查看: 2529|回复: 0
[NI驱动程序] NI RF Signal Generators 21.0.1 x64Win10 32/64bitEng NI RF信号发生器NI-RFSG21.0.1
    昨天 11:23
  • 签到天数: 3840 天
    连续签到: 33 天
    发表于 2021-12-17 18:03:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    Win64Eng
    21.0.1
    文件大小: 5100503040 字节 (4.75 GB)
    修改日期: 2021-10-09 00:18
    MD5: 2d4a24e3c41fdd64e9d30e1b4639464e(官方正确)
    SHA1: e1b92aea5e424b1b5df4f48db5d1396c6a3d068e
    SHA256: e72f0732e1929619c07de59760aeef4a75cf2251d47c7b427a23218289f894cb
    CRC32: f6163825
    RFSG21.0.1.txt (601 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 21.0 Readme
    August 2021
    This file contains installation instructions and compatibility information for NI-RFSG.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 21.0 includes the following new features:
    • Support for LabVIEW 2021
    • Support for Linux
    NI-RFSG 20.7 includes the following new features:
    • Added new InstrumentStudio-based NI-RFSG Soft Front Panel with the ability to debug and monitor applications for the PXIe-5840/5841 and PXIe-5830/5831/5832.
    • Added the ability to load waveforms from TDMS files into the device memory for the PXIe-5840/5841 and PXIe-5830/5831/5832.
    • Added the ability to configure certain properties for a specific waveform on the PXIe-5840/5841 and PXIe-5830/5831/5832.
    NI-RFSG 20.5.4 includes a bug fix to address a .NET initialization issue for PXIe-5830/1/2 devices when using RFmx
    NI-RFSG 20.5 includes the following new features:
    • Support for the PXIe-5832
    • Support for selected ports in configuration lists on the PXIe-5830/5831/5832.
    NI-RFSG 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for RF list mode on the PXIe-5841 with PXIe-5655
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductHardware ModelNI-RFSGNI-RFSG Soft Front Panel (Classic)NI-RFSG Soft Front Panel (InstrumentStudio)
    RF Signal UpconverterPXI-5610
    I/Q ModulatorPXIe-5611
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5832
    PXIe-5840
    PXIe-5841
    PXIe-5841 with
    PXIe-5655 RF Analog Signal Generator
    RF Analog Signal GeneratorPXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with
    PXIe-5696 Amplitude Extender
    Vector Signal GeneratorPXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    Note  Some hardware products are not supported by the NI-DAQmx-based runtime. Visit ni.com/info and enter the Info Code rfsgdevices for more information about which NI-RFSG devices are supported by the NI-DAQmx-based runtime.
    • 4 GB RAM*
    Note  NI-RFSG 21.0 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 21.0.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2018 SP1, 2019, 2020, or 2021
    LabWindows/CVI2017 to current
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    DocumentFormatDescription
    • Hardware device overviews
    NI-RFSG ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2004–2021 National Instruments Corporation. All rights reserved.
    374769AF-01
    GMT+8, 2026-3-30 03:17
