查看: 4399|回复: 0
[DataPlugin] NI Biomedical Standards DataPlugin for EuropeanDataFormat 2022 Q1 x64Win10 32/64bitEng NI用于欧洲数据格式EDF的生物医学标准数据插件21.5
    昨天 08:55
  • 签到天数: 3849 天
    连续签到: 42 天
     楼主| 发表于 2022-11-28 14:58:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Biomedical Standards DataPlugin for EuropeanDataFormat支持读取和导入欧洲数据格式(EDF)文件。
    Biomedical Standards DataPlugin for EuropeanDataFormat可集成到生物医学入门套件中,用于将EDF格式用于多通道生物信号的交换和存储。该DataPlugin支持包含带标题记录和数据记录的EDF和EDF+数据文件,还支持包含连续数字化测谎记录的单个EDF数据文件。
    发布日期:2022/1/31
    扩展:*.EDF; *.REC
    方向:读 / 写入
    应用​程序:EuropeanDataFormat
    包含的版本:2022 Q1完整版,版本号21.5
    语言:所有
    文件大小: 210618368 字节 (200.86 MB)
    修改日期: 2022-03-25 12:27
    MD5: bf32d8275cc17e4bc5414d056babb209
    SHA1: f33176f026ecedea3d6db3bb5de49f6a880bf0fe
    SHA256: 036ad17843a66a07c119fec1a2b6b2431e22a7ec1a2088ce647715b58baca523
    SHA512: 6c306a387562e01d1727d951c20b79f20b1f22a0f417580deb621e826fe20dab8657eb869e17503c33b3ef144c1e329f45cafdb122fd6f3b0c375b33676eaf9b
    请注册登录视觉论坛账号,购买附件查看下载地址
    Biomedical Standards DataPlugin for EDF2022Q1.txt (761 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1 Readme
    January 2022
    This file contains installation instructions and compatibility information for NI Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1.
    • Biomedical Standards DataPlugin for EuropeanDataFormat Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Biomedical Standards DataPlugin for EuropeanDataFormat Manuals: New features, behavior changes, and other documentation
    The Biomedical Standards DataPlugin for EuropeanDataForma integrates into the Biomedical Startup Kit to support the EDF format for exchange and storage of multichannel biological signals. This DataPlugin helps you work with EDF and EDF+ data files that contain a header record followed by data records; a single EDF data file contains one continuous digitized polygraphic recording.
    In the software the DataPlugin name is EuropeanDataFormat.
    Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1 supports the following operating systems:
    Note  Biomedical Standards DataPlugin for EuropeanDataFormat no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1 to an unsupported OS. Additionally, after installing Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Biomedical Standards DataPlugin for EuropeanDataFormat2022 Q1 supports the application software that support DataPlugins, for example DIAdem, SystemLink and LabVIEW.
    Download the Biomedical Standards DataPlugin for EuropeanDataFormat installer from ni.com/dataplugins. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Biomedical Standards DataPlugin for EuropeanDataFormat no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2007–2021 National Instruments Corporation. All rights reserved.
    378738A-01
    GMT+8, 2026-4-8 07:47
