查看: 10889|回复: 1
[NI软件产品] NI Vision Builder for Automated Inspection 2013SP1 Win32Eng 自动检测视觉生成器VBAI2013SP1下载 LabVIEW2013SP1版适用
    1 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2014-5-19 22:36:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 移动
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    标准下载:
    请购买附件下载查看
    下载器下载:
    请购买附件下载查看
    VBAI2013SP1.txt (385 Bytes, 下载次数: 70, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2013 SP1 Readme
    April 2014
    This file contains important information about National Instruments Vision Builder for Automated Inspection and is organized into the following sections:
    Activation Instructions
    Updates and Improvements
    Remote Target Support
    PC-Based Image Acquisition and I/O Support
    Additional Resources
    Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Builder for Automated Inspection.
    To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
    MinimumRecommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024 × 768 resolution video adapter with a 24- or 32-bit display1,280 × 1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    Microsoft Windows 8 (64-bit and 32-bit)/7 (64-bit and 32-bit)/Vista (64-bit and 32-bit)/XP SP3/Server 2003 R2 (32-bit)/Server 2008 R2 (64-bit)
    Browser
    Microsoft Internet Explorer 6.0 or later
    Hard Disk Space
    1 GB
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    If you do not activate a valid license, Vision Builder AI runs in evaluation mode and continues to prompt you to activate a license on each launch. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Enter your serial number, and click Next.
    • You can enter an email address to receive a copy of the activation code for your records.
    The following list describes the changes and enhancements in Vision Builder AI 2013:
    Added support for the NI CVS-1457RTThe NI CVS-1457RT GigE Vision compact vision system is now supported.Updated Acquire Image (1394, GigE, or USB) stepThe Acquire Image (1394, GigE, or USB) step has been updated to support acquiring images from USB 3 Vision cameras.Updated Simulate Acquisition StepThe Simulate Acquisition step has been updated to support AVI files, accept a path to a folder of images, and use a result produced by a previous step as the image file path.Updated Filter Image StepThe Filter Image step has been updated to accept kernels larger than 7×7.Updated Create Region of Interest StepThe Create Region of Interest step has been updated to accept coordinates in real-world units on calibrated images. A new Magic Wand ROI type has been added, along with new controls specific to the Magic Wand ROI type. ROI coordinates can now be offset by a constant.Updated Match Pattern StepThe Match Pattern step has been updated to support Grayscale Value Pyramid and Gradient Pyramid algorithms. Users can configure advanced pattern matching parameters and values in Adv. Options.Added Track Object StepUse the Object Tracking step to track objects from one frame to the next in a sequence of images. The object tracking step enables users to define an object to track, specify the function of the track object step (Track Object, Set Position, Learn Object), configure the settings of the object tracking step, and set the limits of the step status.Updated Read/Verify Text StepThe Read/Verify text step has been updated to support new threshold modes, character size controls, new algorithms to separate characters, read and verify text on multiple lines, and tolerate small misalignment of character lines.Updated Communication Device ManagerThe Communication Device Manager has been updated to simplify server and client configuration, and to support OPC UA device configuration.Added support for NI CompactDAQ devices with USB connectors on real-time targetsNI 177x smart cameras, NI EVS, and NI CVS-1457RT targets support NI-DAQmx analog and digital read/write I/O with the NI cDAQ-9171, NI cDAQ-9174, and NI cDAQ-9178 chassis.Added OPC UA StepUse the OPC UA step to allow Vision Builder AI to communicate with an OPC UA device. In this step, users configure the items that Vision Builder AI reads and writes to a device, as well as the sequence in which Vision Builder AI communicates these items to a device.Updated Vision Pulse RIO StepThe Generate Pulse (Vision RIO) step has been updated to support an action to query the pulse queue status.Added Set Variable VIA Set Variable VI has been added to the LabVIEW API to allow users to set variable values from LabVIEW.
    Updates and Improvements to Vision Builder AI
    The following list describes issues in previous versions of the NI Vision Builder for Automated Inspection that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Builder for Automated Inspection.
    286686The Simulate Acquisition step crashes when reading some TIFF image files.
    363415The Read 2D Barcode step does not support rotated or flipped rectangle Data Matrix barcodes.
    403508The Simulate Acquisition step cannot read some uncompressed AVIs.
    415530When using the Calibration Training Interface to learn a new calibration, the angle of the calibration axis might not be set correctly in specific cases.
    424322The Read/Verify Text step does not detect very small characters when the Auto Detect Multiline and Rotation option is enabled.
    427986The Geometric Matching step may return incorrect calibrated results for some axis angles.
    430001The Simulate Acquisition and Image Logging steps cannot use extended ASCII characters in the path of AVI files.
    432149The Read 2D Barcode step may crash when reading Data Matrix codes.
    432530The Geometric Matching step may crash when the image is calibrated and uses an indirect calibration axis.
    432798The Caliper step returns more repeatable results when measuring two parallel edges.
    434609Read/Verify Text step migrates incorrectly to Vision Builder AI 2013. The Verify Text character option becomes the Read Text character option.
    435703When run on an RT target, Run LabVIEW VI steps produce regions of interest that subsequent steps cannot use.
    436890The Digital Output Polarity column of the Read/Write I/O (NI-DAQmx) step does not update when editing the step.
    437153The Image Logging step incorrectly returns a disk full error when running on an NI EVS.
