查看: 466|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2025 Q4 Patch 1 Win11 32/64bitEng NI-RFSG回放库25.8.1
    9 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
     楼主| 发表于 2025-11-14 08:54:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2025/10/19
    包含的版本:2025 Q4 Patch 1完整版,版本号25.8.1
    Windows Server 2025
    语言:英文English
    32/64位完整版校验和:
    文件大小: 1044891648 字节 (996.49 MB)
    修改日期: 2025-11-03 08:54
    MD5: 77062a21be4ff2ba32d29924e2420643
    SHA1: fac80f97f225e0872e5bc075b99065513fed799c
    SHA256: c4da3bf29383cacdb927ab22fadb18eb651468c7ccc1ccd19f681c50e533702d
    CRC32: 63f2168f
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    NI-RFSG Playback Library2025Q4F1.txt (594 Bytes, 下载次数: 0, 售价: 10 圆)
    32/64位运行版校验和:
    文件大小: 594124800 字节 (566.60 MB)
    修改日期: 2025-11-03 08:55
    MD5: 40a1301dae743d008cd5b6f59cf9c7cc
    SHA1: f831436a110def582fb01e50852ce4fdf495cef7
    SHA256: e6cf66765727db89a94fe3e9757c41a54439afdf4417d887e1c50d3f19c827d0
    CRC32: ef1df28e
    NI-RFSG Playback Library2025Q4RTEF1.txt (619 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q4Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG Playback Library 2023 Q3 Readme
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    NI-RFSG Playback Library 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1 (32-bit and 64-bit)
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2023 Q3 supports the following 64-bit operating systems:
    * NI-RFSG .NET Class Library is required only for .NET support.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2026-4-9 17:32
