查看: 2834|回复: 0
[NI软件套件] NI Semiconductor Test System Development Software 21.0.0 x64Win10 64bitEng NI-STS半导体测试系统开发软件21.0.0
    1 小时前
  • 签到天数: 3858 天
    连续签到: 51 天
    发表于 2022-1-20 17:19:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    半导体测试系统开发软件
    半导体测试系统软件可帮助您开发、执行、调试和部署半导体测试系统软件(STS)应用。
    半导体测试系统开发软件为STS提供了一套测试管理和代码模块开发工具。使用该软件,您可以定义引脚图、配置数字pattern、创建测试代码模块、自定义操作界面、优化并行测试效率(PTE)、以标准测试数据格式(STDF)报告数据,以及维护和校准测试系统。
    Win10x64Eng
    21.0.0
    文件大小: 27815444480 字节 (25.91 GB)
    修改日期: 2022-01-12 05:31
    MD5: b216b56b067e4ad5dbd0aeb65b766dab(官方正确)
    SHA1: b3d7e1fc38939b12e1db43e341778198157d7f29
    SHA256: 5ad071a7cd2eceb5aa1f774e6a4c20a588d175bcaf696c66ebf7acf251131a05
    CRC32: 8829dfaa
    NI-STS21.0.txt (620 Bytes, 下载次数: 0, 售价: 30 圆)
    STS Development Software 21.0 Readme
    October 2021
    This file contains important information about STS Development Software 21.0, including installation instructions and new features. STS Development Software is a collection of NI software for developing, executing, and debugging test programs on a non-STS computer.
    Included Components
    Supported Controllers and Operating Systems
    Installation Considerations
    What's Changed
    Known Issues and Bug Fixes
    Included Components
    STS Development Software 21.0 includes the following major components:
    • STS Development Software 21.0
    • TestStand 2020 f1
    • NI TestStand Semiconductor Module™ 2021 Q4 (TSM)
    • LabVIEW 2020 SP1 f1
    • LabVIEW 2020 SP1 f1 Run-Time Engine
    • LabVIEW 2021 Run-Time Engine
    • NI-Digital Pattern Driver 21.0.0
    • NI-DCPower 21.3.0
    • NI-SCOPE 20.7.0
    • NI-Sync 20.0.0
    • NI-RFPM 20.6.1
    • NI RFmx 21.3.0
    • NI-RFSA 21.0.1
    • NI-RFSG 21.0.1
    • STS Auxiliary Mixed Signal Tools 20.0.0
    • STS Auxiliary RF Tools 21.0.0
    • TSM RF Steps 21.0.0
    • STS Handler and Prober Drivers 20.0.0
    • STS Maintenance Software 21.0.0
    STS Development Software 21.0 has the following requirements:
    • 2.3 GHz 8-Core Intel Xeon processor (or equivalent)
    • At least 100 GB of disk space
    • At least 12 GB RAM (NI recommends 24 GB RAM)
    STS Development Software 21.0 supports the following controllers:
    • PXIe-8880
    • PXIe-8881
    STS Development Software 21.0 supports the following operating system:
    • Windows 10 IoT Enterprise LTSC 2019 (64-bit)
    Note  STS Development Software 21.0 does not support certain versions of Windows 10. Refer to Editions of Windows 10 Supported by NI Software for more information.
    NI offers two installation paths for STS software—installing STS Software through the STS Version Selector and installing STS Development Software through NI Package Manager.
    NI recommends installing STS Development Software through NI Package Manager if you are using a non-STS computer and do not need to switch among versions of STS software. Use STS Development Software 21.0 to develop, run, and debug STS test programs on a non-STS computer without access to NI instruments. When test program development is complete, transfer the test program to an STS from which you will deploy the test program into a production environment.
    Note  If you install STS Development Software 21.0 through NI Package Manager, you cannot downgrade your software version. NI does not recommend updating components of STS Development Software on the non-STS computer. The set of software you use to develop an STS test program must match the set of software on the STS from which you will deploy the test program.
    If you need to switch among versions of STS software on a non-STS computer, install through the STS Version Selector. If you used a mechanism other than the STS Version Selector 19.0.0 or later to install any NI software on the STS or non-STS computer, you must reimage the computer before installing the latest version of the STS Version Selector. Refer to the STS Software 21.0 Readme for more information about installing STS Software through the STS Version Selector.
    Download the STS Development Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate STS Development Software. For more information on STS Development Software activation, refer to NI Software Activation.
    • You must restart the computer after you activate an STS software version.
    If you are using NI .NET Class Libraries, .NET Framework 4.0 (minimum) is required. The NI .NET Class Libraries can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    For information about versions of the .NET Framework and the drivers each supports, refer to NI .NET Support.