    438834The Data Logging step may return an unknown internal error when the number of measurements to log exceeds 255.
    438920Using the Vision Builder AI LabVIEW API to open an inspection that contains a Run LabVIEW VI step with a relative VI Path produces error 0xFFFA9607.
    439066The Filter Image step returns a black image when using a 7×7 convolution kernel with only 1's on the first row.
    439072Choosing a Kernel Size of 7 or greater in the Filter Image step produces a larger kernel than necessary.
    439144When editing the Create ROI step, Magic Wand parameters return to default values.
    439202Kernel values cannot be edited in the Filter Image step when the selected Filter Type is Custom.
    439253When connected to a simulated EVS target, Read/Write I/O (Vision RIO) and Generate Pulse (Vision RIO) steps do not show TTL Output lines 8 and 9.
    440607In the Calibration Training Interface, an invalid coordinate system error is returned when editing the calibration axis.
    441108The Read/Write Variables to INI File step does not read variables with a space between the name of the key and the equal sign.
    441174Inputting an array into the Calculator step returns a scalar.
    443433The Read/Write I/O (DAQmx) step ignores the Invert option when using a previous measurement.
    446419In the Vision Builder AI LabVIEW API, the Get Measurements VI does not return a result when an inspection contains a large number of steps.
    451770Placing an Acquire Image step in multiple states may acquire images with incorrect camera attributes.
    466527When Generate Pulse (Vision RIO) steps use multiple instances of Vision Builder AI on the same device, the steps may generate incorrect pulses.
    You can use Vision Builder AI to remotely configure and control a supported remote target. Vision Builder AI supports the following remote targets:
    • NI 17xx Smart Cameras
    • NI 177x Smart Cameras
    • NI CVS-1457RT Compact Vision Systems
    • NI EVS-1463RT Embedded Vision Systems
    • NI EVS-1464RT Embedded Vision Systems
    Note: Vision Builder AI no longer provides support for the NI 1762 Smart Camera, the NI 1764 Smart Camera, and NI CVS-1450 Series Compact Vision Systems.
    To use Vision Builder AI with a remote target, you must use Vision Builder AI to configure the remote target. For more information about using Vision Builder AI to configure the remote target, refer to the documentation included with the remote target.
    The following table illustrates when a remote target requires you to install driver software on the development computer.
    Remote Target or Camera
    Connected to a Remote Target
    Requires Driver Software Installed
    on Development Computer
    NI Smart Camera
    No
    IEEE 1394
    No
    GigE Vision
    No
    Camera Link
    Yes
    Note: To acquire images from a Camera Link camera attached to a NI EVS-1463RT device, you must use MAX to associate a camera file with the camera. For information about how to associate a camera file with a Camera Link camera connected to a remote target, visit ni.com/info and enter the info code rtcamerafile.
    Vision Builder AI supports the following types of image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • Digital or analog I/O from NI data acquisition (DAQ) devices
    • Serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the development computer.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports National Instruments image acquisition devices that require NI-IMAQ driver version 4.6.4 or later. Specific devices may require later versions.
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    This version of Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, USB 3 Vision, DirectShow-compatible USB cameras, IP cameras, and requires NI-IMAQdx driver version 3.3 or later. Specific devices may require later versions.
    To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Virtual Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    Licensing Options
    Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Run-Time (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Builder for Automated Inspection.
    • Using a TCP slave device with the Vision Builder AI LabVIEW API and Vision Builder AI simultaneously can cause the device to stop communicating.
    • Vision Builder AI behaves unexpectedly or may not display an inspection image if the image is large and the host machine is low on available memory.
    • If you configure a step to PASS or FAIL based on pixel distances and subsequently calibrate an image, the step compares calibrated values against pixel-based limits.
    • If you connect to a remote target, start an inspection in the Vision Builder AI Configuration interface, lose connection to the target, and then reconnect, the inspection opens in the Vision Builder AI Inspection interface.
    • The tab allowing setup of the secondary ethernet port(s) might not initialize properly the first time the Target Options dialog opens after formatting a target. Subsequent calls to the dialog work as expected.
    LabVIEW Project Integration
    (LabVIEW 2010) You can create a new VI in the context of a remote target added in Vision Builder AI Mode. A VI created in this context cannot run or support shared variables. If you try to add a shared variable to the VI, the VI generates an error message indicating that the target does not support shared variables. Always create a VI in the context of My Computer or a remote target added in LabVIEW Real-Time Mode.
    Windows Firewall
    If you are using the Windows Firewall, you may notice the following behavior:
    • Microsoft Windows 7, Windows Vista, Windows Server 2008, Windows Server 2003, or Windows XP with Service Pack 2 (SP2) or later installed
      When you launch Vision Builder AI, a dialog box may prompt you to allow Vision Builder AI to receive information over the network. Depending on your operating system, select Allow access or Unblock this program so that Vision Builder AI can communicate with your remote target.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    • NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provides with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and NI Technical Support at ni.com/support for the most up-to-date information about Vision Builder AI.
    Using NI Launcher
    Finding All Programs
    NI Vision Builder for Automated Inspection Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Vision Builder for Automated Inspection will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Vision Builder for Automated Inspection that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2014 National Instruments Corporation. All rights reserved.
    The registered trademark Linux® is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
    头像被屏蔽
    发表于 2015-10-31 19:26:53 | 显示全部楼层 来自:广东省深圳市 电信
    GMT+8, 2026-4-8 09:19
