查看: 475|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2025 Q4 Win11 64bitENG RFmx蜂窝测试TD-SCDMA25.8.0
 楼主| 发表于 2025-11-18 10:22:52 | 显示全部楼层 |阅读模式
RFmx TD-SCDMA
发布日期:2025/10/10
包含的版本:2025 Q4完整版/运行版,版本号25.8.0
Windows Server 2025
64位完整版校验和:
文件大小: 3137824768 字节 (2.92 GB)
修改日期: 2025-11-03 08:58
MD5: 72bcb162d2ccf054b111019999b91bf2
SHA1: c2ddddbe3ca70bfd563ebee347fc704e42c867bd
SHA256: d5731aa89fe5f899a706f0d6433e8276f80dfe5b3e5741c8dd28bbc6be5838bb
CRC32: c891a3d2
请注册登录机器视觉论坛用户,购买附件查看下载地址
RFmx TD-SCDMA2025Q4.txt (546 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1025402880 字节 (977.90 MB)
修改日期: 2025-11-03 08:59
MD5: efc7ff18783b8f86c616f8696bbbc95f
SHA1: a93a05a8e436b05ae896463a234349ee0f576cc3
SHA256: 768b6d2de00e40cd1342d00b7851475550e5ed9bfc198a83ac3b6f28e2f45f63
CRC32: 53174b38
请注册登录视觉机器论坛用户,购买附件查看下载地址
RFmx TD-SCDMA2025Q4RTE.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
2025Q4未更新自述文件,参考2023Q3版本
RFmx TD-SCDMA 2023 Q3 Readme
  • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
  • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
RFmx TD-SCDMA 2023 Q2 includes the following new feature:
RFmx TD-SCDMA 2023 Q1 includes the following new feature:
RFmx TD-SCDMA 2022 Q4 includes the following new feature:
  • Support for PXIe-5842
RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
Versions Supported by RFmx TD-SCDMA (64-bit only)
  • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
Item
Installed Location
Import Library files
RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
  • RFmx TD-SCDMA drops support for 32-bit user mode.
The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
QQ|LabVIEW视觉
GMT+8, 2026-4-8 12:40
