查看: 602|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite 2025 Q3 Patch 2 Win11 64bitEn 嵌入式控制和监控软件套件2025Q3英文版ECMSS25.5.2
    半小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2025-10-10 09:07:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
    Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
    发布日期:2025/8/7
    包含的版本:2025 Q3 F2专业版,版本号25.5.2
    Windows Server 2025
    语言:英文English
    文件大小: 30256381952 字节 (28.18 GB)
    修改日期: 2025-08-20 18:48
    MD5: 92eef7ae490f184e93afc20ec06315f2
    SHA1: 3d3456a72e5feae403a81787080f081d3115c71a
    SHA256: f0c73ec004825ec357d5636ebf632fa1270bda6e88147f414f9b8bfb84f68cff
    CRC32: f52ee3ea
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    ECMS2025Q3F2x64En.txt (687 Bytes, 下载次数: 0, 售价: 40 圆)
    套件包含:
    编程环境
    ProductVersionBitness
    LabVIEW2025 Q3 Patch 232-bit and 64-bit
    G Web Development Software2022 Q364-bit
    附加软件
    LabVIEW Real-Time Module2025 Q132-bit and 64-bit
    LabVIEW FPGA Module2025 Q132-bit and 64-bit
    LabVIEW Datalogging and  Supervisory Control Module2025 Q332-bit
    LabVIEW Datalogging and  Supervisory Control Runtime2025 Q332-bit
    LabVIEW FPGA Compile Farm  Toolkit2025 Q132-bit and 64-bit
    JKI VI Package Manager2025 Q332-bit and 64-bit
    Vision Development Module2025 Q332-bit and 64-bit
    LabVIEW FPGA Compilation Tool  for Vivado 2021.12025 Q132-bit and 64-bit
    驱动程序
    NI CompactRIO2025 Q332-bit and 64-bit
    NI-DAQmx2025 Q332-bit and 64-bit
    NI-Serial2025 Q332-bit and 64-bit
    NI-VISA2025 Q332-bit and 64-bit
    NI-XNET2025 Q332-bit and 64-bit
    FlexRIO with Modular I/O2025 Q332-bit and 64-bit
    FlexRIO with Integrated I/O2025 Q332-bit and 64-bit
    FPGA Interface C API20.0.032-bit and 64-bit
    NI-Sync2025 Q332-bit and 64-bit
    NI R系列多功能RIO2025 Q332-bit and 64-bit
    NI Vision Acquisition Software (包含IMAQ,  IMAQdx, IMAQ I/O)2025 Q332-bit and 64-bit
    2025Q3未更新自述文件,参考2023Q1版
    Embedded Control and Monitoring Software Suite 2023 Q1自述文件
    2023年1月
    本文件包含Embedded Control and Monitoring Software Suite 2023 Q1的安装说明和兼容性信息。
    您可以在ni.com上找到更多关于此次发行的信息。
    • Embedded Control and Monitoring Software Suite发行说明:已知问题,自上一发行版以来已修复的错误以及关于此次发行的说明信息。
    系统要求
    操作系统支持
    Embedded Control and Monitoring Software Suite中包含的产品
    安装说明
    支持的硬件
    查找范例
    自动安装NI产品
    在Microsoft Windows 11中使用NI软件
    不支持的Windows操作系统
    NI不再支持Phar Lap ETS实时操作系统
    系统要求
    系统要求见各产品的自述文件。
    操作系统支持
    Embedded Control and Monitoring Software Suite 2023 Q1支持以下操作系统:
    Embedded Control and Monitoring Software Suite安装程序中包含以下产品。该表可能未包含可通过您的套件序列号激活的产品的完整列表。关于系统要求、产品安装、激活、已知问题和问题修正的更多信息,请参考具体产品的自述文件。
    应用程序软件
    产品
    版本
    位数
    LabVIEW2023 Q132位和64位
    注:本产品不再支持LabVIEW NXG。关于LabVIEW NXG生命周期日期和驱动程序版本支持的更多信息,请访问ni.com上的LabVIEW NXG。
    附加软件
    产品
    版本
    位数
    FPGA Interface C API202032位和64位
    JKI VI Package Manager2023 Q132位和64位
    LabVIEW FPGA Compilation Tool for Vivado 2021.12022 Q364位
    LabVIEW FPGA Compile Farm工具包2023 Q132位和64位
    LabVIEW FPGA模块2023 Q132位和64位
    LabVIEW Real-Time模块2023 Q132位和64位
    Vision Development模块2023 Q132位和64位
    注:LabVIEW专业版开发系统将安装LabVIEW Advanced Signal Processing工具包、LabVIEW Desktop Execution Trace工具包、LabVIEW Digital Filter Design工具包、LabVIEW Unit Test Framework工具包、LabVIEW VI Analyzer工具包、LabVIEW Database Connectivity工具包和LabVIEW Report Generation工具包。labview\readme目录下可找到这些工具包的自述文件。
    驱动程序
    产品
    版本
    位数
    FlexRIO with Integrated I/O2023 Q132位和64位
    FlexRIO with Modular I/O2023 Q132位和64位
    NI CompactRIO2023 Q132位和64位
    NI-DAQmx2023 Q132位和64位
    NI-Industrial Communications for EtherNet/IP2022 Q332位和64位
    NI-Serial21.532位和64位
    NI-Sync2023 Q132位和64位
    NI-VISA2022 Q332位和64位
    NI-XNET2023 Q132位和64位
    R系列2023 Q132位和64位
    注:本版本中不包含之前版本Embedded Control and Monitoring Software Suite中包含的部分驱动程序。如需最新驱动程序版本,请访问ni.com/downloads。
    Microsoft Visual Studio支持
    如使用Embedded Control and Monitoring Software Suite .NET Class Library,至少需要.NET Framework 4.0。在面向.Net Framework 4.0或.NET Framework 4.5的Visual Studio版本中,Embedded Control and Monitoring Suite 2023 Q1 .NET Class Library可与Visual C#或Visual Basic .NET配合使用。
    如要使用.NET API,除安装NI设备驱动程序外,还必须安装.NET类库或.NET包装器。关于.NET Framework和驱动程序支持的版本信息,及安装文件的下载地址,请访问NI软硬件的.NET资源。
    安装说明
    从ni.com/downloads下载Embedded Control and Monitoring Software Suite。NI软件包含用于管理安装的NI Package Manager。关于使用Package Manager安装、移除、更新NI软件的详细信息,请参考NI Package Manager手册。
    说明
    • 使用软件附带的序列号激活Embedded Control and Monitoring Software Suite。关于Embedded Control and Monitoring Software Suite激活的更多信息,请参考激活产品。
    支持的硬件
    要查看设备信息:
    查找范例
    范例查找位置见各产品的自述文件。
    自动安装NI产品
    不支持的Windows操作系统
    Embedded Control and Monitoring Software Suite不再支持Windows Vista/XP/7/8.x、Windows Server 2003/2008/2012或其他32位Windows操作系统。本产品在2021年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。关于NI操作系统支持的详细信息,请访问https://www.ni.com/r/win32bitsupport
    NI软件不再支持Phar Lap ETS实时操作系统本产品在2022年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。有关Phar Lap及其替代产品NI Linux Real-Time的支持路线图的高层信息,请访问ni.com/r/xf35k1。如需了解运行NI Linux Real-Time的PXI控制器支持的硬件信息,请访问ni.com/r/b7g5wi。
    GMT+8, 2026-4-8 08:46
