TA的每日心情 | 郁闷 2 小时前 |
签到天数: 3859 天 连续签到: 52 天 [LV.Master]2000FPS
楼主 |
发表于 2024-11-29 11:44:40
来自:广东省东莞市 电信
宝视纳Basler-pylon 8.0.1相机软件套装Linux x86(64位)- Debian安装软件包:pylon-8.0.1-16188_linux-x86_64_debs
文件名: pylon-8.0.1-16188_linux-x86_64_debs.tar.gz
文件大小: 959413683 字节 (914.97 MB)
修改日期: 2024-11-06 17:46
MD5: ff0b147cf5f809aeee6ead9e2cc70599
SHA1: bd9225a12b8d70bdc7328c07cd164835067b4989
SHA256: 3ed01a4829436c403142af3f6254640b74360e8f09ff4a48b15455dc91a521c4
CRC32: 4467edb9
Basler官方下载:
链接:https://pan.baidu.com/s/1-601Z4Y2XnGvPdqgy9er4Q
--来自百度网盘超级会员V7的分享
pylon 8 Software Suite for Linux
RELEASE NOTES
Note: Patch versions of pylon for Linux OS are not released publicly.
RELEASE DATE: 2024-10-25
VERSION: 8.0.1 (Linux)
NEW FEATURES / CHANGES
* GenTL/CXP: [311175] Restructured existing log messages for compliance with the
pylon event logging (PEL) framework.
* GenTL/CXP: [300706] Added new logging library with enitity IDs to log
messages, introduced more along with the modification of the
existing ones
* GenTL/CXP: [314043] Added RPath to fglib5.so so that its dependencies can be
found when its loaded directly, without the need to adjust the
LD_LIBRARY_PATH
* pylon Viewer: [316331] Improved pylon Viewer startup time.
* pylon Viewer: [316268] Updated several icons in different areas of the pylon
Viewer, e.g., Workbench and Camera API Generator.
* Workbench: [316268] The recipe will now be forced to stop if execution isn't
finished within 5 seconds after clicking the Stop button in the
Workbench toolbar.
* vTools: [316650] If an input ROI has been specified, the coordinates of the
output regions (Semantic and Instance Segmentation) and bounding boxes
(Object Detection and Instance Segmentation) refer to the original
input image.
In the previous version, the coordinates were given in relation to the
ROI.
* vTools: [316181] Added resources for vTool use cases that show you how to
perform certain machine vision tasks, e.g., expiry date checks. The
resources include recipes, sample images, and basic documentation.
* vTools: [314581] Added new vTools: Data Synchronizer, Image Cropper, Image
Stitcher, Image Transformer, and Region Combiner.
CORRECTIONS
* GenTL/CXP: [300801] Fixed issue of contents of mfs file being empty
* GenTL/CXP: [303262] Ensured that the HAP files Device xmls include only the
process relevant to the current GenTL device, filtering out all
others.
* GenTL/CXP: [315763] Removed caching from HAP XMLs as the register dependencies
are not exported by the HAP file.
* GenTL/CXP: [303265] Prepended process identifiers to device names when
multiple DMA acquisition channels per VA process exist, ensuring
clear association of DMAs within the same process.
* GenTL/CXP: [234116] Added functionality for FG-SDK to run and load applets
from paths with non-latin characters
* GenTL/CXP: [273529] Added support for Ubuntu 20.04, 22.04 and discontinued
supporting Ubuntu 18.04.
* GenTL/CXP: [300663] Added support for imaFlex Penta framegrabber
* GenTL/CXP: [316313] Before fixing this issue, many log messages contained
redundant information. This has been fixed.
Now, additional information (tags) is placed in trace level
messages behind the actual message text.
* pylon Viewer: [315618] The Data Privacy option in the Help menu now has the
correct icon.
* pylon Viewer: [315593] Corrected the sample code generated for vTool
enumeration parameters in the Feature Documentation.
* pylon AI Agent: [316192] Fixed display issues at certain resolutions and
scaling settings.
* vTools: [313333] The Image Loading vTool can now load recipes with unicode-
paths.
