查看: 1849|回复: 0
[NI软件产品] NI SignalExpress 2.5.1 Win32德语/日语/法语/英文 数据记录软件Signal Express 2.5.1
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-12-7 15:22:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2008/8/13
    包含的版本:2.5.1
    受支持的操作系统
    Windows 2000
    Windows XP
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 491624992 字节 (468.85 MB)
    修改日期: 2008-11-18 05:25
    MD5: 61cb8fdc9ef29d1da2a12bae8745fa6c
    SHA1: c03225a2e0d11f9734f8113125d8c688166a3c7b
    SHA256: 8124c7f8c2f4a93654085e35f610f67a497382c9ee15586bed4083307671ecb9
    CRC32: 67e99a6a
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2.5.1.txt (479 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW SignalExpress Tektronix Edition 2.5.1 Readme
    July 2008
    This file contains important information about LabVIEW SignalExpress Tektronix Edition, including known issues, installation, and compatibility issues. Refer to Getting Started with LabVIEW SignalExpress Tektronix Edition for information about getting started with LabVIEW SignalExpress Tektronix Edition. You can access this PDF by selecting Help»Getting Started with»Tektronix Edition in the LabVIEW SignalExpress environment.
    The file contains the following information that you need to understand.
    Compatibility
    You can use LabVIEW SignalExpress Tektronix Edition to connect Tektronix instruments to a PC. With built-in USB plug-and-play capabilities in Windows XP and Vista, LabVIEW SignalExpress Tektronix Edition automatically detects when you connect a supported Tektronix instrument to the PC. With this functionality, you can immediately control the instrument and acquire data from the instrument.
    Note  On Windows Vista x64 Edition, the 64-bit version, USB plug-and-play functionality does not work because LabVIEW SignalExpress Tektronix Edition is a 32-bit application.
    LabVIEW SignalExpress Tektronix Edition 2.5.1 is built on LabVIEW SignalExpress 2.5. All mentions of LabVIEW SignalExpress in this documentation can refer to either LabVIEW SignalExpress or LabVIEW SignalExpress Tektronix Edition. Refer to the LabVIEW SignalExpress Help for more information about new features in LabVIEW SignalExpress 2.5 that are not Tektronix-specific.
    Added Instrument Support
    LabVIEW SignalExpress Tektronix Edition 2.5 adds support for the following Tektronix instruments:
    • DPO2000 Digital Phosphor Oscilloscopes
    • MSO2000 Mixed Signal Oscilloscopes
    New Step
    The following step has been added:
    • Tek DPO/MSO2000
    To run LabVIEW SignalExpress Tektronix Edition, National Instruments recommends that your system meet the following requirements:
    • 512 MB of memory
    • Pentium 4 processor or equivalent (Pentium III or Celeron 600 MHz minimum)
    Insert the NI LabVIEW SignalExpress Tektronix Edition CD in your CD-ROM drive and follow the prompts through the installation.
    Note  If you are using Windows 2000, you must install Service Pack 4 and all additional critical updates before you install LabVIEW SignalExpress Tektronix Edition.
    LabVIEW SignalExpress Tektronix Edition installs or updates the following applications:
    • MAX 4.3
    • LabVIEW SignalExpress 2.5.1
    • LabVIEW SignalExpress Tektronix Edition 2.5.1
    • LabVIEW Run-Time Engine 7.1
    • LabVIEW Run-Time Engine 8.0
    • LabVIEW Run-Time Engine 8.2
    • LabVIEW Run-Time Engine 8.5
    • IVI Compliance Package 2.3
    • NI-VISA 4.2
    • Microsoft .NET Framework 2.0
    Note There is a known installation issue if Microsoft .NET Framework 2.0 Beta 1 is present on your computer. This issue causes the installation of NI SignalExpress Tektronix Edition to fail. To correct this problem, uninstall Microsoft .NET Framework 2.0 Beta 1 or upgrade to Microsoft .NET Framework 2.0 or later before you run the NI SignalExpress Tektronix Edition installer again.
    The NI LabVIEW SignalExpress Tektronix Edition CD installs both LabVIEW SignalExpress Tektronix Edition 2.5.1 and LabVIEW SignalExpress 2.5. All mentions of LabVIEW SignalExpress in this documentation can refer to either LabVIEW SignalExpress or LabVIEW SignalExpress Tektronix Edition.
