查看: 1865|回复: 0
[NI软件产品] NI RFmx WLAN 21.8.1 Full x64Win10 64bitENG RFmx无线局域网络21.8.1完整版
    昨天 08:07
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2022-6-20 18:16:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:
    2022/4/30
    包含的版本:
    21.8.1完整版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 1106112512 字节 (1.03 GB)
    修改日期: 2022-04-30 01:45
    MD5: 522749d94985aaf80208bbdbb209d653(官方正确)
    SHA1: 85cd751bc29ebf5616312804c171e0812011d43e
    SHA256: 9224c3cbb513bc30717041685a06f4ab76e922719d34639ad5470a41a56804f4
    CRC32: 54b6aa62
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN21.8.1.txt (547 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx WLAN 21.8.1 Readme
    April 2022
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11be MU PPDU in SISO and MIMO configurations
    • Support for OFDM physical layer of 802.11n, 802.11ac, and 802.11ax in MIMO configuration
    • Support for OFDM physical layer of 802.11ax SU, MU, Extended Range SU, and trigger-based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D8.0.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 21.8 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.5
    • Support for auto level in MIMO OFDMModAcc measurement
    • Support for skipping decoding of header fields for 802.11be standard
    • Support for auto detection of phase rotation parameters for 802.11be 320 MHz
    • Support for 802.11be gated power measurement
    • Support for Wiener interpolation filter for 802.11ax and 802.11be standards
    • Support for 802.11be auto detection of Standard property
    • Support for phase noise PSD measurement
    • Support for burst start time result in OFDMModAcc measurement
    RFmx WLAN 21.5 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.3
    • Support for EVM noise compensation for MU OFDMA and trigger-based PPDU types
    RFmx WLAN 21.3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.1
      • Trigger-based PPDU MIMO
      • OFDMA with RU Aggregation
      • Additional phase rotation option for pre-EHT modulated fields of 11be 320 MHz
      • MCS 14 (DCM + DUP) and MCS 15 (DCM)
    • Support for 802.11be data bit decoding
    • Support for 802.11be header decoded bits trace
    • Support for Vector Averaging
    • Support for Auto Level for OFDMModAcc measurement
    • Support for FEC coding type and DCM enabled results
    • Support for group delay trace
    • Support for packet extension duration result
    • Support for min-max statistics for certain results
    • Support for Analysis-Only mode for MIMO waveforms
    • Support to save and load MIMO configurations
    RFmx WLAN 21.8.1 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 21.8.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 21.8.1 to an unsupported OS. Additionally, after installing RFmx WLAN 21.8.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®;, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    Select Start » National Instruments » RFmx WLAN » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN » RFmx WLAN Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 21.8.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    The following is the behavior change in RFmx WLAN 20.6 from RFmx WLAN 20.0.
    • Noise calibration performed by OFDMModAcc EVM on PXIe-5840 and PXIe-5644/5645/5646 using earlier versions of RFmx is no longer valid. Noise calibration should be re-run before performing noise compensation.
    377888L-01
    GMT+8, 2026-4-9 00:55
