查看: 1075|回复: 0
[驱动] 宝视纳Basler-适用于Windows 64位系统的VisualApplets(3.5.0版):VAsetup3.5.0.71573
    3 小时前
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2024-11-29 14:24:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VisualApplets is the integrated development environment for real-time applications on FPGA processors in image processing. It allows FPGAs to be programmed using data flow models on a graphical user interface. This solution is used for industrial and non-industrial applications in a wide range of industries. VisualApplets provides access to the FPGA processors of image processing hardware (such as frame grabbers, industrial cameras and image processing devices) to enable unique image processing applications.
    The VisualApplets version 3.5.0 supports the new frame grabber platform imaFlex CXP-12 Penta and now uses UltraRAM. The event engine will now be able to transfer data structures. The release also provides several new operators, along with an extended and improved parameter interface.
    Further information on new examples, additions, and fixes can be found in the release notes.
    文件名: VAsetup3.5.0.71573.exe
    文件大小: 545236304 字节 (519.98 MB)
    修改日期: 2024-10-24 18:45
    版本: 0.0.0.0
    MD5: e6e902d5995ae6a9d5307b370962a2e7
    SHA1: 041ce6116045bf4a786507031d0828ad5ca13ecd
    SHA256: 428427acf636d7bd7989f137c64af90a0cb4dae04ea9324d073a3ec7d3ff3bda
    CRC32: 18398167
    Basler官方下载:
    链接:https://pan.baidu.com/s/1mJyohcJVQMYxPA5zJ3PF5Q
    --来自百度网盘超级会员V7的分享
    RELEASE NOTES
    Release Notes for VisualApplets 3.5.0 | Basler
    GMT+8, 2026-4-17 11:14
