查看: 442|回复: 0
[Cognex] 康耐视标准图像处理软件COGNEX DESIGNER 4.5.1 官方64位Windows原版非破解版 基于VisionPro 9.23和VPDL4.0
    3 小时前
  • 签到天数: 3860 天
    连续签到: 53 天
     楼主| 发表于 2025-11-24 08:58:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    COGNEX DESIGNER 4.5.1 (64-BIT)
    Cognex Designer 4.5.1 replaces 4.5.0. This update provides compatibility for VisionPro 9.23 and VisionPro Deep Learning 4.0, as well as the updates shared below:
    • Update to ImageRecorder
      • Option to create a BMP/PNG combining the image + VisionPro result graphics
      • Option to downscale image
    • Added the ability to run the Deployed project on a chosen monitor
      • Previously the project would only run on the Windows default monitor
    • Scripts running on deployed projects are now optimized
      • Execution time is around 7x faster
    • Additional Sample projects have been added as examples of how to extend Designer using custom .NET plugins
    • Fixed issue preventing Designer running on PCs that had > 64 cores
    • Fixed issue with A5000 device block missing pins
    • Fixed issue with Data Table component causing slow UI updates
    文件类型: .zip
    文件大小: 73.7MB
    版本: 4.5.1
    发布日期: 2024/12/18
    文件名: Setup Cognex Designer (TM) 4.5.1.exe
    文件大小: 77814288 字节 (74.21 MB)
    修改日期: 2024-12-19 00:14
    版本: 4.5.1.1687
    MD5: 8f1d80b14830f010658d4693914370a0
    SHA1: 336fe118cc9ca853adba34de265b8e52817da6aa
    SHA256: b54bf3cb2e797174127482eb4f888d528945ba9b0fa4ac071197edc0d94daeaf
    CRC32: 9c3e50e6
    康耐视官方下载:
    链接:https://pan.baidu.com/s/1qy7PAwCY1L4dJ19geE45Tg
    GMT+8, 2026-4-18 13:28
