查看: 187|回复: 0
[NI驱动程序] NI-568x Driver Software 2026 Q1 Win32/64En NI-568x驱动程序ni-568x_26.0.0
 楼主| 发表于 2026-3-11 10:38:39 | 显示全部楼层 |阅读模式
NI-568x为使用NI RF功率传感器设备的客户提供支持。
NI-568x是与所有NI RF功率传感器设备通信必需的NI仪器驱动程序,包括NI-568x系列射频功率传感器设备。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及配置、归零和测试实用程序。NI-568x包含了交互式软面板和示例。
发布日期:2026/1/28
包含的版本:完整版,版本号23.0.1
Windows Server 2025
语言:英文En
程序位数:32/64位
文件大小: 1417777152 字节 (1.32 GB)
修改日期: 2026-02-07 18:29
MD5: ad00705bfd21ff82b8edcb426d98a312
SHA1: bdb061c9f0a7a1b94258d2a36c2cd3ac6283108b
SHA256: b0ccfead41758718cea39abe59888060758a531761833d8bc5a60cef961e9dd1
SHA512: 3d72ba14f0bcaf0a538c0295721fd0a94e3ff5d73bf13182ecb1a8ac5398fbee540df580f902a3fec14f41a85e52cadf7faff618d39ad28d473836e1408b759c
请注册登录机器视觉论坛会员,购买附件查看下载地址
NI-568x 2026Q1.txt (668 Bytes, 下载次数: 0, 售价: 10 圆)
2026Q1未更新自述文件,参考2023Q1
NI-568x 2023 Q1 Readme
January 2023
This file contains installation instructions and compatibility information for NI-568x 2023 Q1.
  • NI-568x Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
  • NI-568x Documentation: New features, behavior changes, and other documentation
IVI Compliance Pacakge Functionality
This software installation provides support for customers using RF power sensor devices, as specified in the Supported Hardware section. To program your RF power sensor device, use the NI-568x instrument driver or the NI-568x Soft Front Panel (SFP).
The getting started guide for your device provides information about how to install, configure, test, and begin using an RF power sensor device.
NI-568x 2023 Q1 has the following requirements:
  • 512 MB RAM
  • A screen resolution of 1,024 × 768
  • USB port
Note  The minimum USB port requirement for USB-5683 and USB-5684 devices is USB 2.0.
Note  NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. On a laptop computer, the default power management settings are likely to enable sleep mode.
NI-568x 2023 Q1 supports the following operating systems:
Note  NI-568x no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
NI-568x 2023 Q1 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-568x. To add support for application software installed after installing NI-568x, modify your NI-568x installation or launch the NI-568x installer again.
Versions Supported by NI-568x
LabVIEW2020 and later
LabWindows™/CVI™2012 to current
Microsoft Visual C++ (MSVC)2008 to current
Note  If you are running your application on an RT target, 128 MB of memory or more is required.
To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
NI installs NI-568x using NI Package Manager. If you do not already have NI software installed, NI-568x installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
When installing NI-568x, the "NI-568x Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory. This package supports applications using NI-568x with LabVIEW 2023 Q1 or later.
Accessing the APILabVIEW
NI-568x VIs are available in LabVIEW from the Functions»Instrument I/O»Instrument Drivers»NI-568x palette.
LabWindows/CVI
NI-568x functions are available in LabWindows/CVI from the Instrument menu. To load the NI-568x function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\ni568x\ni568x.fp.
C
You can use the NI-568x C dynamically linked library by adding a reference to:
  • (32-bit): Program Files\IVI Foundation\IVI\Bin\ni568x.dll
  • (64-bit): Program Files (x86)\IVI Foundation\IVI\Bin\ni568x.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\ni568x_64.dll for 64-bit development
Select Start»All Programs»National Instruments»NI-568x»NI-568x Soft Front Panel to launch the NI-568x Soft Front Panel.
  • Support for LabVIEW 2021 and later
The NI-568x instrument driver supports the following RF power sensor devices:
  • USB-5680
  • USB-5681
  • USB-5683
  • USB-5684
Device-specific information about these modules is included in the RF Power Sensor Devices Help.
Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder, and click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI-568x (RF Power Meter). You can also select the Search tab to search all installed examples by keyword.
All installed NI-568x examples for LabVIEW, LabWindows/CVI, and C are accessible from Start»All Programs»National Instruments»NI-568x»NI-568x Examples.
Refer to the NI-568x documentation, accessible from Start»All Programs»National Instruments»NI-568x»NI-568x Documentation, for more information about NI-568x.
NI-568x no longer installs IVI Compliance Package (ICP). NI-568x supports IVI configuration and runtime, but no longer installs the following IVI components:
  • IVI-COM Adapters
NI-568x no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
© 2007–2023 National Instruments Corporation. All rights reserved.
QQ|LabVIEW视觉
GMT+8, 2026-4-8 14:37
