查看: 210|回复: 0
[LV工具模块] LabVIEW 2026 Q1 EPICS Client I/O Server Win11 32bitEng NI EPICS客户端I/O服务器2026Q1版下载EPICS26.1.0
 楼主| 发表于 2026-3-12 09:26:50 | 显示全部楼层 |阅读模式
LabVIEW EPICS客户端I/O服务器可帮助您创建EPICS客户端I/O服务器,而无需安装任何LabVIEW附加工具。
实验用物理和工业控制系统(EPICS)是一种用于构建分布式控制系统的软件架构,适用于粒子加速器、望远镜和其他大型实验设备的开发。借助LabVIEW中的EPICS客户端,无需安装LabVIEW数据记录和监控模块或LabVIEW Real-Time模块,即可连接到EPICS IOC,读取和写入过程变量。
在安装该产品之前,请先安装对应的编程环境,比如NI LabVIEW或Microsoft VisualStudio等。
发布日期:2026/1/28
包含的版本:2026 Q1完整版,版本号26.1.0
Windows Server 2025
应用程序位数:32位
文件大小: 1626083328 字节 (1.51 GB)
修改日期: 2025-03-12 16:56
MD5: d042898fea257a1532d1c9cfc032599a
SHA1: e83e71129a41809ee00e8f226ae3198492a00718
SHA256: 78291addfed11f59cdf5ce7a59d96d372acfee69cc3f2a8f30cd819dc2134bd1
CRC32: 10059a6a
请注册登录机器视觉论坛账号,购买附件查看下载地址
无自述文件。NI官方引用的自述文件为DSC模块的自述文件,请参考相应的自述文件。
LabVIEW 2020 Datalogging and Supervisory Control Module Readme
March 2020
This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Module, including installation instructions, known issues, and a partial list of bugs fixed.
LabVIEW Datalogging and Supervisory Control Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
The LabVIEW DSC Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
  • LabVIEW 2020 Base, Full, or Professional Development System (32-bit)
  • At least 2.5 GB of disk space
  • 512 MB of RAM. NI recommends 1 GB of RAM.
  • Internet Explorer 6 Service Pack 1 or later
Note  The DSC Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
The DSC Module supports the following operating systems:
  • Windows 10 (version 1909)/8.1 Update 11/7 SP12
  • Windows Server 2012 R21
  • Windows Server 2008 R2 SP12
  • In 2016 the LabVIEW DSC Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 DSC Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 DSC Module to an unsupported OS. Additionally, after installing the LabVIEW 2020 DSC Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, visit ni.com/r/OSSupport2016.
  • Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport.
  • Refer to LabVIEW Datalogging and Supervisory Control Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
NI installs the DSC Module using NI Package Manager. If you do not already have NI software installed, the DSC Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
You can also install LabVIEW and the DSC Module using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
SQL Server Support
The LabVIEW 2020 DSC Module requires Microsoft SQL Server 2012 Service Pack 4 (SP4) Express. This component is installed by default when you install the DSC Module.
To install the LabVIEW 2020 DSC Module on a machine that has a previous version of the DSC Module installed, you need to upgrade the Microsoft SQL Server version from 2008 R2 to 2012 SP4 Express. Because upgrading the Microsoft SQL Server affects the Citadel database, you must backup your Citadel data before upgrading. Refer to the Archiving Citadel Data topic in the LabVIEW Help for detailed information about archiving the Citadel database.
Licensing
The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
You can access the software and documentation known issues list online. Visit LabVIEW 2020 DSC Module Known Issues for an up-to-date list of known issues.
Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
The Datalogging and Supervisory Control Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
© 2000–2020 National Instruments. All rights reserved.
375310G-01
QQ|LabVIEW视觉
GMT+8, 2026-4-8 11:56
