查看: 2085|回复: 0
[NI软件产品] NI RFmx Waveform Creator 2022 Q4 Win11 32/64bitENG RFmx波形创造器22.8
    1 小时前
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2022-11-25 09:59:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    文件大小: 1063804928 字节 (1014.52 MB)
    修改日期: 2022-10-13 09:53
    MD5: 0f7dabd9d4741fa41346459a01d16f93
    SHA1: 14e7cf7c6cd872333e761627579656b6b4707de6
    SHA256: 8397c909a4a0cabdcf8ac318cd74e6f3260a63f67f7832b87efc0b5d5737f5fe
    CRC32: 135addc3
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx Waveform Creator 2022Q4.txt (582 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Waveform Creator 2022 Q4 Readme
    October 2022
    This file contains important information about the RFmx Waveform Creator, including system requirements, and installation instructions.
    • RFmx Waveform Creator Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Waveform Creator Manuals: New features, behavior changes, and other documentation
    RFmx Waveform Creator provides a unified interface for creating and generating waveforms for multiple wireless standards. You can create unencrypted, unlocked IQ waveform files for playback on NI PXI RF instrumentation. Supported standards include 5G NR, LTE/LTE-Advanced, W-CDMA/HSPA+, GSM/EDGE+, TD-SCDMA, and more.
    RFmx Waveform Creator 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Updated 802.11be standard support to comply with IEEE P802.11be/D2.1.1 specification
    • Support for returning trigger frame parameters used to generate TB PPDU with payload settings for 11ax and 11be
    • Support for Channel Coding for DL 1024QAM for Frequency Range 1 in NR
    • Support for 1024QAM for DL FRCs in NR as per 3GPP Release 17 (June-2022)
    • Support for UL FRC Table A.10 for Frequency Range 2 in NR as per 3GPP Release 17 (June-2022)
    RFmx Waveform Creator 2022 Q3 includes the following new features:
    • Updated 802.11be standard support to comply with IEEE P802.11be/D2.0 specification
    • Support for per chain cyclic shift diversity for WLAN OFDM MIMO standards
    • Support for generation APIs for WLAN standard
    • Support for configuration of multiple shared channels in NR downlink and uplink
    • Support for 256QAM in NR FRCs as per 3GPP Release 17 (March-2022)
    • Support for 1024 QAM modulation type in Downlink Test Models TM2b and TM3.1b as per 3GPP Release 17 (March-2022)
    RFmx Waveform Creator 21.8 includes the following new features:
    • Support for Enhanced Trigger Frame Generation for WLAN 802.11be standard
    • Support for 3GPP NR Release 17 (December 2021 Release)
    • Support for configurable Cell ID in Downlink Test Models
    RFmx Waveform Creator has the following requirements:
    RFmx Waveform Creator 2022 Q4 supports the following 64-bit operating systems:
    Note    RFmx Waveform Creator no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx Waveform Creator supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Waveform Creator. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Waveform Creator (64-bit only)
    LabVIEW2019 SP1, 2020 SP1, 2021, 2022 Q3
    • NI-RFSG 14.5 or later
    • NI-RFSG 20.7 or later (for MIMO configurations with PXIe-5830/5831/5832 in RFmx Waveform Creator for WLAN)
    If you are using the RFmx Waveform Creator .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Waveform Creator .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Waveform Creator installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Waveform Creator. For more information on RFmx Waveform Creator activation, refer to National Instruments Software Activation.
    Select Start » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator.
    Documentation for RFmx Waveform Creator is located at Start » National Instruments » RFmx Waveform Creator Documentation.
    You can access all the installed RFmx Waveform Creator examples at Start » National Instruments » RFmx Waveform Creator Examples.
    The following items are the behavior changes in RFmx Waveform Creator 2022 Q3 from RFmx Waveform Creator 21.8.2.
    • Default value of WLAN Oversampling Ratio control changed to 1.25.
    The following items are the behavior changes in RFmx Waveform Creator 21.8 from RFmx Waveform Creator 21.5.
    • If there are multiple Tx antenna streams, the NR SSB and PDCCH are now mapped on all the antenna streams instead of just the first antenna stream.
    • Dropped support for PDSCH Present in SSB Resource Block.
    © 2017–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-16 09:16
