查看: 182|回复: 0
[NI驱动程序] NI-568x Driver Software 15.1 Win32/64En NI-568x驱动程序NI568X1510
 楼主| 发表于 2026-3-11 10:00:31 | 显示全部楼层 |阅读模式
NI-568x为使用NI RF功率传感器设备的客户提供支持。
NI-568x是与所有NI RF功率传感器设备通信必需的NI仪器驱动程序,包括NI-568x系列射频功率传感器设备。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及配置、归零和测试实用程序。NI-568x包含了交互式软面板和示例。
发布日期:2016/12/2
包含的版本:完整版,版本号15.1.0
Windows 7 64-bit
Windows 8.1 32-bit
Windows 7 32-bit
Windows Vista 64-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Vista 32-bit
Windows 8 64-bit
Windows 8 32-bit
语言:英文En
程序位数:32/64位
文件大小: 630116232 字节 (600.93 MB)
修改日期: 2023-01-21 09:57
MD5: 82fac14da9f584320a1176eb2ac8183c
SHA1: 3b618ddbdb0be941f95a25741bcef0c96ce81941
SHA256: e27577d0705f09a087becc5db27bd606a80369f0e33d201ab60753f7dc5cd13a
SHA512: 73a571b69e3926be43492647ad30ef843622ab7d0bbdf4307bc530bf5a1e70903b7e4013ac34570d48ce7848e1114eb111e6972c7cd6389a6a44a592809b0a68
请注册登录机器视觉论坛会员,购买附件查看下载地址
NI-568x 15.1.txt (609 Bytes, 下载次数: 0, 售价: 10 圆)
NI-568x 15.1 Readme
August 2015
Thank you for using NI-568x. This file contains important information regarding NI-568x and is organized into the following sections:
Accessing VIs and Functions
Driver Version Naming Changes
Uninstalling/Modifying NI RF Power Meters Software
Behavior Changes and Upgrade Notes
Using NI Software with Microsoft Windows 8.x
NI-568x 15.0 includes the following new features:
  • Support for LabVIEW 2015 SP1 (32-bit and 64-bit)
  • Support for LabVIEW 2014 SP1 (32-bit and 64-bit)
  • Support for Windows 10 (32-bit and 64-bit)
  • Support for the USB-5683 power meter
  • Support for the USB-5684 power meter
  • Updated NI-568x Soft Front Panel (SFP)
  • Support for triggered measurements with hysteresis consideration
  • Support for specifying buffer size in continuous power measurements
  • Support for measuring pulse-modulated signals with periods shorter than 30.0 µs
NI-568x 1.2 includes the following new features:
  • Support for LabVIEW 2013 SP1 (32-bit and 64-bit), LabVIEW 2012 SP1 (32-bit and 64-bit), LabVIEW 2011 SP1 (32-bit and 64-bit), LabVIEW 2010 SP1 (32-bit and 64-bit)
  • Support for Windows 8
  • Updated shipping examples
NI-568x 1.1 includes the following new features:
  • Support for the NI USB-5681 (NI 5681)
The NI-568x instrument driver supports the following power meters:
  • USB-5680
  • USB-5681
  • USB-5683
  • USB-5684
Device-specific information about these modules is included in the NI RF Power Meters Help.
NI-568x 15.1 supports the following operating systems:
Note NI-568x 15.0 and later does not support non-R2 editions of Windows Server 2008 and later.
Minimum System Requirements
  • RAM—
    • Windows 7/Vista: 512 MB
    • Windows 8: 512 MB
    • Windows 10: 512 MB
  • A screen resolution of 1,024 × 768
  • Windows 10/8/7/Vista, with all available critical updates and service packs
  • USB port
Note The minimum USB port requirement for USB-5683 and USB-5684 devices is USB 2.0.
Note NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
Recommended System
  • RAM—
    • Windows 7/Vista: 1 GB
    • Windows 8: 1 GB
    • Windows 10: 1 GB
Note  You should install ADEs, such as LabVIEW, LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-568x. To add support for ADEs installed after installing NI-568x, modify your NI-568x installation or launch the NI-568x installer again.
  • LabVIEW 2012 SP1 (32-bit and 64-bit), 2013 SP1 (32-bit and 64-bit), 2014 SP1 (32-bit and 64-bit), 2015 (32-bit and 64-bit).
