查看: 585|回复: 0
[NI驱动程序] NI Vision Common Resources 2020 SP2 Win32/64Eng 视觉公共资源VCR20.7.0
    7 小时前
     楼主| 发表于 2025-11-21 08:51:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    借助Vision Common Resources,您可以使用基本机器视觉功能来开发和部署应用程序。
    Vision Common Resources是一款驱动软件,在Windows硬件或NI Linux Real-Time硬件上均支持NI Vision图像管理函数、图像显示控件和图像共享变量。Vision Development模块可提供全面的及其视觉支持。
    注册商标Linux®的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux®注册商标在全球范围内的所有权。
    - 隐藏内容
    注:安装该产品前,请先安装对应的编程环境。例如,NI LabVIEW或Microsoft Visual Studio®。
    VCR应该没有许可证要求,是视觉软件运行的必要组件之一。VCR作为VDM中的一部分,之前的某些年代版本可能没有提供单独的VCR驱动,只能在打包安装程序时,将VDM中的VCR打包到视觉软件的安装程序中进行安装或者直接安装完整版VDM。
    发布日期:2021/4/21
    包含的版本:2020SP2完整版,版本号20.7.0
    语言:English英文
    文件大小: 1206683648 字节 (1.12 GB)
    修改日期: 2025-11-03 14:21
    MD5: 5370e28a4570728395c0324af7e30f14
    SHA1: be0ef319c5f0d89499f45437cc5cf112aeca6cc8
    SHA256: 09cfca38dc863786d504e637be9518b0aba2ad9a3d36c6c8ede029dbc43c4979
    CRC32: e1021912
    百度网盘和NI官方离线下载地址:
    请注册视觉论坛会员登录后购买附件下载查看
    Vision Common Resources 2020 SP2.txt (584 Bytes, 下载次数: 0, 售价: 5 圆)
    VCR没有单独的自述文件,请参考VDM的自述文件。
    NI Vision Development Module 2020 SP2 Readme
    April 2021
    This file contains important information about NI Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    • NI Vision Development Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI Vision Development Module Manuals: New features, behavior changes, and other documentation
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    External Library Support
    The NI Vision Development Module (VDM) provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/labview/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    Minimum
    Recommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display (Vision Assistant)1,152 × 864 resolution video adapter with a 16-bit display1,152 × 864 resolution video adapter with a 24- or 32-bit display
    Display (other environments)1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    Supported Operating Systems(不支持Win7及任何32位操作系统)
    NI Vision Development Module 2020 SP2 supports the following operating systems:
    • Windows 10 (64-bit)
    • Windows 10 IoT Enterprise LTSB 2016 (64-bit)1
    1Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.(只是限制了操作系统为64位,但是在64位的系统上安装32位的LabVIEW后,VDM2020SP2仍然是支持的)
    NI Application Software
    Versions Supported by NI Vision Development Module
    NI LabVIEW
    2017, 2018, 2019, 2020
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabWindows™/CVI™
    NI LabVIEW NXG
    5.1
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported. Development and runtime support for .NET features are no longer included with NI Vision Development Module 2020 and later.
    NI Vision Development Module FPGA Support
    For more information and the complete list of Vision functions and hardware supported on FPGA, visit ni.com/info and enter the Info Code VisionFPGASupport.
    Installation InstructionsInstalling from the LabVIEW Platform Suite
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform Suite.
    To request additional LabVIEW Platform Suite, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or custom applications.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer provides the runtime installer for NI Vision that can be packaged for redistribution by LabVIEW, CVI, or the standalone NI Package Builder. Visit ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can install the NI Vision Runtime with your application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can directly include the NI Vision Runtime.
    You can use NI Package Builder to package your custom application installer along with the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments.
    The NI Vision Runtime installer may require the system to be restarted after installation. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    • Added support for LabVIEW 2020 FPGA Module (64-bit)
    • Added support for PXIe-1486 FlexRIO FPD-Link Interface Module to Vision FPGA IPs
    • Added support for PXIe-1487 FlexRIO GMSL Interface Module to Vision FPGA IPs
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision and \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    Application Interface and Examples
    The NIEXTCCOMPILERSUPP environment variable is provided as an alias to the location of C language support files. You can use this variable when compiling and linking an application. The Application Interface files (header and library files to include in applications) are placed in a centralized location to prevent users from accidentally overwriting them and to provide this NIEXTCCOMPILERSUPP environment variable.
    Note: $(NIEXTCCOMPILERSUPP) is configured as an environment variable on the target system. The variable evaluates by default to \Program Files\National Instruments\shared\ExternalCompilerSupport\C.
    ItemInstalled Location
    header files<$(NIEXTCCOMPILERSUPP)>\include
    32-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib32\msvc
    64-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib64\msvc
    The following sections detail considerations for using LabVIEW NXG 5.1 with NI Vision Development Module 2020 SP2.
    Changes in VDM Supported in LabVIEW NXG
    For information about VDM support in LabVIEW NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    Installing Vision Development Module for LabVIEW NXG
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install Vision Development Module for LabVIEW NXG.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, then automatically opens an installation window.
    • Select LabVIEW NXG 5.1 and NI Vision Development Module 2020 SP2.
    • Complete the installer instructions to download LabVIEW NXG and Vision Development Module support for LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI Vision Development Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    The NI Vision Development Module supports the external vision library OpenCV. Refer to the National Instruments Web site to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in LabVIEW and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create LabVIEW APIs to call OpenCV entry points.
    • LabVIEW examples.
    © 2003–2021 National Instruments Corporation. All rights reserved.
    375127P-01
    VDM2020SP2解决的问题:
    Bug Number
    Legacy ID
    Description
    Details
    198130
    634805
    The IMAQ FPGA Local Threshold VI does not correctly threshold the top of images when the kernel size is large.
    Workaround:
    There is currently no known workaround for this issue.
    Reported Version:
    Vision Development Module 2017
    Resolved Version:
    Added:
    May 22, 2017
    1183366
    AutoMThreshold.vi with Large Images Can Cause LabVIEW to Crash
    Certain large images when undergoing AutoMThreshold.vi can cause a crash in LabVIEW 2020.
    Workaround:
    Reported Version:
    Resolved Version:
    Added:
    Dec 9, 2020
    GMT+8, 2026-4-23 15:04
