查看: 14180|回复: 0
[NI驱动程序] NI Vision Acquisition Software 17.5 LabVIEW2017SP1 视觉采集软件VAS1750下载
    1 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2018-2-13 20:58:04 | 显示全部楼层 |阅读模式 来自:湖南省怀化市 移动
    NI Vision Acquisition Software 17.5 LabVIEW2017SP1 Win32/64Eng 视觉采集软件VAS1750下载
    2018年1月出品的NI视觉采集软件VAS17.5版本,可以应对当前的LabVIEW2017SP1以及NI VISION2017SP1、VBAI2015F3等版本。注意,从2017年6月发布的VAS1710开始,视觉采集软件VAS的命名方式,又变成大版本号.小版本号的方式,如前面的版本VAS17.1,现在的VAS17.5、以后的VAS18.0之类的版本。而在此之前则是按年月来命名的,如VAS_2017_05。在8.X以前的版本,也是按大版本号.小版本号的方式来命名,这次可以算是一次命名的回归。注意:VAS17.5版本,不同于VAS2017.05版本。VAS17.5版本是17大版的5小版本,支持LabVIEW2017SP1;VAS2017.05版本是2017年5月版本,只支持LabVIEW2017。
    文件大小: 3174036651 字节 (2.96 GB)
    修改日期: 2021-04-06 14:27
    MD5: ff163797ffe468e56810dacb6815dab0(官方正确)
    SHA1: cc402bfba4a1c8a679bcc814e07f789c5fde65dc
    SHA256: 0bfa64ca237cae69b79d70e13f995861da191b4d69d1f63b3b57578447bb54fa
    CRC32: 7d9c4425
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员登录后购买附件下载查看
    VAS17.5.txt (200 Bytes, 下载次数: 81, 售价: 10 圆)
    NI Vision Acquisition Software 17.5 Readme
    January 2018
    This file contains important information about National Instruments Vision Acquisition Software, including installation instructions, new features, fixed issues, and known issues.
    Vision Standards Support
    Updates and Improvements
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    Documentation and Examples
    LabVIEW NXG Considerations
    NI Vision Acquisition Software (VAS) allows you to acquire, display, and save images; control digital I/O on National Instruments image acquisition devices; and configure your driver software and hardware.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Acquisition Software.
    NI Vision Acquisition Software includes the following drivers:
    • NI-IMAQ is driver software for the following device types:
      • NI 17xx smart cameras
      • analog cameras
      • parallel digital cameras
      • Camera Link cameras
    • NI-IMAQdx is driver software for the following device types:
      • NI 177x smart cameras
      • ISC-178x smart cameras
      • GigE Vision-compliant cameras
      • USB3 Vision-compliant cameras
      • IIDC/DCAM-compliant IEEE 1394 cameras
      • DirectShow-compatible cameras
      • Basler and Axis IP cameras
    • NI-IMAQ I/O is driver software for controlling reconfigurable input/output (RIO) on image acquisition devices and real-time targets. The following hardware is supported by NI-IMAQ I/O:
      • NI CVS-1457RT
      • NI CVS-1458
      • NI CVS-1458RT
      • NI CVS-1459
      • NI CVS-1459RT
      • NI EVS-1463
      • NI EVS-1463RT
      • NI EVS-1464
      • NI EVS-1464RT
      • NI PCI-8254R
      • NI PCIe-8255R
      • NI PCIe-8237R
      • NI PCIe-1473R
      • NI PCIe-1473R-LX110
      • NI 1483 FlexRIO Adapter Module
    • Note: New versions of Vision Acquisition Software no longer support the following hardware:
      • NI 1762 and 1764 Smart Cameras
      • NI CVS-1454, 1455, and 1456 Compact Vision Systems
    • Note: The EVS-146x series of controllers are not supported in LabVIEW 2016 or later.
    Additional Driver Software
    Some hardware requires driver software in addition to Vision Acquisition Software drivers. Refer to the National Instruments website at ni.com/drivers for information about these drivers.
    • The NI PCIe-1473R and NI PCIe-1473R-LX110 require NI FlexRIO software to access the DRAM resources in a LabVIEW FPGA project.
    • The NI 1483 FlexRIO Adapter Module requires NI FlexRIO software.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    3.5 GB
    NI-IMAQ
    1.5 GB
    NI-IMAQdx
    1.5 GB
    NI-IMAQ I/O
    2.5 GB
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise (64-bit)3
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP1 (32- and 64-bit)2,3
    Note  NI Vision Acquisition Software August 2016 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Acquisition Software August 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Acquisition Software August 2016 or later to an unsupported OS. Additionally, after installing NI Vision Acquisition Software August 2016 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    3Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by NI Vision Acquisition Software. The installer specifically allows side-by-side installations of NI Vision Acquisition Software for each of the supported versions of LabVIEW, enabling you to use NI Vision Acquisition Software with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Vision Acquisition Software.
    NI Application SoftwareVersions Supported by NI Vision Acquisition Software
    NI LabVIEW
    2014, 2015, 2016, 2017
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabVIEW NXG
    2.0
    NI LabWindows™/CVI™
    2012, 2013, 2015, 2017
    NI Vision Development Module
    7.1 or later
    NI Vision Builder for Automated Inspection
    2.5 or later
    NI Vision Acquisition Software .NET Support
    NI Vision Acquisition Software February 2014 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Acquisition Software will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    The following table lists the machine vision and imaging standards supported by NI Vision Acquisition Software.
