查看: 9533|回复: 0
[LV工具模块] NI Vision Development Module 2010 Win32/64Eng 视觉开发模块VDM2010 适用LabVIEW2010
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2013-5-9 20:51:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ZIP版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ISO版:
    提取码: 请购买附件下载查看
    请购买附件下载查看
    VDM2010.txt (391 Bytes, 下载次数: 88, 售价: 10 圆)
    NI Vision Development Module 2010 Readme
    August 2010
    This file contains important information about National Instruments Vision Development Module and is organized into the following sections:
    General Information
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Development Module.
    General Information
    Installing this program may remove previous versions of the NI Vision Development Module that are currently installed.
    The NI Vision Development Module 2010 supports LabVIEW 8.5, 8.6, 2009, and 2010, Visual Studio 2005 and 2008, and LabWindows™/CVI™ 7.0 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, or any other supported development environment, before installing the NI Vision Development Module.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    This release of the NI Vision Development Module includes the following new features:
    • Support for LabVIEW 2010 (32-bit)
    • Support for LabVIEW 2010 (64-bit)
    • Support for U16 images.
    • Support for contour analysis.
    • Support for color segmentation.
    • Support for motion estimation.
      • Support for the Horn-Schunck and Lucas-Kanadeon optical flow estimation methods, which estimate the motion between at every pixel location across a series of images.
      • Support for the Lucas-Kanade Pyramid method to track the motion of a set of points across a series of images.
    • Support for the support vector machines (SVM) classifier as part of the existing custom classifier functionality.
    • Support for defect detection on textured surfaces.
    • New Texture Training Interface. Use the Texture Training Interface to train texture information for the SVM classifier.
    Note:  To preview the 64-bit features of the NI Vision Development Module Beta, you must install the LabVIEW 2010 (64-bit) Beta.
    Note:  For a list of VIs that support U16 images, refer to the Supported Image Types topic of the NI Vision for LabVIEW Help.
    The following list describes issues in previous versions of the NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the NI Vision Development Module.
    117110Templates are not downloaded to the RT target when generating code with the Vision Assistant Express VI.
    177318In NI TestStand 4.2, adding the Vision Assistant Express VI produces errors.
    181547In Vision Assistant, when attempting to edit an Adv. Straight Edge step the Setup window sometimes does not appear.
    182765RGB U64 images do not appear correctly after being saved with IMAQ Write File.
    182766RGB U64 images do not appear correctly after being saved with IMAQ Write File.
    183058In Vision Assistant, LabVIEW code generation fails silently when the .NET framework is not installed.
    18347914-bit images are displayed as solid gray if the bit depth is not set to 0.
    184217The resulting error message does not clearly indicate the problem when using the imgSessionSaveBufferEx function to try to save a bitmap image at an unsupported bit depth.
    187744IMAQ Read Image and Vision Info sometimes does not correctly dispose of read information.
    190834RGB U64 images do not appear correctly after being saved with IMAQ Write File.
    194334The Image Display control crashes when displaying a U16 image if the 90% Dynamic or Given Percentage Range conversion methods are selected.
    194728IMAQ ColorMatch might crash when an invalid number of elements is specified for the Color Spectrum array.
    195599In Vision Assistant, code generation does not work with LabVIEW (64-bit) on Windows 7 (64-bit).
    196464IMAQ ImageBorderSize cannot set an image border greater than 50.
    198927In Vision Assistant, the selected camera changes after clicking Refresh in the Acquire Image (IEEE 1394 or GigE) step.
    199417IMAQ Find Edge sometimes does not locate the expected edge.
    202323The VisionImage.ImageToArray method is slow when processing U16 images.
    203180Given Percentage Range is an invalid option when controlling the 16-bit display mapping through a property node.
    203622Vision Assistant returns a minimum screen resolution error when Windows Magnifier is enabled.
    205332On a Japanese operating system, Vision Assistant freezes when attempting to edit the Convolution - Custom step in the Cell Analysis solution.
    208699IMAQ Bisecting Line returns an incorrect bisection when one of the bisecting lines is almost vertical
    209196Filled overlays may not be displayed correctly in applications running on a remote target.
