查看: 1960|回复: 0
[NI软件产品] NI Requirements Gateway 1.1.1 Win32Eng 需求网关NIRG1.1.1
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2022-12-7 17:33:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Requirements Gateway应用软件可将开发和验证文档直接链接到文档和数据库中的正式需求。
    Requirements Gateway可指定哪些应用程序、测试和仿真模型与记录的需求相关联,以捕获可追溯性信息。您可以使用Requirements Gateway来捕获和比较项目快照,以查看差异以及需求和覆盖率随时间的变化。该应用软件集成到LabVIEW、LabWindows/CVI和TestStand以及常用的需求描述工具,如Telelogic DOORS、IBM Rational RequisitePro和Microsoft Office等。
    发布日期:2011/8/19
    包含的版本:1.1.1
    受支持的操作系统
    Windows 7 32-bit
    Windows Vista 32-bit
    Windows 2000
    Windows 7 64-bit
    Windows Vista 64-bit
    Windows XP
    语言:英文
    应用程序位数:32位
    文件大小: 89260032 字节 (85.13 MB)
    修改日期: 2022-03-25 06:12
    MD5: 325463d90be059b4a4a9cd3a95d8f6cc
    SHA1: d4e2455c83279020dfaae37296a93e700d966ac9
    SHA256: feea824d948b813d9a3c969a4cc17d22062e41edb9b4ac2bdc59b9fa01f58214
    CRC32: 22db24fe
    请注册登录视觉论坛账号,购买附件查看下载地址
    NIRG1.1.1.txt (523 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Requirements Gateway 1.1 Readme
    January 2009
    This document contains information about known issues and bug fixes in NI Requirements Gateway 1.1. Refer to the NI Requirements Gateway Release Notes for information about other changes since Requirements Gateway 1.0, including new features, and for information about getting started with Requirements Gateway, such as system requirements, installation instructions, and licensing information. If you do not activate a Requirements Gateway license, Requirements Gateway operates in Evaluation Mode.
    Use this Toggle Expansion button to expand or collapse all the sections. You must enable the Allow Blocked Content option in Microsoft Internet Explorer to collapse each section. You must expand each section you want to print or search.
    Contents
    Additional Information
    Installation
    Configuration Dialog Box
    LabWindows/CVI
    NI TestStand
    NI MATRIXx
    Third-Party Types
    Reports
    Snapshots
    Miscellaneous
    The following items are changes from Requirements Gateway 1.0 to Requirements Gateway 1.1, unless otherwise specified.
    LabWindows/CVI
    NI TestStand
    NI MATRIXx
    Third-Party Types
    Reports
    Miscellaneous
    For additional information about Requirements Gateway, refer to the support section of the National Instruments Web site at http://www.ni.com/support. The Web site contains many electronic support services to help you in your development. Some of the databases included are:
    • Developer Zone
    • Example Programs
    • Software Library
    • KnowledgeBase
    National Instruments offers email-based technical discussion forums. You can join the forums at http://forums.ni.com/ni.
    © 2006–2009 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, NI TestStand, LabVIEW, MATRIXx, and SystemBuild are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
    GMT+8, 2026-4-16 10:50
