查看: 4148|回复: 16
[驱动] 宝视纳Basler-pylon 8.0.1相机软件套装(Windows版):Basler pylon 8.0.1-16188
    3 小时前
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2024-11-29 11:06:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    pylon相机软件套装(Windows版)的完整软件包。
    pylon相机软件套装包含易于使用的SDK、驱动程序和工具,让您可通过Windows PC来操作任意一款Basler相机。pylon采用最新GenICam技术,可无限制使用最新型号的Basler相机并使用相关的硬件功能。Basler pylon支持CoaXPress 2.0、GigE Vision、USB3 Vision、Camera Link和GenICam GenTL。
    pylon可为所有典型相机应用提供大量丰富的文档资料和示例程序以供参考,支持各种编程语言(C、C++、C#、VB.Net等),可大大促进应用的开发工作。
    Basler pylon支持所有当前的Windows版本,最高可支持Windows 11(64位)。由于pylon不仅支持Windows,还支持macOS和Linux(x86和ARM),因此在pylon下为Windows创建的应用程序可以轻松移植到其他操作系统和架构(如嵌入式系统)。
    文件名:Basler pylon 8.0.1-16188.exe
    文件大小: 1360299944 字节 (1.27 GB)
    修改日期: 2024-11-05 21:39
    版本: 8.0.1.16188
    MD5: fc6672a11bde41084377b541695f1e4f
    SHA1: 0fdd23a1f238028ed09e8dcd2072629af802e0c8
    SHA256: 87880fec6b5707494233f906650ec049348fc935af13df50c394ed46c514507e
    CRC32: c1756cad
    Basler官方下载:
    链接:https://pan.baidu.com/s/1cayNdLdyVxchcExBtxDz-Q
    --来自百度网盘超级会员V7的分享
    pylon 8 Software Suite for Windows
    RELEASE NOTES
    Note: Patch versions of pylon for Windows OS are not released publicly.
    RELEASE DATE:    2024-10-25
    VERSION:         8.0.1 (Windows)
    NEW FEATURES / CHANGES
    * GenTL/CXP: [311175] Restructured existing log messages for compliance with the
                 pylon event logging (PEL) framework.
    * GenTL/CXP: [300706] Added new logging library with enitity IDs to log
                 messages, introduced more along with the modification of the
                 existing ones
    * pylon Viewer: [316331] Improved pylon Viewer startup time.
    * pylon Viewer: [316268] Updated several icons in different areas of the pylon
                    Viewer, e.g., Workbench and Camera API Generator.
    * Workbench: [316268] The recipe will now be forced to stop if execution isn't
                 finished within 5 seconds after clicking the Stop button in the
                 Workbench toolbar.
    * vTools: [316650] If an input ROI has been specified, the coordinates of the
              output regions (Semantic and Instance Segmentation) and bounding boxes
              (Object Detection and Instance Segmentation) refer to the original
              input image.
              In the previous version, the coordinates were given in relation to the
              ROI.
    * vTools: [316181] Added resources for vTool use cases that show you how to
              perform certain machine vision tasks, e.g., expiry date checks. The
              resources include recipes, sample images, and basic documentation.
    * vTools: [314581] Added new vTools: Data Synchronizer, Image Cropper, Image
              Stitcher, Image Transformer, and Region Combiner.
    CORRECTIONS
    * GenTL/CXP: [300801] Fixed issue of contents of mfs file being empty
    * GenTL/CXP: [303262] Ensured that the HAP files Device xmls include only the
                 process relevant to the current GenTL device, filtering out all
                 others.
    * GenTL/CXP: [315763] Removed caching from HAP XMLs as the register dependencies
                 are not exported by the HAP file.
    * GenTL/CXP: [303265] Prepended process identifiers to device names when
                 multiple DMA acquisition channels per VA process exist, ensuring
                 clear association of DMAs within the same process.
    * GenTL/CXP: [234116] Added functionality for FG-SDK to run and load applets
                 from paths with non-latin characters
    * GenTL/CXP: [300663] Added support for imaFlex Penta framegrabber
    * GenTL/CXP: [316313] Before fixing this issue, many log messages contained
                 redundant information. This has been fixed.
                 Now, additional information (tags) is placed in trace level
                 messages behind the actual message text.
    * pylon Viewer: [315618] The Data Privacy option in the Help menu now has the
                    correct icon.
    * pylon Viewer: [315593] Corrected the sample code generated for vTool
                    enumeration parameters in the Feature Documentation.
    * pylon AI Agent: [316192] Fixed display issues at certain resolutions and
                      scaling settings.
    * vTools: [313333] The Image Loading vTool can now load recipes with unicode-
              paths.
    RESTRICTIONS
    * pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
                    improve overall stability and performance. This introduces a new
                    restriction which affects the video recording feature of the
                    pylon Viewer. Allowing only 250 images per second and camera in
                    the imaging pipeline limits the ability to record every frame
                    when exceeding this limit.
    * pylon Viewer: The Color Calibrator does not support all Basler color cameras.
                    cameras are not supported.
    * pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
                    the Color Calibrator may not work if the camera has already been
                    opened in the pylon Viewer. To prevent this, close the camera
                    before using the Color Calibrator.