    210395.NET code generated from a Vision Assistant script that includes OCR allocates additional memory each time OCR is performed.
    211469The imaqSetWindowPalette function crashes if the number of colors in the palette exceeds 256.
    216627The C# VisionImage constructor can cause a System.IndexOutOfRangeException.
    221695IMAQ Match Geometric Pattern 2 ignores rotation angle match constraints when the Enable Coarse Result option is selected.
    222280The C# Algorithms.Rake method does not release memory until the application is closed.
    223205IMAQ Find Circles hangs when the source image dimensions are 3 × 3 pixels or smaller.
    233215.NET code generated from a Vision Assistant script that includes OCR allocates additional memory each time OCR is performed.
    224343IMAQ Geometric Pattern Matching does not correctly dispose of a resampled image when running on a real-time target.
    228638In Vision Assistant, rotated rectangle ROIs cannot be resized when editing an Adv. Straight Edge step.
    233562The Vision Assistant Help is unavailable after opening Vision Assistant from the Vision Assistant Express VI
    233994After calibrating an image and performing a clamp, the LabVIEW code generated by Vision Assistant or the Vision Assistant Express VI does not return calibrated distances.
    234029IMAQ Quantify 2 returns incorrect Minimal and Maximal values when the image mask is solid black.
    The development computer must meet the following system requirements to run the NI Vision Development Module:
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    1.4 GB
    Operating System
    Windows 7/Vista/XP (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 5.0 or later
    Installation InstructionsInstalling from the LabVIEW 2010 Platform DVDs
    If you purchased LabVIEW 2010, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW 2010 Platform DVDs.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the Vision Development Module CD.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the run-time engine installer for NI Vision. The run-time engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the Drivers and Updates section of ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module CD. The NI Vision Development Module CD ships with one run-time license. Contact a National Instruments sales representative or visit ni.com to purchase additional run-time licenses.
    Note: Additional NI Vision Run-Time Licenses do not include a CD. To install additional licenses, use the original NI Vision Development Module CD and the serial number provided by National Instruments.
    Using the NI Vision Run-Time Engine
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    To use the NI Vision Run-Time Engine installer, you must add /qn as a command line argument to the run-time engine installer. For example, enter \Run-Time Engine\vision2010rte.exe /qn to run the NI Vision Run-Time Engine installer, where is the location to which NI Vision is installed.
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibilty warnings.
    • The Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    • AVI functionality requires Microsoft DirectX 8.1 or later.
    • On Windows XP computers with Service Pack 2 installed, NI Vision does not support reading AVI files located in the Local Settings folder, or any subfolders of this folder, when the AVI file uses any of the following compression filters:
      • Indeo® Video 5.10 Compression Filter
      • Intel Indeo® Video R3.2
      • Intel Indeo® Video 4.5
      • Indeo® Video 5.10
      Copying the AVI file to another folder resolves this problem.
    • Viewing the online help files requires Microsoft Internet Explorer 5 or later.
    • Using NI Vision with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
    • The Vision Assistant Express VI image caching feature is available in LabVIEW 8.2 or later.
    The NI Vision Development Module documentation set consists of the following manuals and help files:
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—Describes how to create machine vision and image processing applications in LabVIEW using the NI Vision Development Module. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module.
      This document also contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. In LabVIEW, select Help»NI Vision for LabVIEW Help.
      Note: The NI Vision for LabVIEW Help combines the NI Vision for LabVIEW User Manual and NI Vision for LabVIEW VI Reference Help from previous releases into one document.
    • NI Example Finder—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision for .NET Documentation
    The NI Vision .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
    • Example programs for specific applications are installed at is the location to which NI Vision is installed.
    NI Vision Assistant Documentation
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    © 2010 National Instruments Corporation. All rights reserved.
    Additional Licenses
    This product contains third-party software. Refer to the NI Vision Development Module 2010 Beta Free and Open Source Software Notices for information about applicable notices and licenses. You can access the NI Vision Development Module 2010 Beta Free and Open Source Software Notices by navigating to \Licenses, where is the location to which you installed the NI Vision Development Module, and selecting VDM2010_beta_FOSS_notices.pdf.
    GMT+8, 2026-4-8 10:48
