查看: 5192|回复: 1
[LabVIEW] NI LabVIEW 2020 Evaluation MAC64Eng LV2020苹果系统评估版 64位英文版离线安装包下载
    11 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2020-10-23 22:37:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW 2020 MAC评估版(评估版好像需要序列号,请先了解授权问题再行购买),建议购买完整版或专业版。
    发布日期:
    20-5-15
    Mac OS X64
    语言:
    英文
    文件大小: 691108466 字节 (659.09 MB)
    修改日期: 2020-06-03 21:19
    MD5: 738eab363b0c53e3e67dda3788e40d76(重复下载一致)
    SHA1: 54be38fab2b01df04a4238b7adc4e52b16de058c
    SHA256: 9b61bcff79b47e07241641fb7ae01f348887c5c1a7e52ef35393ca30fef43b6c
    CRC32: 72acb84d
    LabVIEW2020Eval MAC.txt (567 Bytes, 下载次数: 3, 售价: 20 圆)
    LabVIEW 2020 Readme for macOS
    March 2020
    This file contains important information about LabVIEW 2020 for macOS, including system requirements, installation instructions, known issues, and a partial list of bugs fixed. LabVIEW 2020 for macOS is available only in 64-bit.
    Supported Drivers
    LabVIEW 2020 for macOS has the following requirements:
    macOSRun-Time EngineDevelopment Environment
    ProcessorIntel-based processorIntel-based processor
    RAM256 MB2 GB
    Operating SystemmacOS 10.14 or 10.15macOS 10.14 or 10.15
    • LabVIEW 2020 for macOS is available only in 64-bit.
    Note  If you download the installation image from ni.com, you may run into a macOS warning when you double-click the installer to run. Instead, right-click the installer and select Open. When you see the warning message, click Open to run the installer and proceed with the installation.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2020.
    Changes to selection rules for named Bundle and Unbundle nodes inside malleable VIs
    The rules for how LabVIEW selects cluster elements when you use a Bundle By Name function, Unbundle By Name function, or Unbundle / Bundle Elements Border Node have improved. The improvements may cause existing code to behave differently than you expect when you use these nodes inside a malleable VI. Visit ni.com/r/eakjbu for more information about how these changes impact existing code.
    Complete the following steps to install a patch on computers with LabVIEW 2020. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Mount LabVIEW2020f#.dmg and run LabVIEW 2020 f# Patch.
    • Verify that the patch installs correctly. Select Help»About LabVIEW and look for 20.0.0f# on the right portion of the window.
    Visit LabVIEW 2020 Patch Details for detailed information about all patches available for LabVIEW 2020 and issues fixed in each patch.
    LabVIEW 2020 for macOS supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    LabVIEW 2020 for macOS supports the following drivers. To use hardware with LabVIEW 2020, install the latest version of the driver for the device.
    • NI-488.2
    • NI-DAQmx Base
    • NI-VISA
    Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 Known Issues for an up-to-date list of known issues.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2020. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2020.
    374717N-01
  • 签到天数: 7 天
    发表于 2021-9-18 16:43:04 | 显示全部楼层 来自:广东省东莞市 联通
    GMT+8, 2026-4-9 20:01
