查看: 4329|回复: 0
[Patch补丁] NI LabVIEW 2020 f1Patch Full/Pro MAC64Eng LV2020f1补丁苹果系统完整版/专业版 64位英文版离线安装包下载
    11 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2020-9-23 23:38:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW 2020f1完整版/专业版补丁(是补丁文件,不是独立安装文件,请先安装LV2020MAC完整版或专业版)
    发布日期:
    20-8-31
    Mac OS
    语言:
    英文
    文件大小: 99216046 字节 (94.62 MB)
    修改日期: 2020-08-27 02:44
    MD5: 389624ab43c02eff4459f2c733273ea9(官方正确)
    SHA1: 401362c302cef9e8f64a95b1d3fee3ef247c6c28
    SHA256: b8a7bf864e89ad8f075528ee07248692a8e9cafbb5e27a0ee4efbbcd53ac9484
    CRC32: 0a757bbc
    下载地址:
    NI官方下载地址(可能无法下载完成或无效):
    登录视觉论坛会员购买附件查看
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 登录视觉论坛会员购买附件查看
    LV2020F1MAC.txt (308 Bytes, 下载次数: 2, 售价: 2 圆)
    LabVIEW 2020 Bug Fixes
    概览
    The following items are notable issues fixed between the release of LabVIEW 2019 SP1 and LabVIEW 2020, including additional patches and service packs. If you have an issue ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of LabVIEW 2020.
    Bug Number
    Legacy ID
    Description
    Details
    1009923
    Using Asynchronous Calls by Reference in LabVIEW 2019 SP1 can cause a memory leak.
    Workaround:
    Fixed in the LabVIEW 2019 SP1 f3 and LabVIEW 2020 f1 patches.
    Reported Version:
    LabVIEW 2019 SP1
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1057446
    Dynamic Dispatch method overrides do not save updates
    In specific situations, changes made to method overrides will not save.  Reopening the VI after saving changes will show the previous code.  This prevents users from updating Dynamic Dispatch VIs for child classes.
    Workaround:
    None
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    997305
    LabVIEW can crash or display incorrect text characters when "Use Unicode UTF-8" option enabled in Windows
    On systems that have the Windows option "Beta: Use Unicode UTF-8 for worldwide language support" enabled in Region settings, LabVIEW can crash or display garbled text in some languages. To find the Region settings go to Control Panel > Region > Administrative > Change system locale...
    This option causes the system default code page to be UTF-8, which LabVIEW does not support.
    R&D made changes in the LabVIEW 2020 f1 patch to prevent the crash, but some text will still display incorrectly in some languages.
    Workaround:
    Disable the "Beta: Use Unicode UTF-8 for worldwide language support" option in Windows.
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 5, 2020
    1054835
    SHA-256/SHA-224 results are incorrect for some message sizes
    LabVIEW returns the wrong value for a SHA-256 and SHA-224 for message sizes 56, 120, ..., (N*64+56) bytes
    Workaround:
    There is currently no known workaround for this issue.
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1019181
    Unable to install package: ni-vipm
    An error can occur during the LabVIEW 2020 installation which prevents the install of the package ni-vipm
    Workaround:
    Deselect VI Package Manager when installing
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1056583
    Right-clicking on a class wire/terminal/control when when right-click plugins causes crash
    When using right-click plugins, LabVIEW can sometimes crash if right clicking on a class wire, terminal, or control.
    Workaround:
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1014647
    LabVIEW hangs when the LabVIEW CLI tries to disconnect from the target LabVIEW instance
    Automated build systems using the LabVIEW CLI can cause LabVIEW to hang sometimes when disconnecting in the middle of a build.
    Workaround:
    Avoid trying to disconnect while building.
    Reported Version:
    LabVIEW 2019
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1009119
    XControls do not load correctly when placed in subVI
    When a XControl is placed in a subVI, the XControl may not appear.
    Workaround:
    Temporarily fix by redropping the XControl in the subVI, but the problem will return when the VI is loaded again.  No workaround for built applications.
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1048670
    LabVIEW crashes with id 0xC0000005 when using some forms of error tracing
    Workaround:
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1078977
    LabVIEW 2020 crashes when using the File >> New.. dialog and selecting Class or Interface
    Workaround:
    Add a class by right clicking and selecting New >> Class or Interface
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1000558
    LabVIEW can crash when the Class Hierarchy window is open and missing dependency
    If there is a class or interface which has a missing dependency class or interface and the LabVIEW Class Hierarchy window is open and the missing dependency is selected when you close the project or quit LabVIEW, a crash may be encountered.