    Refer to the LabVIEW SignalExpress Help, accessible by selecting Help»LabVIEW SignalExpress Help from the pull-down menu in LabVIEW SignalExpress, for information about LabVIEW SignalExpress Tektronix Edition.
    Example projects for LabVIEW SignalExpress are located in the signalexpress\examples\ folder. You can modify an example project to fit an application, or you can copy and paste from one or more examples into a project that you create. A Tektronix-specific tutorial is located in the signalexpressteked\examples\ folder.
    Compatibility
    LabVIEW SignalExpress is compatible with the following products:
    • NI-DAQmx 7.3 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.2 or later
    • IVI Compliance Package 2.1 or later
    • IVI Driver Toolset 2.0 or later
    To convert a LabVIEW SignalExpress project to a LabVIEW VI, you must have the LabVIEW 7.1 Full Development System or greater installed.
    • To support the AFG3011 arbitrary/function generator, you must download the latest IVI driver from ni.com/idnet.
    • The Tek AFG3000 step might not notify you when you enter a parameter value that is outside the valid range for that parameter. The instrument ignores invalid parameter values.
    • You cannot activate the sweep mode of an AFG3000 arbitrary/function generator from LabVIEW SignalExpress.
    • The Ramp symmetry (%) parameter on the Step Setup tab of the Tek AFG3000 step displays values without a decimal point. However, the instrument handles the ramp symmetry with a resolution of 0.1%.
    • If you set a Tektronix DPO3000 series product to a bandwidth of 150 MHz and connect the instrument to LabVIEW SignalExpress or if LabVIEW SignalExpress recalls an instrument setup with Bandwidth (Hz) in the Tek DPO3000 step set to 150 MHz, LabVIEW SignalExpress sets Bandwidth (Hz) to Full.
    • On the Step Setup tab for the Tek DPO3000 step, the Acquired Waveform display is incorrectly scaled by a factor of 0.8. However, the underlying data is correct and the waveform displays correctly in the Data View.
    • When you convert a project to a LabVIEW block diagram, some VIs may prompt you to save. Mass compile the LabVIEW\vi.lib directory to prevent this dialog from appearing each time you convert a project.
    • In the Load from ASCII step, if you deselect an output signal and it still appears to be selected, select another signal. LabVIEW SignalExpress deselects the original signal.
    • When you load a project created in LabVIEW SignalExpress 1.1 and earlier that contains a Limit Test step with an output displayed in the Data View, the Data View does not display the signal. Create a new viewer in the Data View and drag the Limit Test output signal into the Data View to view the signal.
    • When you convert a project that contains features not supported in LabVIEW to a LabVIEW block diagram, LabVIEW SignalExpress generates a LabVIEW block diagram with one Express VI. You cannot open the block diagram of the generated Express VI. If you include the generated Express VI in a distribution with the LabVIEW Application Builder, you must install LabVIEW SignalExpress to any target computers on which you run the LabVIEW-built application.
    • LabVIEW SignalExpress only supports one version of LabVIEW at a time. When you install LabVIEW SignalExpress, it finds the most current installed version of LabVIEW and installs support for LabVIEW SignalExpress into that version. If you later install a new version of LabVIEW, you need to uninstall and reinstall LabVIEW SignalExpress. When you reinstall, LabVIEW SignalExpress will install support for the new version of LabVIEW.
    • LabVIEW SignalExpress only supports one version of LabVIEW at a time for project conversion into LabVIEW. LabVIEW SignalExpress only installs support for the latest version of LabVIEW installed on the system. However, when you convert a LabVIEW SignalExpress project to a LabVIEW block diagram, LabVIEW SignalExpress calls the last version of LabVIEW opened on the system. If the last version of LabVIEW open on the system is not the version of LabVIEW with LabVIEW SignalExpress support installed, you must launch the version of LabVIEW with LabVIEW SignalExpress support and re-generate the project.
    • Registration information is saved on a per-user basis in Windows Vista. When you change users, the user information that appears when you launch LabVIEW SignalExpress may appear incorrectly.
    • Creating a source distribution in LabVIEW of a LabVIEW SignalExpress User Step template VI may fail and return an error. For one possible solution for this error, navigate to the Additional Exclusions page of the Source Distribution Properties dialog box and select the Remove unreferenced project library members option to remove the error.
