查看: 1889|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2022 Q4 Win11 64bitENG RFmx蜂窝测试TD-SCDMA22.8
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-11-25 09:52:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版/运行版,版本号22.8.0
    64位完整版校验和:
    文件大小: 1109104640 字节 (1.03 GB)
    修改日期: 2022-10-13 09:53
    MD5: b8f3b43aadc91a59114db944f6232649
    SHA1: 31730c9391e76336d624adadce862034c4e3a829
    SHA256: 04bd1feea615189e5295c62a8f059f5b5f12122963850ba9ae6502d3048712f8
    CRC32: c1ca8f59
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx TD-SCDMA 2022Q4Full.txt (552 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 610105344 字节 (581.84 MB)
    MD5: 2c4878e04a29436aa5b6cf933edf7106
    SHA1: 147f0e13d27f63467329cdb0b01393c39e5f534e
    SHA256: 68f2d64c244edc4509ba1120c43f481040ff54950d1e38c01dcfc820126dfa9c
    CRC32: ced74c4c
    RFmx TD-SCDMA 2022Q4RTE.txt (576 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 2022 Q4 Readme
    October 2022
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2022 Q3 includes the following new feature:
    RFmx TD-SCDMA 21.3 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 supports the following 64-bit operating systems:
    Note NI-USRP no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2026-4-16 07:35
