查看: 15|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2024 Q3 Patch 3 Win11 32/64bitEn NI PXI矢量信号分析仪驱动NI-RFSA 24.5.3
    昨天 08:07
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 昨天 17:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSA
    NI-RFSA 2024 Q3 Patch 3
    发布日期:2024/10/22
    包含的版本:2024 Q3 Patch 3完整版,版本号24.5.3
    语言:英文English
    文件大小: 4592422912 字节 (4.28 GB)
    修改日期: 2026-04-08 16:22
    MD5: d6a38b4240268aa76c9b2913facbce0a
    SHA1: d96b497c393f9a7f0be6ce722da73bba7e35feb5
    SHA256: 4531480aadf529a418cd565cbec3a02f4867cbdc7d741a4457e577b04c2a2dd5
    SHA512: 7e923300812c318a0fa86ecf00d534a85487091741a3c2a8fb9093fd6557aadea3bb8722af454fae53ce10d8fa9a5232ffe61776c3c39f723f0fc4a62201df63
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSA 2024 Q3 Patch3.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q3Patch3版未更新自述文件,参考2023Q3版
    NI-RFSA 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-RFSA 2023 Q3.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Documentation: New features, behavior changes, and other documentation
    NI-RFSA 2023 Q1 Patch 1 includes the following new feature:
    NI-RFSA 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSA 2022 Q4 includes the following new feature:
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841/5842 if you choose to install the runtimes independently.
    • 4 GB RAM*
    NI-RFSA 2023 Q3 and NI-RFSA SFP 2023 Q3 support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSA
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "NI-RFSA Support for LabVIEW" package supports applications using NI-RFSA ​with LabVIEW 2023 Q1 or later. When installing NI-RFSA, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Other documentation for NI-RFSA can be found in Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-4-9 00:24