    • When viewing scalar data in a table, the data history of the scalar data is not saved unless you previously viewed the scalar data in a chart display.
    • The Save to ASCII/LVM step does not save any units associated with the specified data.
    • You can configure only one IVI session name for a driver. If you configure more than one IVI session name for a driver, you invalidate existing IVI session names for that driver.
    • LabVIEW prompts you with a warning dialog box during project conversion if LabVIEW loads vi.lib subVIs from the National Instruments\LabVIEW directory rather than from the directory in which you saved a LabVIEW SignalExpress project. Click the OK button to resume conversion.
    • The Load from ASCII, Load from LVM, and Load from SPICE steps convert up to 20 imported signals into the LabVIEW VI during project conversion. If you want to import more than 20 signals and then convert the project to a LabVIEW VI, use two or more Load from ASCII, Load from LVM, or Load from SPICE steps.
    • You cannot convert a LabVIEW SignalExpress project to a LabVIEW block diagram if a hardware step in the project uses software triggers.
    • Text in any step configuration view does not display correctly if you set monitor resolution to 1400 x 1050 or higher or if you use large fonts.
    • Due to driver and operating system issues, absolute time stamps have an inaccuracy of 100 ms to 200 ms. National Instruments recommends that you use relative time stamps.
    • You cannot use a software trigger if the IVI FGEN Standard Function step or the IVI FGEN Arbitrary Waveform step are in continuous generation mode or if the IVI FGEN steps are in a sweep operation. During a sweep operation, the NI-FGEN devices send a start trigger only at the first sweep iteration.
    • If you configure a device to start on a digital trigger and the trigger source is the start trigger of an analog output NI-DAQmx supported device, the device might receive the start trigger before the generation starts. This can occur the first time you run the project or on the first iteration of a continuous execution. To work around this issue, configure the analog output device to be a slave by configuring the device with a digital trigger and selecting a trigger signal from another device as the trigger source.
    • If you are installing both the System Identification Toolkit 3.0 and LabVIEW SignalExpress 2.5, you must install the System Identification Toolkit 3.0 before you install LabVIEW SignalExpress 2.5. Installing the System Identification Toolkit 3.0 after you install LabVIEW SignalExpress results in an error upon launch of LabVIEW SignalExpress 2.5. To resolve the error, you can uninstall the affected components and reinstall in the correct order. The easiest way to resolve the error is to install the free System Identification Toolkit 3.0.1 upgrade. Refer to ni.com for more information on obtaining the free System Identification Toolkit 3.0.1 upgrade CD.
    Bug IDFixed Issue
    4BBCR2LYNeed longer timeout for AutoSetup for new video app
    4B8FI8XJTek AFG3000 step causes Create Analog Signal step not to work
    4B5FGUXJWaveforms not displayed on front panel of the arb after waveform type is changed a few times
    4AAAG5LYCannot perform multi-channel triggered acquire
    44LBKDZLStep Setup view is different from image on the scope
    403GQGI8Confusing pop-up: Tektronix code cannot be generated at this time
    38BF4MN7Window Menu: Arrange All - tiles the windows but does not bring them all to the front
    3BRAPM95Unchecking "Relative time" results in plot x-scale labeled "3.195G"
    3ECDGCTQSteps dependent on other steps that are not executable shouldn't be executable either
    3HG9CKNRRefresh device list doesn't refresh enum in HW block
    3IRCSLXXNo option to send digital data to a viewer in right-click menu
    3SJADPI8Instruments connected via USB can appear twice in IVI session name ring of IVI steps
    422E16RSLoad from SPICE - switching between Domain type does not re-show the Imported Signal (it goes blank)
    4248BMI8Non active log doesn't playback when viewed
    429CNLDELoad from ASCII block does not undo correctly
    42NJGSI8Statistic step doesn't work with U32 data
    42QB80YGHeader should not clip text (horizontally)
    42RDHPLYSave to ASCII preview graph legend incorrect after undo/redo
    439F04LYLogging tool - undo redo messes up signal selection
    43GDR5YGViewer - Unchecking a plot in the legend should not force autoscale X
    444F4E26Output Range control should be exposed in Power Supply Interface
    445DS10XAnnotations don't show up when doing playback
    44SACETQTiming and Transition - Edge and Pulse markers are not working
    45AEFHK9New Logs are not visible in the LabVIEW SignalExpress Express VI
    45BESONBDrag and drop of docked config page does not indicate to SE that files needs to be saved
    45ECNJRSRecording Options - Setting value doesn't change it if you don't click outside the control
    45ED3RRSIf you codegen a logging project that has logged data, LabVIEW SignalExpress Express VI also requires logged data to be present in the correct disk location
    45FD89TQActual log much longer than requested. The additional data are also incorrect.