    * pylon Viewer: On computers with an Intel HD graphics card, it may be necessary
                    to update the graphics driver to the current version.
    * Workbench: Using multiple pin data views actively displaying data in the
                 Workbench may cause
                 an increase of the CPU load and degradation of the overall
                 performance. Basler
                 recommends using fewer pin data views whenever possible.
    * Workbench: The Statistics feature of the Workbench measures the execution
                 times of vTools.
                 The times measured in the Statistics feature may vary depending on
                 the configuration of your
                 system and the overall CPU load. This is so, because CPUs may run
                 with different frequencies
                 depending on the current load (e.g., due to dynamic frequency
                 scaling).
    * CXP IC: For line scan applets, ranges of line period and line exposure aren't
              handled properly. The maximum values may be lower than expected.
    * pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
                   functionality was added to pylon C to be able to start and stop
                   streaming explicitly. This functionality has not been documented
                   in the pylon C programmer's guide yet. Please refer to the pylon
                   C++ programmer's guide (see chapter "Migrating from Previous
                   Versions - Changes in the IStreamGrabber API") or the pylonC
                   OverlappedGrab programming sample.
    * pylon C++ SDK: When building samples using CMake, you may run into a path
                     length limitation of the operating system. You may get build
                     errors stating the paths exceed the maximum path length of 260
                     characters. This may happen if the absolute path of your CMake
                     build directory exceeds 80 characters. The build directory is
                     the current working directory or the directory specified by the
                     '-B' option when you call cmake. If you experience this error,
                     use a build directory with a shorter path not exceeding 80
                     characters, i.e., directly in your user profile
                     C:\Users\\Samples. You can enable long paths on
                     Windows 10, Version 1607, and later. See the Microsoft
                     documentation for more information.
    * pylon C++ SDK: Using Visual Studio 2017, you may get the MSB4211 warning. To
                     remove the warning, specify the version of the Windows SDK in
                     the Release and Debug project properties (Configuration
                     Properties -> General -> Windows SDK Version).
    * pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
                     usual enumeration for event notifications. The following code
                     snippets can be used to work around this issue. For C++ you can
                     use: CBooleanParameter(camera.GetNodeMap(),
                     "EventNotification").TrySetValue(true); in addition to:
    * GigE: In case the error message "Failed to allocate resources." has been
            reported, Basler recommends using the pylon GigE Configurator tool to
            optimize the IP configuration of NICs and cameras.
    * GigE: Multiple IP configurations on a single network interface are not fully
            supported by the IP Configurator tool.
    * pylon C++ SDK: The InstantCameraArray classes can acquire images from a
                     maximum of 21 cameras.
    * GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
            recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
            may cause buffer underruns and image loss. In addition, Basler
            recommends using the pylon GigE Configurator tool to optimize the
            complete setup.
    * GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
    * USB: The Power Management used by the Intel USB host must be turned off since
           Basler U3V devices may get desynchronized. If this is the case the Basler
           U3V devices may be not available after booting the system in some cases.
           Disable LPM packages on the USB3 bus with the following steps 1. Enable
           advanced settings by executing the following command powercfg -attributes
           2a737441-1930-4402-8d77-b2bebba308a3 d4e98f31-5ffe-
           4ce1-be31-1b38b384c009 -ATTRIB_HIDE 2. Change the LPM settings in the
           power options - Open the Power Options in the control panel. - Click
           "Change plan settings" for the selected power plan. - Click "Change
           advanced power settings". - In the "Power Options" dialog on the
           "Advanced settings" tab, select "USB settings". - Set "USB 3 Link Power
           Management" to "Off".
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
           to be installed in order to work. The pylon Supplementary Package for
           MPEG-4 is available for download on the Basler website.
           may fail, if the Quality parameter is set to 80 % or more. As a
           workaround, set the Quality parameter to a lower value.
    * MP4: The Recording feature doesn't support the Compression Beyond feature in
           ace 2 Pro cameras. When recording is started and the Compression Beyond
           feature is enabled, the pylon Viewer first disables the Compression Beyond
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
          blaze to be installed. The pylon Supplementary Package for blaze is
    * Direct Show: CoaXPress cameras are not supported with DirectShow driver.
    * Twain: CoaXPress cameras are not supported with Twain driver.
    * pylon AI Agent: With certain resolutions and scaling settings, buttons may not
                      be visible。
  • 签到天数: 7 天
    发表于 2025-9-4 07:08:19 | 显示全部楼层 来自:广东省东莞市 联通
    发表于 2025-12-3 14:57:34 | 显示全部楼层 来自:天津市河西区 联通
    发表于 2025-11-19 15:16:01 | 显示全部楼层 来自:浙江省温州市 电信
    发表于 2024-11-30 09:16:03 | 显示全部楼层 来自:中国 移动数据上网公共出口
    发表于 2025-1-8 20:10:56 | 显示全部楼层 来自:黑龙江省 移动(全省通用)
    发表于 2025-5-20 22:58:34 | 显示全部楼层 来自:香港 电讯盈科有限公司
    发表于 2025-6-21 23:11:42 | 显示全部楼层 来自:重庆市 移动
    发表于 2025-8-18 09:08:28 | 显示全部楼层 来自:北京市 电信
    GMT+8, 2026-4-17 11:14