    Spectre and Meltdown
    Refer to Meltdown and Spectre - Processor Speculative Execution Vulnerabilities (Windows) for more information about addressing Spectre and Meltdown issues.
    STS Software 21.0 adds the following major new features:
    New Hardware Support
    • PXIe-6569—Added support for the PXIe-6569 high-speed serial instrument.
    • PXIe-4137 (40 W) Source Measure Unit (SMU)—Added support for the high power (40W/10 A, pulsed) SMU version of the PXIe-4137.
    • PXIe-4190—Added support for the PXIe-4190 LCR. Support applies only to STS models with the CX configuration.
    New and Improved Test Program Development and Debugging
    • Added support for extended continuity test frequency range up to 21.5 GHz on the PXIe-5831 + PXIe-5841 with STS-5531 as an STS RF subsystem.
    • RF Steps added the following new steps and examples:
      • The WLAN Test - 8 GHz example sequence demonstrates how to perform error vector magnitude (EVM) measurements with noise compensation on the PXIe-5831 + PXIe-5841 with STS-5531 as an STS RF subsystem.
      • The S-Parameter Test - 6 GHz example sequence demonstrates how to publish the S-parameter magnitude only or S-parameter magnitude and phase.
      • The NR test example sequence demonstrates how to use the TSM RF Steps to implement NR TXP measurements.
    • RF Steps adds the following new measurements:
      • NR ACP measurements—Perform customized definition of measurement offset and integration bandwidth.
      • WLAN OFDM ModAcc measurements—Support vector averaging type to reduce noise floor of a signal while retaining the signal spectrum.
      • WLAN measurements—Support the IEEE 802.11be standard.
    • The STS Auxiliary RF Tools provides the enhanced Golden Units Calibration Tool for calculating and updating the correlation offsets based on golden DUT, or known good unit, measurements. The enhanced features support multiple sites. You can calibrate golden units, retry failed golden units, check the calibration interval, and specify the minimum pass number of the golden units per site.
    • The STS Auxiliary RF Tools provides the enhanced STS RF Switch Control Panel plug-in for InstrumentStudio, which allows you to configure and connect the RF subsystem internal switches and paths to perform RF measurements. The enhanced features expand support on the PXIe-5831 + PXIe-5841 with STS-5531 as an STS RF subsystem, extend the measurement frequency up to 21.5 GHz, and support the PXIe-5841 with STS-5534 as an STS RF subsystem.
    What's Changed
    STS Development Software 21.0 includes updates to the following major components.
    Note  This is not an exhaustive list of updated products in STS Development Software.
    Previous Version
    Current Version
    LabVIEW 2020 SP1 Run-Time EngineLabVIEW 2021 Run-Time Engine
    STS Maintenance Software 20.1.0STS Maintenance Software 21.0.0
    NI-Digital Pattern Driver 20.6.2NI-Digital Pattern Driver 21.0.0
    NI-DCPower 20.7.0NI-DCPower 21.3.0
    NI RFmx 20.7.1NI RFmx 21.3.0
    NI-RFSA 20.7.1NI-RFSA 21.0.1
    NI-RFSG 20.7.1NI-RFSG 21.0.1
    STS Development Software 21.0 Auxiliary Components
    STS Development Software 21.0 changes the following auxiliary components.
    Note  This is not an exhaustive list of changed auxiliary components in STS Development Software.
    Previous Version
    Renamed/Current Version
    STS Auxiliary RF Tools 20.1.0STS Auxiliary RF Tools 21.0.0
    TSM RF Steps 20.1.0TSM RF Steps 21.0.0
    You can access the known issues list and bug fixes list online. Refer to the private NI STS Technical Support Community, located at https://forums.ni.com/t5/NI-STS-Technical-Support/gp-p/5300, for an up-to-date list of known issues and bug fixes in STS Development Software 21.0. You can work directly with NI Services personnel contracted on your project to request to be added to the NI STS Technical Support Community.
    Select Start»National Instruments»STS Help to access the STS Help, which includes information about STS Development Software 21.0.
    If you open help files directly from the \National Instruments\STS\Documentation\Help directory, NI recommends that you open STSDocumentation.chm first because this file is a collection of help files and provides a complete table of contents and index.
    STS manuals are available as PDFs in the \National Instruments\STS\Documentation\Manuals directory. You must have Adobe Acrobat Reader installed to view the PDFs.
    STS Development Software no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2017–2021 National Instruments Corporation. All rights reserved.
    378143F-01
    GMT+8, 2026-4-16 09:14
