查看: 1852|回复: 0
[NI软件产品] NI Pulsed RF Measurement Library 1.0.1 x64Win10 32/64bitEng NI脉冲射频测量库1.0.1
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-11-23 15:00:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Pulsed RF Measurement Library脉冲射频测量库
    脉冲射频测量库可对电子扫描阵列系统中使用的元件进行脉冲射频测量。
    脉冲射频测量库是一个软件附加软件,可以与PXI硬件和NI软件一起使用,对功率放大器(PA)、发射接收模块(TRM)等进行射频测量。利用该软件,您可以执行脉冲设计和稳定性、2端口S参数和功率附加效率的测量,其可用于PA和TRM的设计验证、特性分析和生产测试。脉冲射频测量库包括配置和测量功能以及编程实例,可作为构建您的自动测试应用程序的编程模板。附带VI参考指南还提供了系统的描述和第三方硬件组件的建议,如耦合器、开关、线缆、适配器和校准套件。
    发布日期:2022/8/1
    包含的版本:1.0.1完整版
    文件大小: 8008058880 字节 (7.46 GB)
    修改日期: 2022-08-01 17:00
    MD5: 2f6ba283e971002ac00bdb7976dc43f4
    SHA1: baa04e9431865137166e59addd694af754b148e4
    SHA256: b3b62a3edfe62b2486ef6b684a92d3e6d7afb25f70b9877ad78feca4e1a64646
    SHA512: 0e703d220f6b90e0f96bb3db22e4e424008e4cb1c955172eb5e8a35291de2461ae31113802c8747fdff107b1797c035f58ac52e6b36224246418bba472b2def6
    请注册登录视觉论坛,购买附件后查看下载地址
    Pulsed RF Measurement Library1.0.1.txt (653 Bytes, 下载次数: 0, 售价: 20 圆)
    Pulsed RF Measurement Library 1.0 Readme
    September 2021
    This file contains important information about the Pulsed RF Measurement Library, including system requirements, and installation instructions.
    Included Components
    Included Components
    Accessing the VIs
    The Pulsed RF Measurement Library is a component of the Electronically Scanned Array Characterization Reference Architecture that includes configuration and measurement functions for S-parameter, pulse stability, pulse profile, and power-added efficiency (PAE) measurements. The Pulsed RF Measurement Library also contains interactive panels for benchtop characterization and programming examples that serve as a template for building automated applications for testing power amplifiers and transmit-receive modules.
    Included Components
    The Pulsed RF Measurement Library includes the following major components:
    • A software library of configuration and measurement VIs
    • Interactive examples that enable benchtop characterization of DUTs
    • Programming examples that serve as a template for building automated test applications
    The Pulsed RF Measurement Library 1.0 has the following requirements:
    • Xeon quad-core processor
    • At least 512 GB of disk space
    • At least 16 GB/s controller bandwidth
    • 8 GB RAM
    • 64-bit version of Windows 10 (version 1903)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2019 SP1 and LabVIEW 2020 SP1.
    The Pulsed RF Measurement Library 1.0 requires the following software versions.
    Software
    Versions Supported by Pulsed RF Measurement Library
    LabVIEW2019 SP1, 2020 SP1
    Download the Pulsed RF Measurement Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate the Pulsed RF Measurement Library. For more information on activating the Pulsed RF Measurement Library, refer to Activating a Product.
    Accessing the VIs
    Pulsed RF Measurement Library VIs are available from the \vi.lib\addons\PRFMsc folder directory.
    For information on supported hardware, refer to the Hardware Overview section of the Electronically Scanned Array Characterization Reference Architecture User Manual.
    Refer to the Electronically Scanned Array Characterization Reference Architecture User Manual, accessible from \PRFM Test Software directory, for information about the Pulsed RF Measurement Library.
    Programming examples for the Pulsed RF Measurement Library are located in the labview\examples\PRFMsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Interactive panels for the Pulsed RF Measurement Library are located in the \PRFM Test Software directory.
    © 2021 National Instruments Corporation. All rights reserved.
    378550A-01
    GMT+8, 2026-4-16 07:36