  • LabWindows/CVI 2012 or later
  • Microsoft Visual C++ (MSVC) 2008 or later
    • Windows 10/8.1/8.0/7/Vista: Users\Public\Public Documents\National Instruments
    • Windows 10/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit): Program Files\IVI Foundation\IVI\
    • Windows 10/8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
      • Windows 10/8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/: Program Files\IVI\
      • Windows 10/8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
    • Windows 10/8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
ItemInstalled Location on Windows 10/8.1/8.0/7/Vista
NI-568x\Drivers\ni568x
NI-568x Function Panel\Drivers\ni568x\ni568x.fp
NI-568x LabVIEW Examples\NI-568x\Examples
LabWindows/CVI Examples\CVI\Samples\ni568x
NI-568x Header files\Include
NI-568x Import Library files (32-bit)\Lib\msc
NI-568x Import Library files (64-bit)\Lib_x64\msc
NI-568x DLL (32-bit)\Bin
Additional File Locations for Windows 10/8.1/8 (64-bit)/7 (64-bit)/Vista (64-bit)
ItemInstalled Location on Windows 10/8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
NI-568x DLL (64-bit)\Bin
Select Start»All Programs»National Instruments»NI-568x»NI-568x Soft Front Panel to launch the NI-568x Soft Front Panel.
Documentation for NI RF Power Meters is located at Start»All Programs»National Instruments»NI-568x»NI-568x Documentation. The documentation set is composed of the following documents.
DocumentFormatDescription
NI RF Power Meters HelpHTML/Windows HelpContains primary help content for NI RF Power Meters products. The help is an HTML version of a traditional user manual that includes the following information:
  • An introduction to NI RF Power Meters
  • Hardware device information
  • A complete reference for all NI-568x programming functions and VIs
NI-568x ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
NI-568x IVI Compliance DocumentTXTContains information about IVI compliance.
Introduction to ni568xHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com.
NI-568x palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-568x palette.
NI-568x functions are available in LabWindows/CVI from the Instrument menu. To load the NI-568x function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\ni568x\ni568x.fp.
In LabVIEW, you can use the NI Example Finder to search or browse examples. NI-568x examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
  • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI-568x (RF Power Meter) or by directory structure at instr»ni568x.
  • Click the Search tab to search all installed examples by keyword. For example, search for "568x" to locate all NI RF Power Meter examples.
You can also access all the installed NI-568x examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-568x»NI-568x Examples.
NI-568x versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-568x 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-568x 1.2. The first version released under the new numbering scheme is NI-568x 15.0.
  • Select NI-568x 15.1 from the dialog box that appears.
For Windows 8.x, complete the following steps:
  • Click Settings.
  • Click Systems.
  • Click Apps and Features.
  • Select National Instruments.
  • Click the Uninstall button.
For Windows 10, complete the following steps:
  • Click the Start button.
  • Select Programs»Programs and Features.
As part of the NI-568x 15.1 installation, the following software is installed. To completely remove the NI-568x 15.1 installation from your system, you must also remove all of the following packages:
  • NI IVI Compliance Package 15.0
  • NI Measurement & Automation Explorer 15.0.0
  • NI Measurement Studio Common .NET Assemblies for .NET 15.0.0
  • NI System Configuration API 15.0.0
  • NI System API Windows (32-bit and 64-bit) 15.0.0
  • NI-VISA Runtime 15.0
  • NI I/O Trace 15.0.0
Behavior Changes and Upgrade NotesKnown Issues
You can access the software and documentation known issues list online. Refer to the NI-568x Known Issues at ni.com and enter the Info Code exez53 for an up-to-date list of known issues in NI-568x 15.1.
The following items are changes in NI-568x 15.1 from NI-568x 15.0.
601287Fixed an issue where the serial number could not be read from a USB-5680 or USB-5681 power meter.
The following items are changes in NI-568x 15.0 from NI-568x 1.2.
240557Fixed an issue in which scope mode would error when using short capture times.
409122Fixed an issue in which VISA aliasing would fail in NI Measurement & Automation Explorer (MAX).
523688Fixed several issues in which attribute behavior was inconsistent with IVI compliance standards.
The following items are changes in NI-568x 1.2 from NI-568x 1.1.
238457Fixed an issue in which power meters did not appear in NI Measurement & Automation Explorer (MAX) after installing the NI-568x driver.
238742Fixed an issue in which timeout errors occurred in scope mode.
238918Fixed an issue in which you could not use the power meter after disconnecting and reconnecting the power meter.
The following items are changes in NI-568x 1.1 from NI-568x 1.0.
93562Fixed an issue in which the NI-568x properties were not accessible from the property node.
211620Fixed an issue in which LabVIEW 8.2 would not launch after installing NI-568x.
106509Fixed a timeout error when reading from the NI 5680.
Using NI Launcher
For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
Finding All Programs
NI-568x 15.0 Drops Support for Microsoft Windows XP and Windows Server 2003
NI-568x 15.0 drops support for Windows XP and Windows Server 2003. Versions of NI-568x 15.0 and later will not install or run on Windows XP or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
NI-568x Drops Support for Microsoft Windows Vista in 2016
NI-568x will drop support for Microsoft Windows Vista as of July 1, 2016. Versions of NI-568x that ship after July 1, 2016 will not install or run on Windows Vista. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
NI LabVIEWlifecycle
NI TestStandtslcp
NI DIAdemddlcp
NI SignalExpressselcp
NI VeriStandnivslifecycle
© 2007–2016 National Instruments. All rights reserved.
375452B-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 18:11
