TA的每日心情 | 无聊 10 小时前 |
签到天数: 3851 天 连续签到: 44 天 [LV.Master]2000FPS
楼主 |
发表于 2023-5-16 17:18:36
来自:广东省东莞市 电信
MVTEC Deep Learning Tool 22.06 Full Version x64 windows 深度学习工具dlt-22.06完整版
文件名: lt-22.06.zip
文件大小: 2306928630 字节 (2.15 GB)
修改日期: 2022-06-06 11:45
MD5: 7ac257f6720f7f04a6008864ae65349f
SHA1: 303f6b5bc3fae9b38d354612f6423ff6833c40d2
SHA256: 02a3efb6dfd5e227c0e65bbb21b0f3d352ed2d33064fda372036b6ebf188a213
CRC32: c4e72ef4
MVTEC官方地址:
需要注册,然后免费下载。www.mvtec.com
百度网盘下载地址:
链接:https://pan.baidu.com/s/1NRVyZCXplGciRnBXn_8Etg
--来自百度网盘超级会员V5的分享
VERSION 22.06NEW FEATURES- It is now possible to change the opacity of label regions on the Image page for all project types.
- When the license is about to expire within 100 days, now a warning is shown.
- The metadata dictionary of the DL model now stores additional information about the training (trained with DLT, used DLT version, used DL device, required time).
- The Image page has been enhanced with an additional zoom step between 1:1 and 1:2. Now, zooming should work more smoothly.
- When exporting semantic segmentation projects to an HDICT dataset file it is now possible to change the suffix of the label image filenames.
- There is now an option to remove projects from the Recent Projects section on the Project page. The projects' context and dot menus have been extended accordingly.
- After deleting a split and undoing this change, now the sorting is more consistent.
- After resetting a training, now the Settings tab card is visible instead of the empty Results tab card so that the user can easily adapt the training parameters.
- From this version on, the DLT supports labeling for Deep OCR scenarios to further improve the Deep OCR models provided by HALCON.
RESOLVED ISSUES AND IMPROVEMENTS- On the Gallery page, the thumbnails of non-square images were distorted so that they filled the whole thumbnail. This problem has been fixed.
- In the example projects shipped with the DLT, some labels had wrong positions. This problem has been fixed.
- When moving the splitter between the Navigator pane and the Labels pane on the right panel of the Image page, it could happen that the title of the Navigator pane was covered by the pane. This problem has been fixed.
- When importing labels that already exist in the project, they were not de-duplicated in projects with relative paths. This problem has been fixed.
- For projects with relative image paths, "Open image in File Explorer" and "Save image as" from the context menu did not always work. This problem has been fixed.
- When drawing an oriented rectangle, the wrong mouse cursor was shown while hovering another rectangle. This problem has been fixed.
- On the Review page, it was possible to switch to the Image page by pressing the Enter key. This shortcut has been removed. The Image page can be reached by pressing Alt+3 from all pages. In addition, double-clicking an icon on the Review page switches to the corresponding image and selects the label.
- The release notes of the DLT versions 0.6.2 and 22.03 did not mention that several shortcuts used to assign labels were changed. The available shortcuts are: 1-9; a, b, d, f, g, j, k, l, n, o, q, u-z; A, B, D, F, G, J, K, L, N, O, Q, U-Z
Further, all supported shortcuts are now mentioned explicitly in the documentation. - When exporting a segmentation project as a HALCON dictionary (HDICT), sometimes the background class was assigned to the wrong class. This problem has been fixed.
- After opening and closing an example program, the context menu of the closed program still had an entry to close the program. This problem has been fixed.
- If an error occurs after starting a training, the training is now reset and it is possible to change the settings right away.
- After deleting a split used by a training and then undoing this deletion, the split was selected in the split combo box on the Settings tab of the Training page but not on the training list on the left hand side. This inconsistency has been fixed.
