NI RFmx Waveform Creator 2025 Q4 Win11 32/64bitENG RFmx波形创造器25.8.0
RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
发布日期:2025/10/10
包含的版本:2025 Q4完整版,版本号25.8.0
Windows Server 2025
文件大小: 1562630144 字节 (1.46 GB)
修改日期: 2025-11-03 10:31
MD5: 30e418cc1ab13861c41c5933fa64481b
SHA1: 02d21146deb0e6a0b56b9b0fd558d1e494cd9ebd
SHA256: ad35f26ad40289242db6ce2338bd06d41d83f52d6b0ab12434752d156ddfaf57
CRC32: ddb6d282
请注册登录机器视觉论坛用户,购买附件查看下载地址
RFmx Waveform Creator 2025 Q4 Changes
Learn about new features, behavior changes, and other updates in RFmx Waveform Creator 2025 Q4. New Features
- Support for 802.11bn waveform creation compliant with IEEE P802.11bn/D1.0 specification covering salient features like Distributed RUs including 60MHz variant, Unequal Modulation, 2x LDPC Encoding, New MCS indices, Enhanced long range (ELR) and Interference Mitigation.
- Exposed granular APIs to support multi-block user configurable packet creation for Bluetooth LE HDT packet Format 1.
- Support for Bluetooth LE HDT packet creation with Constant Tone Extension.
- Support for NR FRCs for UL NTN.
- The range of Payload Length (bytes) has been changed from [0–510] to [0–508] when the direction-finding mode is set to Angle of Arrival or Angle of Departure for HDT Format0 packets.
2025Q4版未更新自述文件,参考2023Q3版本
RFmx Waveform Creator 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx Waveform Creator, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx Waveform Creator Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx Waveform Creator Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Executable Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx Waveform Creator 2023 Q3 includes the following new features: - Support for Pulse library
- Single pulse generation
- Pulse Types: Trapezoidal, Raised Cosine, Custom Profile, Custom IQ
- Modulation: BPSK, QPSK, LFM, AM/FM step, Barker code
- Pulse Parameters
- Rise Time, Fall Time, Pulse Width
- Droop, Overshoot, Ripple
- Updated 802.11be standard support to comply with IEEE P802.11be/D3.2 specification
RFmx Waveform Creator 2023 Q2 includes the following new features: - Generation API support added to RFmx Waveform Creator for Bluetooth®
- Updated 802.11be standard support to comply with IEEE P802.11be/D3.0 specification
- Support for UL FRC tables A.1-1a and A.2-1a with interlaced RB allocations
- .NET Class Library support for generation APIs of WLAN standard
RFmx Waveform Creator 2023 Q1 includes the following new features: - Support for Unframed Data Modulation for 802.11be standard
- Updated 802.11be standard support to comply with IEEE P802.11be/D2.3 specification
- Support for new reference channels for timing adjustment in UL FRC Table A.10 for Frequency Range 2 as per 3GPP Release 17 (September-2022)
- Support for LabVIEW 2023 Q1 (64-bit)
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx Waveform Creator has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx Waveform Creator 2023 Q2 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx Waveform Creator no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Waveform Creator 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Waveform Creator 2023 Q3 to an unsupported OS. Additionally, after installing RFmx Waveform Creator 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx Waveform Creator supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Waveform Creator. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx Waveform Creator (64-bit only) | | LabVIEW | 2020 SP1, 2021, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSG 14.5 or later
- NI-RFSG 20.7 or later (for MIMO configurations with PXIe-5830/5831/5832 in RFmx Waveform Creator for WLAN)
Microsoft Visual Studio SupportIf you are using the RFmx Waveform Creator .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Waveform Creator .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx Waveform Creator installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
- Use the serial number that is included with your software to activate RFmx Waveform Creator. For more information on RFmx Waveform Creator activation, refer to National Instruments Software Activation.
ExecutableSelect Start » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator. Accessing the DocumentationDocumentation for RFmx Waveform Creator is located at Start » National Instruments » RFmx Waveform Creator Documentation. Finding ExamplesYou can access all the installed RFmx Waveform Creator examples at Start » National Instruments » RFmx Waveform Creator Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following items are the behavior changes in RFmx Waveform Creator 2023 Q3 from RFmx Waveform Creator 2023 Q1 - FR2-1 DL FRCs are now supported with two frames.
The following items are the behavior changes in RFmx Waveform Creator 2023 Q1 from RFmx Waveform Creator 2022 Q4 - Uplink reference channels G-FR1-A5-15 and G-FR1-A5-16 now support interlaced RB allocation.
The following items are the behavior changes in RFmx Waveform Creator 2022 Q3 from RFmx Waveform Creator 21.8.2. - Default value of WLAN Oversampling Ratio control changed to 1.25.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