    Machine Vision or Imaging StandardVersion Supported by NI Vision Acquisition Software
    Camera Link®
    2.0
    GenICam™
    3.0.1
    GigE Vision®
    2.0 (select features)
    IIDC
    1.32
    USB3 Vision®
    1.0.1
    This release of NI Vision Acquisition Software includes the following new features.
    NI-IMAQ 17.5
    • No new features for this release
    NI-IMAQdx 17.5
    • Added support for LabVIEW NXG 2.0
      • For information about VAS support in LabVIEW NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    • Added NXG support for:
      • IIDC/DCAM-compliant IEEE 1394 cameras (no System Designer or Camera Soft Front Panel support)
    NI-IMAQ I/O 17.5
    • No new features in this release
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI Vision Acquisition Software.
    The following list contains potential high severity issues that you may want to review before using this product. Refer to the previous link to determine if any known issues have been resolved in a subsequent update.
    • Installing or reinstalling certain drivers, including NI-IMAQdx or Vision RIO support, on top of previous installations on a Linux Real-Time target can put the target in an unreachable state unless you force it into safe mode using the reset button or manually reassociate driver dependencies on the target. To avoid this issue, format the target prior to installing or reinstalling software, or only perform reinstallations using a Recommended Software Set. To learn more about this issue and additional recovery options, visit ni.com/info and enter the Info Code nikalEmbeddedReinstall.
    Complete the following steps to install NI Vision Acquisition Software.
    Note: You must have administrator access to install NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    NI-IMAQ and NI-IMAQdx integrate with NI Measurement & Automation Explorer (MAX), the National Instruments utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ.
    • Run NI MAX.
      • Double-click the NI MAX icon on the desktop. You can use NI MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with NI MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Use NI MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the NI MAX help window to install software.
    • Launch NI MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the NI MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to configure NI-IMAQdx.
    If you are using a USB webcam or other DirectShow-compatible camera, ensure that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an IEEE 1394, USB3 Vision, GigE Vision, or IP camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    • Install the NIC.
    • Choose Browse my computer for driver software.
    • Browse to the driver location. The newest driver version is installed to \NI-IMAQdx\Staging\NI GigE Vision.
    • Click Next.
    • Click Close.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps.
    Complete the following steps to configure NI-IMAQdx for Windows.
    • Connect the camera.
    • Run NI MAX.
      • Double-click the NI MAX icon on your desktop. You can use NI MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For IEEE 1394 and USB3 Vision cameras, NI-IMAQdx may not be associated with the camera if a third-party driver is installed. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx.
    • Run NI MAX.
      • Configure your network settings. Refer to the Remote Systems Help in NI MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the Real-Time target, using one of the following options:
      • Recommended Software Set on supported Smart Cameras, Embedded Vision Systems, Compact Vision Systems, CompactRIO controllers, NI Industrial Controllers, and FlexRIO controllers
        • Click Add/Remove Software on the NI MAX toolbar to launch the LabVIEW Real-Time Software Wizard.
        • Select Vision Software, NI CompactRIO, NI Industrial Controller, or FlexRIO under the version of the LabVIEW Real-Time Module you are using.
        • Click Next.
        • Select any additional add-ons you would like to install to the target machine. For some real-time targets, such as CompactRIO controllers, NI-IMAQdx or supported camera types will appear as an add-on.
        • Click Next to begin downloading the software to the target machine. When NI MAX has finished downloading the software, it restarts the remote device.
        • Click Finish.
      • Custom installation
        • If you are given a choice of Recommended Software Sets, choose custom software installation and click Next to proceed with a custom installation.
        • Select NI-IMAQdx, as well as any additional software you would like to install on the target machine.
        • Click Finish.
    • Press to refresh the NI MAX configuration tree. Your camera should be listed in the Remote Systems list.
    Documentation and examples are installed onto your hard drive with NI Vision Acquisition Software. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation and then select the driver documentation. You can also navigate to \Public\Public Documents\National Instruments. Some application-specific documents are installed to the application help folder, as listed in the following sections.
    NI Vision Acquisition Software Documentation for NI MAX
    • You can access the Measurement & Automation Explorer Help for NI-IMAQ and the Measurement & Automation Explorer Help for NI-IMAQdx from the NI MAX Help menu by selecting Help»Help Topics»NI Vision. These documents are installed to \MAX\Help.
    NI Vision Acquisition Software Documentation for LabVIEW
    • You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu.
    • NI Example Finder—Illustrates common applications you can create with NI Vision Acquisition Software. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. Vision Acquisition Software examples for LabVIEW are installed to is the location LabVIEW is installed.
    NI Vision Acquisition Software Documentation for LabWindows/CVI
    • NI-IMAQ Function Reference Help—Contains reference information about NI-IMAQ functions for LabWindows/CVI.
    • NI-IMAQdx Function Reference Help—Contains reference information about NI-IMAQdx functions for LabWindows/CVI.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each function to access help for that function, control, function class, and function library. The NIIMAQdx.fp, and \CVI\Bin.
    • Example programs are installed to
      • version\samples
    NI Vision Acquisition Software for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application. This document is installed to \Vision\Help.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples, and then select the driver you want to see examples for. You can also navigate to \Public\Public Documents\National Instruments.
    In LabVIEW NXG, NI-IMAQdx supports only the following:
    • IIDC/DCAM-compliant IEEE 1394 cameras (not available in the measurement panels or System Designer)
    For advanced camera configuration or renaming support, use NI MAX.
    © 2018 National Instruments. All rights reserved.
    375130G-01
    GMT+8, 2026-4-8 09:21
