楼主: 石鑫华视觉
[原创] NI Vision Assistant视觉助手教程 5.11 Image Calibration图像标定(附件下载)
    发表于 2015-8-31 12:46:39 | 显示全部楼层 来自:浙江省杭州市 电信
    发表于 2015-9-18 09:37:42 | 显示全部楼层 来自:广东省深圳市 电信
  • 签到天数: 8 天
    发表于 2015-9-20 21:55:28 | 显示全部楼层 来自:江苏省苏州市 电信
    发表于 2015-9-21 14:37:26 | 显示全部楼层 来自:天津市 电信IDC机房
    菲力尔FLIR-灰点Point Grey工业相机Linux Ubuntu18.04-arm64系统驱动Spinnaker_Python-2.2.0.48-CP27/CP36/CP37-linux_aarch64
    文件版本:
    spinnaker_python-2.2.0.48-Ubuntu18.04-cp27-cp27mu-linux_aarch64.tar
    spinnaker_python-2.2.0.48-Ubuntu18.04-cp36-cp36m-linux_aarch64.tar
    spinnaker_python-2.2.0.48-Ubuntu18.04-cp37-cp37m-linux_aarch64.tar
    百度网盘下载地址:
    链接:[hide] [url=https://pan.baidu.com/s/1j7LlqpOqswF_T6fYTar6Mw]https://pan.baidu.com/s/1j7LlqpOqswF_T6fYTar6Mw[/url][/hide] 提取码: arjf
    Spinnaker SDK – 2.2.0.48
    - CHANGE LIST (list of updates with this version):
    Enhancements:
    - Initial support for Ubuntu Focal (20.04)
    - Improve 'Incomplete Buffer Warning' with more actionable message
    - Improve experience on finding out why there are missing packets (SpinView_WPF)
    - Add disable Auto Gain and Auto WB to SpinView optimize FPS button
    - Add warning/note to Trigger example related to triggering faster than frame time
    - SpinView_Qt - Port over Windows Camera Auto IP
    Resolved Issues:
    - Fix multiple issues introduced with 2.1 release when using Gige cameras in Windows 7
    - Bash profile has incorrect line ending
    - Fix disabling of GEV enumeration
    - Debug Symbols loaded in Example .sln Files (for .exe files)
    - SpinView_WPF buffer nodes do not update when streaming
    - Spinnaker Documentations shortcut does not open the C/C++ pdf on Linux
    - Unavailable Files in Examples_vs2015 Solution
    - SpinView_Qt does not link to Spinnaker documentation on Linux
    - Some paths lost in PATH after installing Spinnaker 2.2.x
    - Gige camera window in SpinView would close randomly while streaming with a split view of U3V and GigE at max resolution
    - Resetting Application Settings does not set rendering back to CPU
    - Lossless Compression - Unable to decompress images with chunk data enabLED
    - UnregisterEventHandler failing with error "No event is registered"
    - No Command Nodes Available in VisionPro Cognex
    - USB3 camera segfaults in linux when being accessed in multiple applications
    - SpinView 2.0.0.146 histogram not working with BFLY-PGE-13E4C bayer pixel formats
    - EnumerateGEVInterfaces shortcuts do not work unless run as admin
    - Spinview 2.0.0.146 display pane will reset when startup everytime.
    - Interfaces appear and disappear from the Interface list on some PCs
    - Streaming images are not displayed after re-arranging image display panes in SpinView_Qt
    - endacquisition freezes with image callback registered (Windows)
    - EnumerationEvents_(C ,CSharp, VB, Python) Doesn't Show GigE Interface Arrival/Removals Correctly
    - SpinView_WPF log viewer match whole words search is not case sensitive
    - GigE camera won't initialize after firmware update in SpinView_WPF
    - After power cycling a GigE camera in SpinView_WPF, device list does not update on its own
    - SpinView_WPF throws 4 errors when displaying node information with no increments
    - macos installer pyspin3.6 package packs in pyspin2.7
    - 32bit SpinnakerDirectShow_v140.dll not packaged in 64bit Spinnaker installer
  • 签到天数: 6 天
    发表于 2015-9-21 21:53:09 | 显示全部楼层 来自:广东省东莞市 电信
  • 签到天数: 1 天
    发表于 2015-10-7 11:21:39 | 显示全部楼层 来自:广东省广州市 电信
  • 签到天数: 12 天
    发表于 2015-10-9 11:37:41 | 显示全部楼层 来自:河南省郑州市 联通
  • 签到天数: 16 天
    发表于 2015-10-9 14:42:22 | 显示全部楼层 来自:河南省洛阳市偃师市 联通
  • 签到天数: 60 天
    发表于 2015-10-10 23:04:03 | 显示全部楼层 来自:江苏省苏州市 电信
    石鑫华视觉供应工业镜头,CCTV镜头、远心镜头、显微镜头、扩倍镜,详细登陆http://visionbbs.com
  • 签到天数: 5 天
    发表于 2015-10-11 13:42:58 | 显示全部楼层 来自:广东省阳江市 移动
    GMT+8, 2026-4-10 23:31