RESTRICTIONS
* pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
improve overall stability and performance. This introduces a new
restriction which affects the video recording feature of the
pylon Viewer. Allowing only 250 images per second and camera in
the imaging pipeline limits the ability to record every frame
when exceeding this limit.
* pylon Viewer: The Color Calibrator does not support all Basler color cameras.
cameras are not supported.
* pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
the Color Calibrator may not work if the camera has already been
opened in the pylon Viewer. To prevent this, close the camera
before using the Color Calibrator.
* pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL
driver for your system. On Debian-based platforms, you also need
to install the following packages: libgl1-mesa-dri, libgl1-mesa-
glx, libxcb-xinerama0, and libxcb-xinput0
* pylon Viewer: Under circumstances, the pylon Viewer may experience issues when
using the Wayland display server protocol. It is recommended to
use Xorg instead.
* pylon Viewer: On Ubuntu 22.04 (or higher), the offline Basler Product
Documentation (BPD) may not be accessible when using Firefox due
to permission restrictions. To work around this issue, you can
set the environment variable TMPDIR to a location in the user's
home directory, use a different browser, or install Firefox from
a different source than snap
* Workbench: Using multiple pin data views actively displaying data in the
Workbench may cause
an increase of the CPU load and degradation of the overall
performance. Basler
recommends using fewer pin data views whenever possible.
* Workbench: The Statistics feature of the Workbench measures the execution
times of vTools.
The times measured in the Statistics feature may vary depending on
the configuration of your
system and the overall CPU load. This is so, because CPUs may run
with different frequencies
depending on the current load (e.g., due to dynamic frequency
scaling).
* Workbench: In case of display errors or missing symbols in the Workbench,
check and update
your graphics card driver or install the OpenGL software emulation
softpipe/llvmpipe.
* CXP IC: For line scan applets, ranges of line period and line exposure aren't
handled properly. The maximum values may be lower than expected.
* CXP IC: Starting with version 24.04, Ubuntu no longer provides libtiff.so.5.
This results in the following error when loading applets: "Unable to
load module library". As a workaround, you can create a symlink to
libtiff.so.6 in "/usr/lib/x86_64-linux-gnu" with the command "sudo ln
-s libtiff.so.6 libtiff.so.5".
* pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
* pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
functionality was added to pylon C to be able to start and stop
streaming explicitly. This functionality has not been documented
in the pylon C programmer's guide yet. Please refer to the pylon
C++ programmer's guide (see chapter "Migrating from Previous
Versions - Changes in the IStreamGrabber API") or the pylonC
OverlappedGrab programming sample.
* pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
usual enumeration for event notifications. The following code
snippets can be used to work around this issue. For C++ you can
use: CBooleanParameter(camera.GetNodeMap(),
"EventNotification").TrySetValue(true); in addition to:
* GigE: In case the error message "Failed to allocate resources." has been
reported, Basler recommends using the pylon GigE Configurator tool to
optimize the IP configuration of NICs and cameras.
* GigE: Multiple IP configurations on a single network interface are not fully
supported by the IP Configurator tool.
* GigE: Assigning a static IP address to a camera that is not in the same subnet
as the network adapter may make the camera unreachable. To prevent this,
set the rp_filter (reverse path filter) to 2 ("loose mode") on the
camera's network interface. For more information, see the Assigning an
IP Address to a Camera topic in the Basler Product Documentation.
* GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
may cause buffer underruns and image loss. In addition, Basler
recommends using the pylon GigE Configurator tool to optimize the
complete setup.
* GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
* MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
to be installed in order to work. The pylon Supplementary Package for
MPEG-4 is available for download on the Basler website.
may fail, if the Quality parameter is set to 80 % or more. As a
workaround, set the Quality parameter to a lower value.
* MP4: The Recording feature doesn't support the Compression Beyond feature in
ace 2 Pro cameras. When recording is started and the Compression Beyond
feature is enabled, the pylon Viewer first disables the Compression Beyond
* 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
blaze to be installed. The pylon Supplementary Package for blaze is
* pylon AI Agent: With certain resolutions and scaling settings, buttons may not
be visible.
