查看: 1338|回复: 0
[驱动] 宝视纳Basler-pylon 8.0.1相机软件套装Linux ARM 64位 - tar.gz:ylon-8.0.1-16188_linux-aarch64
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2024-11-29 14:04:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    宝视纳Basler-pylon 8.0.1相机软件套装Linux ARM 64位 - tar.gz:pylon-8.0.1-16188_linux-aarch64
    文件名: pylon-8.0.1-16188_linux-aarch64_setup.tar.gz
    文件大小: 891218862 字节 (849.93 MB)
    修改日期: 2024-11-05 22:21
    MD5: c5b6058d5328c2c62fb8b3823abc0b79
    SHA1: 19e9e5af1b0fa4bed92e24c314d2692190e305a1
    SHA256: 140c6403119d3b7ea8c0dad8e6bc3464d2d8023eedee8f4fd3048976f30672d1
    CRC32: 163d015c
    Basler官方下载:
    链接:https://pan.baidu.com/s/1DHWw8102p5xint7CPwbG3w
    --来自百度网盘超级会员V7的分享
    pylon 8 Software Suite for Linux
    RELEASE NOTES
    Note: Patch versions of pylon for Linux OS are not released publicly.
    RELEASE DATE:    2024-10-25
    VERSION:         8.0.1 (Linux)
    NEW FEATURES / CHANGES
    * GenTL/CXP: [311175] Restructured existing log messages for compliance with the
                 pylon event logging (PEL) framework.
    * GenTL/CXP: [300706] Added new logging library with enitity IDs to log
                 messages, introduced more along with the modification of the
                 existing ones
    * GenTL/CXP: [314043] Added RPath to fglib5.so so that its dependencies can be
                 found when its loaded directly, without the need to adjust the
                 LD_LIBRARY_PATH
    * pylon Viewer: [316331] Improved pylon Viewer startup time.
    * pylon Viewer: [316268] Updated several icons in different areas of the pylon
                    Viewer, e.g., Workbench and Camera API Generator.
    * Workbench: [316268] The recipe will now be forced to stop if execution isn't
                 finished within 5 seconds after clicking the Stop button in the
                 Workbench toolbar.
    * vTools: [316650] If an input ROI has been specified, the coordinates of the
              output regions (Semantic and Instance Segmentation) and bounding boxes
              (Object Detection and Instance Segmentation) refer to the original
              input image.
              In the previous version, the coordinates were given in relation to the
              ROI.
    * vTools: [316181] Added resources for vTool use cases that show you how to
              perform certain machine vision tasks, e.g., expiry date checks. The
              resources include recipes, sample images, and basic documentation.
    * vTools: [314581] Added new vTools: Data Synchronizer, Image Cropper, Image
              Stitcher, Image Transformer, and Region Combiner.
    CORRECTIONS
    * GenTL/CXP: [300801] Fixed issue of contents of mfs file being empty
    * GenTL/CXP: [303262] Ensured that the HAP files Device xmls include only the
                 process relevant to the current GenTL device, filtering out all
                 others.
    * GenTL/CXP: [315763] Removed caching from HAP XMLs as the register dependencies
                 are not exported by the HAP file.
    * GenTL/CXP: [303265] Prepended process identifiers to device names when
                 multiple DMA acquisition channels per VA process exist, ensuring
                 clear association of DMAs within the same process.
    * GenTL/CXP: [234116] Added functionality for FG-SDK to run and load applets
                 from paths with non-latin characters
    * GenTL/CXP: [273529] Added support for Ubuntu 20.04,  22.04 and discontinued
                 supporting Ubuntu 18.04.
    * GenTL/CXP: [300663] Added support for imaFlex Penta framegrabber
    * GenTL/CXP: [316313] Before fixing this issue, many log messages contained
                 redundant information. This has been fixed.
                 Now, additional information (tags) is placed in trace level
                 messages behind the actual message text.
    * pylon Viewer: [315618] The Data Privacy option in the Help menu now has the
                    correct icon.
    * pylon Viewer: [315593] Corrected the sample code generated for vTool
                    enumeration parameters in the Feature Documentation.
    * pylon AI Agent: [316192] Fixed display issues at certain resolutions and
                      scaling settings.
    * vTools: [313333] The Image Loading vTool can now load recipes with unicode-
              paths.
    RESTRICTIONS
    * pylon Viewer: A new image throttle has been implemented in the pylon Viewer to
                    improve overall stability and performance. This introduces a new
                    restriction which affects the video recording feature of the
                    pylon Viewer. Allowing only 250 images per second and camera in
                    the imaging pipeline limits the ability to record every frame
                    when exceeding this limit.
    * pylon Viewer: The Color Calibrator does not support all Basler color cameras.
                    cameras are not supported.
