查看: 9424|回复: 0
[LabVIEW] NI LabVIEW 2012SP1 Win32ENG 32位LV2012SP1英文版下载
    昨天 16:03
    发表于 2013-3-12 23:08:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    LV2012SP1ENG.txt (298 Bytes, 下载次数: 56, 售价: 10 圆)
    LabVIEW 2012 Service Pack 1 Readme for Windows
    Version 12.0.1
    December 2012
    This file contains important information about LabVIEW 2012 Service Pack 1 (SP1) for Windows, including system requirements, installation instructions, a partial list of bugs fixed for LabVIEW 2012 SP1, and known issues for LabVIEW.
    Refer to the National Instruments website for the latest information about LabVIEW 2012 SP1.
    LabVIEW 2012 SP1 (64-bit)
    Additions to the LabVIEW Help
    Important Information
    ProcessorPentium III/Celeron 866 MHz or equivalentPentium 4M or equivalent
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemWindows 8/7/Vista (32-bit and 64-bit)
    Windows XP SP3 (32-bit)
    Disk Space353 MB3.67 GB (includes default drivers from the NI Device Drivers DVD)
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  The following list describes restrictions for using LabVIEW on Windows:
    • LabVIEW does not support Windows 2000/NT/Me/98/95 or Windows XP x64.
    Note  The previous table provides the most current system requirements. The LabVIEW Installation Guide does not provide updated system requirements for LabVIEW 2012 SP1.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2012 and LabVIEW 2012 SP1.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2012 and LabVIEW 2012 SP1.
    When run on Windows (64-bit), LabVIEW 2012 SP1 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2012 SP1 (64-bit) includes nearly all of the development environment features of LabVIEW 2012 SP1 (32-bit).
    Refer to the National Instruments website for information about obtaining a copy of LabVIEW 2012 SP1 (64-bit).
    LabVIEW 2012 SP1 (64-bit) supports many hardware devices. Refer to the National Instruments website for information about drivers compatible with LabVIEW 2012 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2012 SP1 (64-bit).
    Supported Modules
    LabVIEW 2012 SP1 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. No additional modules support LabVIEW 2012 SP1 (64-bit).
    • Because LabVIEW 2012 SP1 may apply different compiler optimizations on different machines, you may need to perform additional steps to guarantee that a built application contains the same binary contents when built on different machines. Refer to the National Instruments website for more information about reproducing builds in LabVIEW 2012 SP1.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2012 SP1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    375494Improved update rate of front panel control value references
    373305Property: Mouse for 2D Picture controls returns incorrect values after using Invoke Method: Reinitialize to Default on the 2D Picture control
    373150Error code 3 when running LabVIEW 64-bit applications using NI_AALBase.lvlib, that were installed with installers built in 64-bit LabVIEW Application Builder
    371714Slow load time when adding a VI to the Exported VIs List for a DLL
    371651LabVIEW Source Control prompts to add vi.lib or instr.lib to source control even if they are to be excluded
    370957Specific type of cluster sent over the network may produce incorrect results
    370578LabVIEW User Interface responsiveness decreases on Mac OS when many VIs are loaded into memory
    370259Custom Waveform Graphs display NaN values incorrectly
    368875Slow load and close time for large Application Build specifications
    368466Plot visibility check box cannot be toggled for plot 0 on an XY Graph
    368396Certain applications built with Application Builder fail to launch
    368000Using Property: Owner to get an owning cluster's reference on the cluster's sub-controls returns incorrect value if the sub-control reference came from Property: Controls[] of the owning cluster
    367463References returned by Property: Controls[] of a pane containing type definitions are incorrect
    367428Private inlined VIs in a library cannot be built into packed project libraries
    366331Dynamic event registration of an array of controls fails with Error 1
    365679LabVIEW 3D Picture control does not work with certain AMD video card drivers
    364799Selecting the Configure Web Application Server button immediately after preference page load results in 404 error
    364462Crash when changing value of typedef constant
    363945LabVIEW crashes if changing properties for multiple selected nodes by right-clicking the label
    362925Crash when dragging instance of Polymorphic VI from dialog to block diagram
    362576Invoke Method: Add File crashes LabVIEW if Path parameter contains too many characters
    362366Packed Project Library deployment fails on Real-Time targets
    362018Crash when loading some VIs, saved in a previous version of LabVIEW, into LabVIEW 2012
    361857Certain network configurations cause slow loading of NationalInstruments.LabVIEW120.dll
    361839Boolean constant & string constants grow to length of label when cluster is type defined
    361666Tools»Actor Framework Message Maker... is missing in Linux
    357092Cannot use right-click shortcut menu to create items for the reference out terminal of Property Node (XML) or Invoke Node (XML)
    323332Control reference returned from CtlRef of an Event Structure is incorrect for Type Definitions
    312538Link between .NET Constructor Node and Assembly is sometimes lost even when .NET Assembly exists
    237213Event registration refnum of typedef does not update when typedef updates
    212136"The VI is not executable. The full development version of LabVIEW is required to fix the errors" dialog on a built app
    184689LabVIEW UI is less responsive when displaying NaN values on 3D Surface Graph
    Recompiling VIs for Bug Fixes
    The following fixes require you to manually recompile VIs to correct the problem:
    • 366331—Dynamic event registration of an array of controls fails with Error 1
    To force a recompile of a VI without recompiling its subVIs, press the key while you click the Run button. To force a recompile of all VIs in memory, press the keys while you click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and press the keys while you click the Run button. This method does not recompile any of the VIs called dynamically in the hierarchy.
    You also can recompile VIs in a specified directory using the following steps.
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the desired directory and click the Current Folder button.
    • Click the Mass Compile button to recompile all VIs in that directory with updates.
    • Click the Done button to return to LabVIEW.
    © 2004–2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-24 23:47
