Advanced Signal Processing Toolkit (64-bit)202064-bit
LabVIEW Desktop Execution Trace Toolkit202032-bit and 64-bit
LabVIEW Digital Filter Design Toolkit (32-bit)202032-bit
LabVIEW Digital Filter Design Toolkit (64-bit)202064-bit
LabVIEW FPGA Compilation Tool for ISE 14.7202032-bit and 64-bit
LabVIEW FPGA Compilation Tool for Vivado 2019.1202064-bit
LabVIEW FPGA Compile Farm Toolkit202032-bit and 64-bit
LabVIEW FPGA Module (32-bit) Chinese2020 f132-bit
LabVIEW FPGA Module (32-bit) English2020 f132-bit
LabVIEW FPGA Module (32-bit) Japanese2020 f132-bit
LabVIEW MathScript Module (32-bit) Chinese202032-bit
LabVIEW MathScript Module (32-bit) English202032-bit
LabVIEW MathScript Module (32-bit) French202032-bit
LabVIEW MathScript Module (32-bit) German202032-bit
LabVIEW MathScript Module (32-bit) Japanese202032-bit
LabVIEW MathScript Module (32-bit) Korean202032-bit
LabVIEW NXG FPGA Module5.1.064-bit
LabVIEW NXG Real-Time Module5.1.064-bit
LabVIEW Real-Time Module Chinese202032-bit
LabVIEW Real-Time Module English202032-bit
LabVIEW Real-Time Module Japanese202032-bit
LabVIEW Unit Test Framework Toolkit (32-bit)202032-bit
LabVIEW Unit Test Framework Toolkit (64-bit)202064-bit
LabVIEW VI Analyzer Toolkit (32-bit)202032-bit
LabVIEW VI Analyzer Toolkit (64-bit)202064-bit
NI LabVIEW OPC UA Toolkit (32-bit) Chinese202032-bit
NI LabVIEW OPC UA Toolkit (32-bit) English202032-bit
NI LabVIEW OPC UA Toolkit (32-bit) Japanese202032-bit
NI LabVIEW OPC UA Toolkit (64-bit) English202064-bit
Vision Development Module2020 SP132-bit and 64-bit
Driver Software
Version
Bitness
FPGA Interface C API20.0.032-bit and 64-bit
FlexRIO with Integrated I/O20.6.032-bit and 64-bit
FlexRIO with Modular I/O20.6.032-bit and 64-bit
NI CompactRIO20.5.032-bit and 64-bit
NI R Series Multifunction RIO20.0.032-bit and 64-bit
NI-DAQmx20.1.032-bit and 64-bit
NI-IMAQ20.6.032-bit and 64-bit
NI-IMAQ I/O20.6.032-bit and 64-bit
NI-IMAQdx20.6.032-bit and 64-bit
NI-Industrial Communications for EtherNet/IP20.0.032-bit and 64-bit
NI-Serial20.0.032-bit and 64-bit
NI-Sync20.1.032-bit and 64-bit
NI-VISA20.0.032-bit and 64-bit
NI-XNET20.5.032-bit and 64-bit
Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit.
To compare the products included in NI Software Suites, including the NI Embedded Control and Monitoring Software Suite, refer to Compare NI Software Suites.
Back to Top
Back to Top
Back to Top
NI Embedded Control and Monitoring Software Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
© 2014–2021 National Instruments Corporation. All rights reserved.
377939D-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 13:27
