查看: 9|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q3 Patch 3 Win11 32/64bitEn NI RF信号发生器NI-RFSG25.5.3
    12 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    NI-RFSG 2025 Q3 Patch 3
    发布日期:2025/9/21
    包含的版本:2025 Q3 Patch 3完整版,版本号25.5.3
    Windows Server 2025
    文件大小: 5598056448 字节 (5.21 GB)
    修改日期: 2026-04-08 16:07
    MD5: 06646acfa529d17ccf9a6193c8754dc4
    SHA1: 3b8f8853a07518f7088b97c1ab294f66f9c635d2
    SHA256: b0372ac54a3a3ff2f9037772c4c2f3f5f14c15e5300607a287184ecc51957fde
    SHA512: 7a1e0a4d240550224da765238e679fb5df9babc18792dc74e8da24d1bbd174bb3d99aaafcb21cca4d06f91e6bebf94f45f31b5209caf307db689edd2c82ce7de
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSG 2025 Q3 Patch3.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 2025 Q3 Changes
    Learn about new features, behavior changes, and other updates in NI-RFSG 2025 Q3.
    This version of NI-RFSG provides support for the following features:
    • Support for SystemLink Asset Utilization.
    • Support for PXIe-5842 VST with 54 GHz Frequency Extension (RMM-5585).
    • Support for PXIe-5563 RF Port Switch.
    NI-RFSG2025Q3版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q3.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Documentation: New features, behavior changes, and other documentation
    NI-RFSG 2023 Q1 Patch 1 includes the following new feature:
    NI-RFSG 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q4 includes the following new feature:
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841/5842 if you choose to install the runtimes independently.
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q3.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    The "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG ​with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Other documentation for NI-RFSG can be found in Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-4-8 20:21