    45FA8OYGChannel View: device not visible in Playback (refresh devices only applies to current work area)
    45N91UYGPlayback - Sample rate should be displayed in the playback option view
    45NDRTYGPlayback Options - Logged signals tree view should allow right-click menu to set Active Log
    45OGQOI8Viewer stays empty when dragging an imported log in playback mode
    45SD65YGRestore Defaults should restore application specific defaults
    45TD6UOKCreating data the first time is slow
    45TDTNK9Viewer doesn't autoscale Y axis correctly when scale is changed from Logarithmic to linear
    45TJ94I8Sweep's output dialog doesn't work well when there are many signals in the project.
    45TJDDI8The sweep step should output the iteration count
    464MGU2WDelete Log dialog does not mention that Log is being used in Playback as well
    465I8W9Limit Test returns 'Missing inputs' error when user switches to limits defined by input signals
    465GF6RSIVI Scope logs data poorly
    467CN2N7Code generation of synchronized steps fails in certain cases
    467DG4LYStart condition with NI-Scope acquired sine wave doesn't work
    468DN7FNWarning message pops up while building an application that contains 2 LabVIEW SignalExpress Express VIs
    46BB1PWWSynchronization Code Should Filter Duplicate Clock\Trigger Names
    46BCMEXACan't stop VI after error from black box code gen
    46BD2D00Viewers - Cursors fails to update when the signal is renamed
    46DDCH2WMenu hot keys don't work when Signal Selection table is active in Recording Options tab
    46DF9RRSProject Documentation tab - No button or key sequence to select all
    46EA3S3ILimit Test displays "upper limit" terminal when >Lower limit is selected
    46ICP82WLogging Signals Selection dialog forgets signals if you cancel and then return
    46IHN700Export to Excel - dragging log group from log window doesn't export all data in group
    46JCRCLYConditional repeat does not allow logged inputs
    46K9CA0XScalar log and viewing it on the chart does not update the current value
    46K9HB0X"First Log Complete" shows up at unexpected time when having imported a log
    46KADARSProject conversion from within LabVIEW gives strange VIs for single and loop modes
    46KC2ENBDropping a array of double onto a non-Table viewer causes error dialog
    46LCPA3IStatistics - selecting checkboxes while code is thinking resets buttons
    46LFM4X0Deleting a task while it is running in MAX causes errors
    46NFFFNRSubset and resample allows negative subset lengths
    46O8CL0XLoading project with viewer loading empty
    46O8D60XLoading project with empty top viewer in playback mode.
    46PAI7XAChannel View does not display all devices available
    46PCLIGXConverting log to ASCII loses timestamp
    472C1UYGIncorrect information in About window
    474952W9Examples that use DAQ Assistant should use 'Let NI-DAQ choose' whenever possible to avoid errors when user runs project on their hardware.
    474KQU00LabVIEW SignalExpress crashes when grouped output datatype changes when that output is not the first created output for a step
    475A0DK9Logging issues when device channel being logged is changed
    4760UJW9Snapshots in documentation appear empty when project reloaded
    47S9GENBDrag and drop a jpg file from explorer onto Documentation tab, SignalExpress crashes eventually
    47THBIAFPlayback on 1 Sample (on demand) signals doesn't scroll correctly
    48CG1LKZLabVIEW SignalExpress cursor values do not update when waveform changes
    48HAM62BCannot print graphics in Landscape mode
    48P91NX6Exporting logged scalar data to Excel during runtime gives blank Excel spreadsheet and clears log
    492DCAPJStatistics Step does not properly handle array of scalars input
    © 2004-2008 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, LabVIEW, and SignalExpress are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    Tektronix® and Tek are registered trademarks of Tektronix, Inc.
    GMT+8, 2026-4-16 08:00