    * pylon Viewer: Under certain circumstances, e.g., a very slow or busy computer,
                    the Color Calibrator may not work if the camera has already been
                    opened in the pylon Viewer. To prevent this, close the camera
                    before using the Color Calibrator.
    * pylon Viewer: To use the pylon Viewer, you must install the latest Mesa OpenGL
                    driver for your system. On Debian-based platforms, you also need
                    to install the following packages: libgl1-mesa-dri, libgl1-mesa-
                    glx, libxcb-xinerama0, and libxcb-xinput0
    * pylon Viewer: Under circumstances, the pylon Viewer may experience issues when
                    using the Wayland display server protocol. It is recommended to
                    use Xorg instead.
    * pylon Viewer: On Ubuntu 22.04 (or higher), the offline Basler Product
                    Documentation (BPD) may not be accessible when using Firefox due
                    to permission restrictions. To work around this issue, you can
                    set the environment variable TMPDIR to a location in the user's
                    home directory, use a different browser, or install Firefox from
                    a different source than snap
    * Workbench: Using multiple pin data views actively displaying data in the
                 Workbench may cause
                 an increase of the CPU load and degradation of the overall
                 performance. Basler
                 recommends using fewer pin data views whenever possible.
    * Workbench: The Statistics feature of the Workbench measures the execution
                 times of vTools.
                 The times measured in the Statistics feature may vary depending on
                 the configuration of your
                 system and the overall CPU load. This is so, because CPUs may run
                 with different frequencies
                 depending on the current load (e.g., due to dynamic frequency
                 scaling).
    * Workbench: In case of display errors or missing symbols in the Workbench,
                 check and update
                 your graphics card driver or install the OpenGL software emulation
                 softpipe/llvmpipe.
    * CXP IC: For line scan applets, ranges of line period and line exposure aren't
              handled properly. The maximum values may be lower than expected.
    * CXP IC: Starting with version 24.04, Ubuntu no longer provides libtiff.so.5.
              This results in the following error when loading applets: "Unable to
              load module library". As a workaround, you can create a symlink to
              libtiff.so.6 in "/usr/lib/x86_64-linux-gnu" with the command "sudo ln
              -s libtiff.so.6 libtiff.so.5".
    * pylon C SDK: The pylon C API doesn't provide convenient functions to use GenDC
    * pylon C SDK: For using the GenTL Consumer (e.g., with CoaXPress), additional
                   functionality was added to pylon C to be able to start and stop
                   streaming explicitly. This functionality has not been documented
                   in the pylon C programmer's guide yet. Please refer to the pylon
                   C++ programmer's guide (see chapter "Migrating from Previous
                   Versions - Changes in the IStreamGrabber API") or the pylonC
                   OverlappedGrab programming sample.
    * pylon C++ SDK: Some ace 2 cameras may use a Boolean parameter instead of the
                     usual enumeration for event notifications. The following code
                     snippets can be used to work around this issue. For C++ you can
                     use: CBooleanParameter(camera.GetNodeMap(),
                     "EventNotification").TrySetValue(true); in addition to:
    * GigE: In case the error message "Failed to allocate resources." has been
            reported, Basler recommends using the pylon GigE Configurator tool to
            optimize the IP configuration of NICs and cameras.
    * GigE: Multiple IP configurations on a single network interface are not fully
            supported by the IP Configurator tool.
    * GigE: Assigning a static IP address to a camera that is not in the same subnet
            as the network adapter may make the camera unreachable. To prevent this,
            set the rp_filter (reverse path filter) to 2 ("loose mode") on the
            camera's network interface. For more information, see the Assigning an
            IP Address to a Camera topic in the Basler Product Documentation.
    * GigE: For optimum use of Basler's ace 2 5GigE and 1GigE cameras, Basler
            recommends using dual-channel DDR4-3600 RAM or better. Using slower RAM
            may cause buffer underruns and image loss. In addition, Basler
            recommends using the pylon GigE Configurator tool to optimize the
            complete setup.
    * GenTL: Limited GenTL support for producers with GenTL version 1.4 and below.
    * MP4: MP4 video recording requires the pylon Supplementary Package for MPEG-4
           to be installed in order to work. The pylon Supplementary Package for
           MPEG-4 is available for download on the Basler website.
           may fail, if the Quality parameter is set to 80 % or more. As a
           workaround, set the Quality parameter to a lower value.
    * MP4: The Recording feature doesn't support the Compression Beyond feature in
           ace 2 Pro cameras. When recording is started and the Compression Beyond
           feature is enabled, the pylon Viewer first disables the Compression Beyond
    * 3D: Using Basler blaze 3D cameras requires the pylon Supplementary Package for
          blaze to be installed. The pylon Supplementary Package for blaze is
    * pylon AI Agent: With certain resolutions and scaling settings, buttons may not
                      be visible.
    GMT+8, 2026-4-17 11:12
