查看: 2123|回复: 1
[驱动] 大恒图像Windows系统英文驱动运行时V1.22.23.02 Galaxy_Windows_Runtime_EN_32bits-64bits_1.22.2302.9111
    4 小时前
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2023-3-7 10:29:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    软件说明
    Galaxy Windows Runtime SDK
    1. 支持的相机类型
       水星、水星二代、火星、金星系列相机
    2. 支持的语言:中文
    3. Galaxy Windows Runtime SDK是配套工业相机二次开发的运行时组件包,适用于大恒GigE,USB3.0,USB2.0相机产品。
    4. 如果PC已经安装了Galaxy Windows SDK,需要先将其卸载,才可以安装运行时安装包。
    文件名: Galaxy_Windows_Runtime_EN_32bits-64bits_1.22.2302.9111.zip
    文件大小: 29041875 字节 (27.70 MB)
    修改日期: 2023-02-24 15:11
    MD5: cfc742c8e75eb186df365eae043a40f5
    SHA1: 5b9c21f4b88418286fb1cccd9ffd95e423b2faa8
    SHA256: d89d455c0ac53cf2c991c8413aa06e2ff937c670b29252b143120829de98313b
    CRC32: d690d5f6
    RELEASE DATE:2023-02-11
    VERSION:1.23.2302.9111
    NEW FEATURES / CHANGES
    GxIAPI Library:Add TianXing and VE2S function codes
    Samples:Split the pixel format definition in the C library header file from the GxIAPI. h header file, A separate header file.
                             Users can also use C image processing library in C++projects.
    Samples:Add "GxPixelFormat.h" Pixel format definition header file
    Samples:The length of the FFC file obtained by the python sdk interface from_file is one byte longer
    Doc:Update  C software development instructions
    RELEASE DATE:2023-01-16
    VERSION:1.22.2301.9161
    GxIAPI File:Fixed function code missing
    RELEASE DATE:2022-12-20
    VERSION:1.21.2212.9201
    GxU3VTL:Optimize the opening device by services
    GxIAPI Library:Add function codes
    GxIAPINET library:Fix the exception thrown by the. net4.0 library import parameter group interface
    GxIAPINET library :Fix the exception thrown by closing the VS19 and above devices
    GxGVTL library :Fix the problem of network card disconnection triggering device disconnection callback
    GxGVTL library :Fix the problem of setting package length for mining interface
    Samples:Repair C# CxImageProcess Example program image display inversion problem
    USB driver :Update dhUSBFM.dat file
    RELEASE DATE:2022-10-18
    VERSION:1.20.2210.9181
    GxIAPI Library:Add function codes related to Langsun camera, Add batch read/write register address interface, Optimize import parameter group interface
    GxIAPICPPEX Library:Add batch read/write register address interface, Optimize import parameter group interface
    GxIAPINET Library:Add batch read/write register address interface, Optimize import parameter group interface
    DxImageProcLibrary:Expand image format conversion function: "MONO12_ PACKED to MONO8 type"
    DxLibrary: Add the culture in the name of the display panel attribute tree list
    Python SDK:Add sample program for collection callback:GxAcquireCallback.py
    Doc:Update C++software development instructions, C software development instructions, DotNET software development instructions
    RELEASE DATE:2022-09-29
    VERSION:1.19.2209.9291
    GxIAPI Library: add Burst acquisition mode" and "Frame storage depth"  and "Clear frame memory" function code
    GxIAPI Library: Cancel "GXImportConfigFile"  "GXImportConfigFileW" Interface Default Parameters
    Dx Library: Fix the initialization failure of some scene parameters
    Doc: Camera application manual and frame rate calculation tool, starting from this version, it will no longer be released with the installation package,
                 go to the official website to download the latest version
    CORRECTIONS
    RELEASE DATE:2022-08-30
    VERSION:1.18.2208.9301
    GxIAPI Library: add "Contrast" and "Stripe Calibration" function code
    Shading Correction Tool: repair the bug of AWBLampHouse and high bit depth
    CORRECTIONS
    RELEASE DATE:2022-06-23
    VERSION:1.17.2206.9232
    GxGigeIPConfig: Remove the device vender information on the interface.
    CORRECTIONS
    GxIAPICPPEx library: Upgrade the GalaxyIncludes.h file in the GxIAPICPPEx library to improve the compilation compatibility of VS2017 and above.
    U3V driver: Under Win7, the matching method of U3 camera driver is changed from fuzzy matching to precise matching, which does not affect the original behavior of users.
    RELEASE DATE:2022-04-13
    VERSION:1.16.2204.9131
    DxImageProc Library: extends the function of DxImageFormatConvert interface and supports the conversion of Bayer image data into RGB_ Planar image data
    DxImageProc Library: a new DxCalcCameraLutBuffer interface is added, which can calculate the camera look-up table interface through gamma, contrast and brightness values
    DxImageProc Library: a new ReadLutFile interface is added, which can get the camera look-up table interface through read the look-up table file
    GxIAPICPPEx library and GxIAPINET Library: add IGXImageFormatConvert class, which is equivalent to the DxImageFormatConvert interface of DxImageProc library
    GxIAPICPPEx library and GxIAPINET Library:         IGXImageSpecialFunction::CalculaLut interface is added, which is equivalent to the DxCalcCameraLutBuffer interface of DxImageProc library
    GxIAPICPPEx library and GxIAPINET Library: IGXImageSpecialFunction::ReadLutFile interface is added, which is equivalent to the ReadLutFile interface of DxImageProc library
    GxIAPI Library: add "StaticDefectCorrectionValueAll","StaticDefectCorrectionFlashValue","StaticDefectCorrectionFinish","StaticDefectCorrectionInfo"function code
    Gigabit Network Camera TL Library: add a mechanism to force entry into the firewall trust list, provided that it must be run with administrator privileges.
    Gigabit Network Camera TL Library: Improve online upgrade speed
    Gigabit Network Camera TL Library: Optimize the burning process without affecting the original behavior of users
    Bad point correction plug-in:Optimize the internal interaction mechanism without affecting the original behavior of users
    CORRECTIONS
    Solve the annotation problem of gxiapi header file of English installation package
    Solve the problem that the image display of c# sample program will be reversed after the computer hibernates
    Gigabit Network Camera TL Library: solve the problem of failure to open camera without DNA encryption
    Gigabit Network Camera TL Library: user data area write of compatible A7 device is equal to or less than 4 bytes
    百度网盘下载地址:
    链接:
    提取码:kzx7
    --来自百度网盘超级会员V5的分享
    大恒官方下载地址:
    GMT+8, 2026-4-17 12:47
