查看: 1907|回复: 0
[LV工具模块] LabVIEW 2012 Multicore Analysis and Sparse Matrix Toolkit Win32/64Eng LabVIEW多核分析和稀疏矩阵工具包2012
    3 小时前
  • 签到天数: 3765 天
    连续签到: 16 天
     楼主| 发表于 2022-12-6 12:10:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Multicore Analysis and Sparse Matrix Toolkit
    LabVIEW Multicore Analysis and Sparse Matrix工具包可帮助您创建用于性能敏感型数学和分析算法的应用程序。
    LabVIEW Multicore Analysis and Sparse Matrix工具包是一款附加软件,提供了LabVIEW中使用的多线程分析库。该附加软件可用于需要在线处理或在离线场景下处理大型数据集的应用程序。该附加软件还具有稀疏线性代数功能,包括线性代数和矩阵运算,并通过可用库支持单精确度数据。LabVIEW Multicore Analysis and Sparse Matrix工具包支持通过 LabVIEW Real-Time模块在Windows PC和LabVIEW Real-Time (ETS)操作系统上执行。
    发布日期:2012/6/10
    包含的版本:2012
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 2 or later
    Full完整版
    文件大小: 123205256 字节 (117.50 MB)
    修改日期: 2022-03-25 06:09
    MD5: 5e7eec7de14b199538d7f663125c40c9
    SHA1: f8255cec3eba1d0070499a5587be00ef716283b6
    SHA256: e8217dd2e7cd168fa3d778010020d15d827fd5a0163770b7cfa719e3c3c266bf
    CRC32: 8af5d1c0
    请注册登录视觉论坛账号,购买附件查看下载地址
    MASMT2012.txt (668 Bytes, 下载次数: 0, 售价: 10 圆)
    RTE运行版
    文件大小: 58376328 字节 (55.67 MB)
    修改日期: 2022-03-26 00:08
    MD5: fc03a65881960745f1bb2d90d7a132d3
    SHA1: acfe5c5a1a89978a4b361ded9a4c934eaf3d70ea
    SHA256: aefd4ecc62d5bb80211fa7adc093f7c6fdd7e1cf11458dbbe6230b430568d0fd
    CRC32: a4a4899b
    MASMT2012RTE.txt (594 Bytes, 下载次数: 0, 售价: 5 圆)
    LabVIEW 2012 Multicore Analysis and Sparse Matrix Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains information about the LabVIEW 2012 Multicore Analysis and Sparse Matrix Toolkit, including installation instructions, new features, behavior changes, and known issues.
    The LabVIEW Multicore Analysis and Sparse Matrix Toolkit enables you to create applications that leverage multicore technologies for computing performance-sensitive mathematics and analysis algorithms. The Multicore Analysis and Sparse Matrix Toolkit also provides sparse matrix data types and VIs which enable you to solve large-scale problems that dense matrices are unable to handle.
    In addition to the system requirements for the LabVIEW Development System, the Multicore Analysis and Sparse Matrix Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit or 64-bit)
    • At least 1GB of disk space
    • 2GB RAM recommended
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    Double-click the setup.exe file in the root directory of the Multicore Analysis and Sparse Matrix Toolkit installer and follow the instructions on the screen to install this product.
    The Multicore Analysis and Sparse Matrix Toolkit 2012 introduces the following new features.
    • Signal Operation VIs—Use the Signal Operation VIs to manipulate signals and return a signal output. This palette contains the following new VIs:
      • Auto Correlation—Use the Auto Correlation VI to compute the auto correlation of an input sequence.
      • Convolution—Use the Convolution VI to compute the convolution of input sequences.
      • Cross Correlation—Use the Cross Correlation VI to compute the cross correlation of input sequences.
    • Support for determinism—A subset of Multicore Analysis and Sparse Matrix Toolkit VIs execute in bounded times in Real-Time applications. Refer to the LabVIEW Help for more information about reducing jitter and achieving bounded execution times for applications that contain Multicore Analysis and Sparse Matrix VIs.
    The Multicore Analysis and Sparse Matrix Toolkit 2012 contains the following changed VIs.
    • Get Number of Threads—In the previous version, the default option for function domain is All. In this version, the default option for function domain is Default. The behavior of this option is unchanged.
    • Set Number of Threads—In the previous version, the default option for function domain is All. In this version, the default option for function domain is Default. The behavior of this option is unchanged.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Multicore Analysis and Sparse Matrix Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Multicore Analysis and Sparse Matrix Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Multicore Analysis and Sparse Matrix Toolkit are located in the labview\examples\Multicore Analysis and Sparse Matrix Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2011–2012 National Instruments. All rights reserved.
    GMT+8, 2026-1-7 12:36
