查看: 187|回复: 0
[NI驱动程序] NI-568x Driver Software 20.0 Win32/64En NI-568x驱动程序ni-568x_20.0.0
 楼主| 发表于 2026-3-11 10:27:28 | 显示全部楼层 |阅读模式
NI-568x为使用NI RF功率传感器设备的客户提供支持。
NI-568x是与所有NI RF功率传感器设备通信必需的NI仪器驱动程序,包括NI-568x系列射频功率传感器设备。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及配置、归零和测试实用程序。NI-568x包含了交互式软面板和示例。
发布日期:2020/7/24
包含的版本:完整版,版本号20.0.0
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
语言:英文En
程序位数:32/64位
文件大小: 735590400 字节 (701.51 MB)
修改日期: 2026-03-11 09:02
MD5: 1ef4b8f7350187c52d36e47c6e211732
SHA1: 9fc6cb7299e3377d221a3bf231296e3beebd8a1e
SHA256: a94277332c68121600096a91be023dc0d282b33583c3742b105609a6dfd71799
SHA512: 7acb1885cb23d16440c5855f7eacba94eff0349028eb63112c7f59a5a52eb35da14fdefcad1332d1b077496915117d33d5efd676f0b77de9499b0e40efc3250b
请注册登录机器视觉论坛会员,购买附件查看下载地址
NI-568x 20.0.txt (650 Bytes, 下载次数: 0, 售价: 10 圆)
NI-568x 20.0 Readme
June 2020
This file contains important information about NI-568x, including new features, bug fixes, and known issues.
IVI Compliance Pacakge Functionality
NI-568x Drops Support for Windows 7 (32- and 64-Bit) and All 32-Bit Windows Operating Systems in 2021
This software installation provides support for customers using RF power sensor devices, as specified in the Supported Hardware section. To program your RF power sensor device, use the NI-568x instrument driver or the NI-568x Soft Front Panel (SFP).
The getting started guide for your device provides information about how to install, configure, test, and begin using an RF power sensor device.
NI-568x 20.0 adds support for LabVIEW 2020
NI-568x 19.0 adds support for LabVIEW 2019
NI-568x 18.0 adds support for LabVIEW 2018
NI-568x 17.0 includes the following new features:
  • Support for LabVIEW 2017
  • Support for LabVIEW 2016
The NI-568x instrument driver supports the following RF power sensor devices:
  • USB-5680
  • USB-5681
  • USB-5683
  • USB-5684
Device-specific information about these modules is included in the RF Power Sensor Devices Help.
NI-568x 20.0 has the following requirements:
  • 512 MB RAM
  • A screen resolution of 1,024 × 768
  • USB port
Note  The minimum USB port requirement for USB-5683 and USB-5684 devices is USB 2.0.
Note  NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. On a laptop computer, the default power management settings are likely to enable sleep mode.
NI-568x 20.0 supports Windows 10/8.11/7 SP12.
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install this security update.
Note  Refer to NI-568x Drops Support for Windows 7 (32- and 64-Bit) and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
NI-568x 20.0 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-568x. To add support for application software installed after installing NI-568x, modify your NI-568x installation or launch the NI-568x installer again.
Application SoftwareVersions Supported by NI-568x
LabVIEW2017 SP1, 2018 SP1, 2019, 2020
LabWindows™/CVI™2012 to current
Microsoft Visual C++ (MSVC)2008 to current
Note  If you are running your application on an RT target, 128 MB of memory or more is required.
To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
NI installs NI-568x using NI Package Manager. If you do not already have NI software installed, NI-568x installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
Accessing the APILabVIEW
NI-568x VIs are available in LabVIEW from the Functions»Instrument I/O»Instrument Drivers»NI-568x palette.
LabWindows/CVI
NI-568x functions are available in LabWindows/CVI from the Instrument menu. To load the NI-568x function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\ni568x\ni568x.fp.
C
You can use the NI-568x C dynamically linked library by adding a reference to:
  • (32-bit): Program Files\IVI Foundation\IVI\Bin\ni568x.dll
  • (64-bit): Program Files (x86)\IVI Foundation\IVI\Bin\ni568x.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\ni568x_64.dll for 64-bit development
Select Start»All Programs»National Instruments»NI-568x»NI-568x Soft Front Panel to launch the NI-568x Soft Front Panel.
Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder, and click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI-568x (RF Power Meter). You can also select the Search tab to search all installed examples by keyword.
All installed NI-568x examples for LabVIEW, LabWindows/CVI, and C are accessible from Start»All Programs»National Instruments»NI-568x»NI-568x Examples.
Documentation for RF power sensor devices is located at Start»All Programs»National Instruments»NI-568x»NI-568x Documentation. The documentation set is composed of the following documents.
DocumentFormatDescription
RF Power Sensor Devices HelpHTML/Windows HelpContains primary help content for RF power sensor devices. The help is an HTML version of a traditional user manual that includes the following information:
  • An introduction to RF power sensor devices
  • Hardware device information
  • A complete reference for all NI-568x programming functions and VIs
Getting started guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
NI-568x ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
NI-568x IVI Compliance DocumentTXTContains information about IVI compliance.
Introduction to ni568xHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
NI-568x no longer installs IVI Compliance Package (ICP). NI-568x supports IVI configuration and runtime, but no longer installs the following IVI components:
  • IVI-COM Adapters
You can access the NI-568x 20.0 known issues online at NI-568x 20.0 Known Issues.
You can access the NI-568x bug fix list online at NI-568x 20.0 Bug Fixes. This list describes a subset of issues fixed in NI-568x 20.0. If you have a Bug id, you can search this list to validate that the issue has been fixed.
NI-568x will drop support for Windows 7 (32- and 64-bit) and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
LabWindows/CVIcvi_lifecycle
© 2007–2020 National Instruments. All rights reserved.
375452F-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 18:11