    Workaround:
    Deselect the missing item before closing or close the Class Hierarchy window
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1047200
    VI for Override Throws Error 7 when overriding Packed Library with Debugging Enabled in LabVIEW 2020
    Try to create an override VI in a child class which inherits from a parent inside a Packed Project Library and debugging is enabled, it fails with Error 7.
    Workaround:
    Build override VI manually.
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1072837
    Casting Utility For Actors.vim has incorrect error handling
    When messages are created for interfaces there may be incorrect error handling behavior due to wiring in the Casting Utility For Actors.vim
    Workaround:
    Modify the VIM manually
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1055195
    "Casting Utility For Actors.vim" causes dependency issue when used in a PPL
    Workaround:
    Edit new messages to separate from the VIM
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    1043411
    RFmx Memory leak in LabVIEW 2020
    Large RFmx applications could see large memory leaks under some circumstances
    Workaround:
    Reported Version:
    LabVIEW 2020
    Resolved Version:
    LabVIEW 2020 f1
    Added:
    Aug 31, 2020
    166601
    545835
    LabVIEW Runtime Engine encounters Worker Thread Limit when using web services on Linux RT-based cRIO
    On a Linux RT-based cRIO, the LabVIEW Runtime Engine can get into a deadlocked state waiting for action from the Web Server. This can cause process hangs resulting in a Worker Thread Limit error reported to the user by the Web Server.
    Workaround:
    Use a mechanism other than web services.
    Reported Version:
    LabVIEW 2015
    Resolved Version:
    LabVIEW 2020
    Added:
    Feb 11, 2020
    221253
    509876
    Bundle by Name function can send wrong pointer into subVI with Call Library Function Node
    If a main VI has the output of a Bundle by Name function connected to a subVI, a Call Library Function node within the subVI can receive the wrong pointer from the wired cluster.
    Workaround:
    Reported Version:
    LabVIEW 2013 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Aug 7, 2016
    320200
    704376
    EXE including 'Std Deviation and Variance' VI is unloadable
    Building an executable including a VI that uses the 'Std Deviation and Variance' VI results in an error: "(Hex 0x464) VI is not loadable".
    Workaround:
    Reported Version:
    LabVIEW 2018
    Resolved Version:
    LabVIEW 2020
    Added:
    N/A
    316578
    457854
    Aborting a VI can leave VIs targeted by a Call By Reference node reserved permanently
    Workaround:
    Close the project to unreserve the VI
    Reported Version:
    LabVIEW 2013
    Resolved Version:
    LabVIEW 2020
    Added:
    Feb 18, 2020
    166386
    Incorrect behavior when using a Boolean control from the System palette
    When using a Boolean control from the System palette and running the VI, you do not see the "hover" picture change. When clicked, the value stays consistent, but the button does not change visually.
    Workaround:
    Do not use the System Boolean buttons or place them inside another structure.
    Reported Version:
    LabVIEW 2017 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    166645
    LabVIEW Application Builder fails to build a Source Distribution on Windows when using some specific vi.lib VIs that contain non-Windows components
    When using some specific vi.lib VIs (including vi.lib\Utility\tdmsutil.llb\TDMS Component Path.vi) that contain non-Windows components, LabVIEW Application Builder will fail to build a Source Distribution on Windows.
    Workaround:
    Reported Version:
    LabVIEW 2015 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    188865
    When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array
    When making multiple calls to Python function in a For Loop, the Python execution treats the passed data as a list, rather than a NumPy array.
    Workaround:
    Reported Version:
    LabVIEW 2019
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    221209
    Hovering over an override method in the Project Explorer does not show parent class description if the VI has empty description
    Workaround:
    Reported Version:
    LabVIEW 2017 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    166772
    587931
    Special characters (\r, \n, etc.) are not correctly converted to JSON when using LabVIEW Web services
    When a LabVIEW Web service is set to the JSON output type, strings with special characters such as tab constant, carriage return constant, and end of line constant are not escaped properly. This does not include the /s character.
    Workaround:
    Reported Version:
    LabVIEW 2015 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    166397
    Calling a Channel Write VI by reference in a loop results in a compiler error
    Workaround:
    Call this VI by reference outside the loop.
    Reported Version:
    LabVIEW 2017 SP1
    Resolved Version:
    LabVIEW 2020
    Added:
    Apr 20, 2020
    GMT+8, 2026-4-9 20:05
