查看: 3598|回复: 3
[驱动] 瑷荔德Allied Vision Tech(AVT) 工业相机驱动和二次开发包Vimba_v5.1_Windows The SDK for AVT cameras
    昨天 07:53
     楼主| 发表于 2024-11-28 11:27:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: Vimba_v5.1_Windows.exe
    文件大小: 188348064 字节 (179.62 MB)
    修改日期: 2024-10-25 10:46
    版本: 5.1.0.31755
    MD5: cc742d21a5b4d7b86dbe71b2d341bb1a
    SHA1: 78f1ae3f3b5a49fc6fcf67ace02badedcc75d464
    SHA256: d8ef69d52efb2e8182ff056a3d65e3e867acdcd950c397d66a23f9145fb68305
    CRC32: e5939e8c
    AVT官方下载:
    链接:https://pan.baidu.com/s/1NaSxOY92z8k1X5VgyKtO0g
    Changes in Vimba 5.1.0:
    VimbaC
      - New feature: Support for Alloc And Announce frame allocation mode
      - Feature endianess related fixes (corresponding to GigE TL)
    VimbaCPP
      - New feature: Supports Alloc And Announce frame allocation mode
    VimbaNET
      - New target framework version: .NET 4.7.2
    VimbaPython
    Vimba Viewer
      - Supports Alloc And Announce frame allocation mode
      - Chinese localization
      - Supports changes of GigE TL and VimbaC
      - Fixed: IP labels not updated after changing the IP via GevCameraForceAddressSend
      - Fixed: Auto ROI tab always resets ROI at startup
    Firmware Updater
      - Supports Git hash representation
    Firmware Updater Console
    GigETL
      - Changed behaviour of endianess handling (values must match host endianness in little-endian),
        for better compatibility with third-party software.
        Affected features that now have a changed byte order:
          - Config Mode
          - IP-related features including MulticastIPAddress
          - Action Commands
      - New feature DeviceUpdateTimeout (only applicable if GigE discovery is switched to Broadcast)
      - New GVSPMaxLookBack default value (0 instead of 1) for improved packet resend handling
      - Fixed: High memory usage during performance bottleneck (Nonpaged pool growing with multiple GigE cameras)
      - Fixed: Action commands caused an error message in the console log
      - Fixed: Multicast IP address range, better compatibility with third-party software
    GigE Filter Driver
      - Reduced memory allocations
      - Hidden statistics
    USB TL
    -  Fixed: Reset cameras streaming state when opened (Endpoint Halt)
    -  Updated 3rd-party libraries
    发表于 2025-5-29 11:50:29 | 显示全部楼层 来自:江苏省苏州市 电信
  • 签到天数: 1 天
    发表于 2026-3-31 16:10:51 | 显示全部楼层 来自:山东省济南市 移动
    前天 15:11
  • 签到天数: 1 天
    发表于 前天 15:15 | 显示全部楼层 来自:河北省石家庄市 电信
    GMT+8, 2026-4-24 05:14
