查看: 470|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2025 Q4 Patch 1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA25.8.1
 楼主| 发表于 2025-11-18 10:26:12 | 显示全部楼层 |阅读模式
RFmx TD-SCDMA
发布日期:2025/10/19
包含的版本:2025 Q4 Patch 1完整版/运行版,版本号25.8.1
Windows Server 2025
64位完整版校验和:
文件大小: 3137845248 字节 (2.92 GB)
修改日期: 2025-11-03 08:59
MD5: aac4b8984c8c6af2972013175fe4a513
SHA1: 0cea7fba9ffc88b8b47ecd8cce187668b7d88954
SHA256: fe73ab01ab8f101afb0a77a472a293eda6c40b7c4af68daff0b17f0071162620
CRC32: e102934b
请注册登录机器视觉论坛用户,购买附件查看下载地址
RFmx TD-SCDMA2025Q4F1.txt (554 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1025423360 字节 (977.92 MB)
MD5: fca2b6a66aecf950918b2b4e3caa4df0
SHA1: 176e34dcd145e885bc392655545578b1e63190bc
SHA256: 5bdac7d091b55bf8c290651584ab7f78aeeefc71ac35c35be2fd49b7ea4c93e9
CRC32: 6e9a354c
请注册登录视觉机器论坛用户,购买附件查看下载地址
RFmx TD-SCDMA2025Q4RTEF1.txt (579 Bytes, 下载次数: 0, 售价: 5 圆)
2025Q4 Patch 1未更新自述文件,参考2023Q3版本
RFmx TD-SCDMA 2023 Q3 Readme
  • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
  • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
RFmx TD-SCDMA 2023 Q2 includes the following new feature:
RFmx TD-SCDMA 2023 Q1 includes the following new feature:
RFmx TD-SCDMA 2022 Q4 includes the following new feature:
  • Support for PXIe-5842
RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
Versions Supported by RFmx TD-SCDMA (64-bit only)
  • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
Item
Installed Location
Import Library files
RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
  • RFmx TD-SCDMA drops support for 32-bit user mode.
The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
QQ|LabVIEW视觉
GMT+8, 2026-4-8 12:37
